1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Linux network tuning
To: [email protected]
Cc: [email protected]
Date: Wed, 5 Sep 2018 08:11:52 -1000
It's been a long time since I felt the need to do network tuning on a
Linux host. Back when I still felt that need (some 15+ years ago) I
attempted to tune my way to better throughput on a gigabit network;
everything I tried made the performance worse than the automatic
behavior in the stock Linux kernel.
I don't doubt that there are special cases where tuning matters. None
of my fairly aggressive cases were special enough to cross that
threshold. I wouldn't be surprised if these delays are somewhere
else-- have you confirmed your name resolution setup is correct?
--Kyle
On Wed, Sep 5, 2018 at 8:06 AM Eric Norum <[email protected]> wrote:
> Are there guidelines for tuning the network parameters for a Linux host running a bunch of EPICS soft IOCs?  We were seeing some issues with CA clients seeing delays of over a second for ‘get' requests.  Setting the values shown here:
> net.core.netdev_max_backlog = 5000
> net.core.rmem_max = 8388608
> net.core.wmem_max = 8388608
> net.core.rmem_default = 124928
> net.core.wmem_default = 124928
> net.ipv4.tcp_rmem = 4096 87380 8388608
> net.ipv4.tcp_wmem = 4096 65536 8388608
> net.ipv4.tcp_mem = 8388608 8388608 8388608
> seems to have improved things.  But I don’t know if those numbers, which I got from a google search, are way too big, or not yet big enough or completely weird.
> Suggestions welcomed.
> Machine details:
> 8 cores
> 24 GiB RAM
> 1 TB SSD
> Gigabit Ethernet
> EPICS R3.15.4
> Load average in the 3 to 4 range but CPU utilization as shown by ‘top’ showed at least 60% idle even when clients were experiencing the slow response.
> Eric Norum
> [email protected]
RE: Linux network tuning Mark Rivers
Linux network tuning Eric Norum
Prev: Linux network tuning Eric Norum
Next: Re: Problem with database parsing in EPICS 7.0.1 Kim, Kukhee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Linux network tuning Mark Rivers
ANJ, 05 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
