Mark ,
f you want to see commands sent to controller set these PVs:
$(P):DEBUG_LEVEL = 16
$(P):DEBUG_EXECUTE = 1
(if you are using our edm screens then there is GUI for this)
This outputs all commands sent to the brick but all polling is muted.
If you want to send demands without going through the motor record then use PV
$(P):M1:DirectDemand
for motor 1.
I'm afraid I added these direct demands for similar reasons to the issue you are having. (I would like to be able to switch motor record into 'dumb' mode where it always sends all user actions to the controller. My issue was that we use 'deferred' moves where a script starts several motors simultaneously. In some circumstances on a six circle diffractometer with jittery motors, NTM logic would suppress one of the demands and this would be catastrophic.)
When I tried this on PPMAC I was using motor 6-9, all NTM related fields at default. I have also just tried it with motor 6-10-1
giles.
Sent: 02 August 2018 20:58:59
To: Knap, Giles (DLSLtd,RAL,LSCI); [email protected]; [email protected]
Subject: Re: Delta Tau motor control problem
Have you enabled asynTrace in the underlying asyn TCP driver to see what commands are actually being sent to the controller? There are probably asynTrace calls in the motor driver as well.
Sent: Thursday, August 2, 2018 10:18 AM
To: [email protected]; Mark Rivers; [email protected]
Hi Giles,
It took a while to get through the differences between the version I was
using and this latest one, but I eventually got it running using the
version you released yesterday. Unfortunately, it hasn't made any
difference.
Is there an easy way to test this functionality without going through
the motor record so I can at least determine if the problem is in the
driver or the motor record?
Does anybody know if there anything in the motor record that could cause
this if the fields in the motor record that describe various aspects of
the motor (e.g. velocity, acceleration, etc) are not properly configured?
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]
On 8/1/2018 12:04 PM, [email protected] wrote:
> Hi Mark,
> See latest pmac at https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_dls-2Dcontrols_pmac_releases_tag_2-2D1&d=DwIFAw&c=nE__W8dFE-shTxStwXtp0A&r=D7ZiziuMQuq40HlGYOZPBg&m=hXNy61CAHm2fE0dEnE_T6w8Mom1Re8RSl3DCYELh4zE&s=nQGySqmgeIasdlsqnzhNQCIgICRA-EbDPaFv3g9Gkvs&e=
> I agree with Mark R that this is related to an interaction between driver and NTM but I don't think a well behaved driver should ever exhibit what you describe.
> ________________________________
> From: [email protected] <[email protected]> on behalf of Mark Rivers <[email protected]>
> Sent: 01 August 2018 15:21:19
> To: [email protected]; Mark Davis
> Hi Mark,
> The motor record contains an NTM field that controls the behavior when a new target value is entered and the motor is still moving. What value does NTM have for your record?
> Mark
> From: [email protected] <[email protected]> on behalf of Mark Davis <[email protected]>
> Sent: Wednesday, August 1, 2018 8:35 AM
> Subject: Delta Tau motor control problem
> HI all,
> I have run in to another problem with my attempts to control a stepper
> motor using a Delta Tau controller.
> Current configuration:
> Motor Controller: Delta Tau Power Brick LV-IMS
> EPICS version: 3.14.12.2
> Asyn module: 4.32
> powerPMAC driver: The 2014-09-25 version at
> https://urldefense.proofpoint.com/v2/url?u=http-3A__www.observatorysciences.co.uk_deltatau-5Fdownloads.php&d=DwIFAw&c=nE__W8dFE-shTxStwXtp0A&r=D7ZiziuMQuq40HlGYOZPBg&m=hXNy61CAHm2fE0dEnE_T6w8Mom1Re8RSl3DCYELh4zE&s=-YPCsQc3KmJAS2-hRXAfTk3oJfzx4jZLMLQTKgz_GEw&e=
> IOC config:
> #===== for Power Brick LV-IMS controllers =====
> drvAsynPowerPMACPortConfigure("SSH1", "192.168.137.234", "root",
> "deltatau", "0", "0", "0")
> # 'Ctlr port name', 'SSH port name'. 'port address'. '#axes'
> 'Moving poll interval (ms)', 'Idle poll interval (ms)'
> powerPmacCreateController("PBRICK1", "SSH1", "0", "32", "25", "100")
> # open-loop axes (they don't use the encoder readback)
> pmacCreateAxis("PBRICK1", "3")
> asynSetTraceMask("PBRICK1", 0, 0)
> asynSetTraceMask("SSH1", -1, 0)
> asynSetTraceIOMask("SSH1", -1, 0)
> # includes a motor record...
> dbLoadTemplate("db/powerPMAC.substitutions")
> Using this configuration, I can control the motor via the motor record
> just fine, as long as I wait until the motor reaches the new position
> after each new setpoint.
> However, if I change the setpoint while the motor is still moving, it
> will stop before getting to either the new or the previous setpoint, the
> done moving bit in the status value from the controller stays at 0, and
> new setpoints to the motor record are ignored.
> If I then give the controller a move command directly, this works fine:
> The motor moves to the new position and the done moving bit goes back to
> 1, at which point new setpoints applied to the motor record will work again.
> NOTE: Changing the setpoint in a middle of the move using commands on
> the controller itself also works fine (e.g. it will happily reverse
> direction in the middle of a move to get to the latest setpoint).
> Given how long the motor record has been around, I assume that such a
> basic problem would have been resolved long ago. And the controller is
> fine with changes to the setpoint during a move, so I would think that
> the problem must be in the driver.
> Has anyone run in to this sort of thing before? Someone mentioned that
> the driver available from the Diamond Light Source incorporates the
> driver I am using (i.e. it should work for Geo Brick and Power Brick
> controllers?). Does anyone now if this is a driver bug and whether or
> not it is fixed in the DLS version?
> Thanks.
> Mark Davis
> NSCL/FRIB
> [email protected]
- Delta Tau motor control problem Mark Davis
- Re: Delta Tau motor control problem Mark Rivers
- Re: Delta Tau motor control problem [email protected]
- Re: Delta Tau motor control problem Mark Davis
RE: Stream Device: Parse response that includes checksum of command string [email protected]
Re: streamDevice 32-Bit ULONG endianess Dirk Zimoch
<2018>
<2018>
