1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: mrfioc2 Linux driver
To: Steve Kinder - UKRI STFC <[email protected]>
Date: Tue, 7 Aug 2018 09:15:15 -0700
> mrfioc2 3-0-0
The latest version of the mrfioc2 modules is 2.2.0 released in October 2017.  Are you my chance using the PSI forked version?
http://epics.sourceforge.net/mrfioc2/
Please note the Supported Hardware section.  This includes the PCIe-EVR-300dc
Section 4 of my manual covers the setup you're trying to do.
http://epics.sourceforge.net/mrfioc2/evr-usage.pdf
There is also a example UDEV rule in mrmShared/linux/README
If you're able to try 2.2.0, and still have difficulty getting the kernel module loaded,
please reply with the output of:
> lsmod |grep mrf
> dmesg|grep mrf
On 08/07/2018 08:40 AM, Steve Kinder - UKRI STFC wrote:
> Hello all
> I am trying to get an MRF PCIe-EVR-300DC configured and working on Linux using mrfioc2. I think I have an IOC built. I think I have some understanding of the parameters to mrmEvrSetupPCI(EVR-01, 1, 0, 0, 0). I could well be wrong on those but that isn't the source of my immediate problem. Executing the previous call gives:
> Can't open /sys/module/mrf/parameters/interfaceversion in order to read kernel module interface version. Is kernel module loaded?
> I found some documentation that indicates an MRF kernel driver is also required:
> $ make -C /location/of/mrmShared/linux \
> KERNELDIR=/lib/modules/`uname -r`/build modules_install
> $ sudo depmod -a
> $ sudo modprobe mrf
> I seem to need to execute the first line as root or I get permissions problems. However then I get:
> # make -C /home/controls/work/R3.14.12.5/support/mrfioc2/3-0-0/mrmShared/linux KERNELDIR=/lib/modules/`uname -r`/build modules_install
> make: Entering directory `/home/controls/work/R3.14.12.5/support/mrfioc2/3-0-0/mrmShared/linux'
> make -C /lib/modules/3.10.0-514.6.1.el7.x86_64/build M=/home/controls/work/R3.14.12.5/support/mrfioc2/3-0-0/mrmShared/linux modules_install
> make[1]: Entering directory `/usr/src/kernels/3.10.0-514.6.1.el7.x86_64'
> Makefile:641: Cannot use CONFIG_CC_STACKPROTECTOR_STRONG: -fstack-protector-strong not supported by compiler
>   DEPMOD  3.10.0-514.6.1.el7.x86_64
> make[1]: Leaving directory `/usr/src/kernels/3.10.0-514.6.1.el7.x86_64'
> make: Leaving directory `/home/controls/work/R3.14.12.5/support/mrfioc2/3-0-0/mrmShared/linux'
> The documentation dates back to 2015, Rev 7, so may be out of date?
> Any advice/help would be much appreciated. Further documentation?
> My kernel is 3.10.0-514.6.1.el7.x86_64, mrfioc2 3-0-0
> Thanks
> Steve
> d
> o
> m
> o
> d
> p
> r
> o
> b
> e
> m
> r
> f
Re: mrfioc2 Linux driver Jeong Han Lee
Re: mrfioc2 Linux driver Steve Kinder - UKRI STFC
Prev: mrfioc2 Linux driver Steve Kinder - UKRI STFC
Next: Re: mrfioc2 Linux driver Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
ANJ, 09 Aug 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
