1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: asynPortDriver and read/write access to record fields
Date: Thu, 20 Sep 2018 09:21:14 +0200
Coming back to my original question: How would I set HOPR from inside
AsynPort Driver? Only via this 'intermediate record method'?
Or is there an (opaque) interface?
-bastian
On 180919-2040, Mark Rivers wrote:
> Another option is to load your waveform record with NELM being as large as you would ever want.  You can then set HOPR to be the last channel actually used in that sweep.  You do need to replot the display if HOPR changes, but that can be done with a single medm button.
> You could also use medm for control and a simple Python or other language GUI just for the trace plot.
> Mark
> -----Original Message-----
> From: Loeher, Bastian Dr. <[email protected]>
> Sent: Wednesday, September 19, 2018 1:33 PM
> Cc: [email protected]
> Dear Mark,
> thanks for the quick response.
> Looks like I have two options:
> a) Fixed axes & number of samples to display (so interpolation / downsampling needed).
> b) Look into using a more modern DM.
> Option a) I can try out, because for simple standalone systems MEDM still is a very suitable tool.
> For option b) I'm currently looking into using phoebus.
> Bastian
> On 180919-0104, Mark Rivers wrote:
> > > When using MEDM to display the waveform using the Cartesian plot, one must (so I understand) adjust the 'LOPR', 'HOPR', and 'NELM' fields of the record for the time X axis.
> > I believe that NELM cannot be changed after iocInit.  It would need to be large enough for the largest waveform you will display.
> > You can change HOPR and LOPR for the X and Y waveform records to change the displayed range in medm.  However, medm does not automatically rescale the plot when you change HOPR and LOPR, so you must close and re-open the plot when you change those.
> > Mark
> > From: [email protected] <[email protected]> On
> > Behalf Of Dr. Bastian Löher
> > Sent: Tuesday, September 18, 2018 2:44 PM
> > To: [email protected]
> > Subject: asynPortDriver and read/write access to record fields
> > Hi,
> > I'm in the process of implementing an asynPortDriver based driver for a USB scope (Picotech 2000 series). The driver is based on the testAsynPortDriver example.
> > Since a real device is connected the driver produces waveforms, where the length and axis ranges depend on the user settings (i.e. capture time, sampling frequency and so on).
> > When taking the axis range in MEDM from the channel, then the waveform will be clipped (when NELM is too small), or it will only occupy part of the display (when NELM is too large).
> > I also tested auto-scale of the axis, but in that case also the axis labels are never changed.
> > What is the standard procedure here? Should I use something else than MEDM? Or is it possible to get to work by changing my code/record database?
> > I've seen an old post using intermediate 'longout' records, but they didn't seem to work as intended.
> > (https://epics.anl.gov/tech-talk/2015/msg00289.php)
> > Thanks
> > Bastian
> Dr. Bastian Löher
> Data acquisition
> Experiment controls
> Detector development
> R3B - Relativistic reactions with radioactive beams Gamma spectroscopy
> -- TU Darmstadt ---------------------------------------------------------------
> Room / Raum: S2|14 420
> Phone / Telefon: +49 6151 75373
> Mobile / Mobil: +49 162 5467038
> E-Mail: [email protected]
> Institut für Kernphysik
> Technische Universität Darmstadt
> Schlossgartenstrasse 9, 64289 Darmstadt
> http://www.ikp.tu-darmstadt.de
> -- GSI ------------------------------------------------------------------------
> Room / Raum: SB3 3.199, KBW 5.15, SH4 2.007 Phone / Telefon: +49 6159 71 2739, 1803, 3272
> Fax: +49 6159 71 3007
> GSI Helmholtzzentrum für Schwerionenforschung GmbH Planckstraße 1, 64291 Darmstadt, Germany, www.gsi.de
> Commercial Register / Handelsregister: Amtsgericht Darmstadt, HRB 1528 Managing Directors / Geschäftsführung:
> Professor Dr. Paolo Giubellino, Ursula Weyrich, Jörg Blaurock Chairman of the Supervisory Board / Vorsitzender des GSI-Aufsichtsrats:
> State Secretary / Staatssekretär Dr. Georg Schütte
Dr. Bastian Löher
Data acquisition
Experiment controls
Gamma spectroscopy
asynPortDriver and read/write access to record fields Dr. Bastian Löher
RE: asynPortDriver and read/write access to record fields Mark Rivers
Re: asynPortDriver and read/write access to record fields Loeher, Bastian Dr.
Prev: RE: measComp 2-1 and TC32 Mark Rivers
Next: Re: asynPortDriver and read/write access to record fields Dr. Bastian Löher
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: Re: asynPortDriver and read/write access to record fields Arnold, Ned D.
Next: Question about timing in Cachannel lzf neu
ANJ, 20 Sep 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
