1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn: disconnect and reconnect port via PV
To: [email protected]
Date: Fri, 31 Aug 2018 09:13:41 -0400
Maybe you can use asynRecord's CNCT field:
dbLoadRecords("../../db/asynRecord.db","P=asyn,R=Record,PORT=device_port,ADDR=0,OMAX=0,IMAX=0")
Bruno
On Fri, Aug 31, 2018 at 2:30 AM Niedermayer, Philipp <[email protected]> wrote:
Hello everyone,
I have implemented a soft IOC that communicates to a spectrum analyzer via asyn and stream device using vxi11:
vxi11Configure("device_port","$(DEVICE_IP)",0,"0.0","inst0",0,0)
The device has a limitation that it can only be controlled by one remote controller at a time. The current approach is to temporarily stop the entire soft IOC when required and then restart it via the st.cmd file.
It would be better to have a PV (e.g. a bo with CONNECTED/DISCONNECTED state) for this task, that can dis- and reconnect the asyn port.
I know that you can disable record processing by the DISA field, but that did not prevent asyn to keep up a connection to the device in background.
I found the “asynManager” which has the promising “connectDevice” and “disconnect” option, but I’m not sure how to (if at all) call them from the PV.
Is there a way to have such a PV? How could that be implemented?
Greetings and tanks in advance
Philipp
Forschungszentrum Juelich GmbH
52425 Juelich
Sitz der Gesellschaft: Juelich
Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498
Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher
Geschaeftsfuehrung: Prof. Dr.-Ing. Wolfgang Marquardt (Vorsitzender),
Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt,
Prof. Dr. Sebastian M. Schmidt
Asyn: disconnect and reconnect port via PV Niedermayer, Philipp
Prev: OXCS N-Helix communication Allan Serra Braga Bugyi
Next: RE: Asyn: disconnect and reconnect port via PV Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Asyn: disconnect and reconnect port via PV Niedermayer, Philipp
ANJ, 31 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
