Hi John,
We just received our first XPS-D8 models last week. The advertised claim that they are completely hardware and software compatible with the XPS-Q8 is not true. These are
the differences we have found so far:
The D8 does not support FTP to fetch/load configuration files or trajectory definition files. It supports SFTP. This means that the trajectory/profile move code
in the driver will need to be changed.
The I/O connector that has the pulse outputs for trajectory scans has changed. The C8 and Q8 have a DB-25 connector. The D8 has a DB-50 connector and different
pins.
The basic motor record support appears to work OK in our initial testing.
Is the motor record known to work with the latest version of the Newport XPS hardware, XPS-D8?
Research Support Specialist
Cornell Laboratory for Accelerator Sciences and Education
- Newport XPS-D8 John Dobbins
Re: Newport XPS-D8 Matt Newville
<2018>
<2018>
ANJ, 29 Aug 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
