1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Delta Tau motor control problem
To: Mark Davis <[email protected]>
Date: Wed, 1 Aug 2018 14:45:30 -0500
On 08/01, Mark Davis wrote:
> I assume that the driver SHOULD still work with the default Yes
> value.  Using the No value is not only less efficient, but could be
> a real problem.  If someone makes a typo when entering a new
> setpoint, it wouldn't matter if they realized their mistake and
> quickly entered the correct setpoint before the device has moved
> very much - It would still go all the way to the incorrect setting
> before starting to move to the correct position.
Couldn't you just stop the move?
Lewis
Delta Tau motor control problem Mark Davis
Re: Delta Tau motor control problem Mark Rivers
Re: Delta Tau motor control problem Mark Davis
Prev: Re: Delta Tau motor control problem Mark Davis
Next: CSS-Boy : trigger not firing for $(pv_name) at runtime Amien Crombie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Next: Fwd: Re: Delta Tau motor control problem Mark Davis
ANJ, 03 Aug 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
