1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Linux scan thread suspended
To: Mark Rivers <[email protected]>, 'Pilar Gil Jaldo' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 5 Sep 2018 14:07:03 +0000
> epicsStrDup: mallocMustSucceed(1) - malloc failed Thread scan2 (0x9c2b038) suspending.
Another possibility is that the string that was passed to epicsStrDup was not properly 0 terminated, and so it was trying to copy a very large string, which led to the malloc failure.
-----Original Message-----
From: [email protected] <[email protected]> On Behalf Of Mark Rivers
Sent: Wednesday, September 5, 2018 9:03 AM
To: 'Pilar Gil Jaldo' <[email protected]>; [email protected]
Hi Pilar,
I think your case is different from the tech-talk thread.  In the tech-talk thread they said there was no IOC error mesage, but in  your case you have a very clear IOC error message:
This says to me that your IOC has run out of memory.  I suspect there is a memory leak somewhere.
Is this a 32 or 64 bit machine, and how much memory does it have?
You could restart the IOC and use "top" to look at the memory usage with time.
What version of EPICS are you using, and what devices does this IOC control?
From: [email protected] <[email protected]> On Behalf Of Pilar Gil Jaldo
Sent: Wednesday, September 5, 2018 8:36 AM
To: [email protected]
Subject: Linux scan thread suspended
Hello everybody,
I have a question regarding the reasons why a scan thread can be suspended. I have a running IOC and at a certain moment the IOC breaks with following message:
I have found in the tech-talk messages following reason which seems to be the same problem that mine.
https://epics.anl.gov/tech-talk/2013/msg00154.php
The IOC is on a network where many devices are sending packages to the CA network, but nobody is answering because other devices are switched off (the traffic in the CA is very high).
Is it possible that the segmentation fault is caused by a network congestion? Can the scan thread be suspended by a higher network traffic?
Thank you very much in advance for your answers.
Pilar Gil Jaldo
Linux scan thread suspended Pilar Gil Jaldo
RE: Linux scan thread suspended Mark Rivers
Prev: RE: Linux scan thread suspended Mark Rivers
Next: Re: Linux scan thread suspended Pilar Gil Jaldo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 05 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
