mbbi2.tar.gz /*************************************************************** * StreamDevice record interface for * * multibit binary input direct records * * * * (C) 1999 Dirk Zimoch ([email protected]) * * (C) 2005 Dirk Zimoch ([email protected]) * * * * This is an EPICS record Interface for StreamDevice. * * Please refer to the HTML files in ../doc/ for a detailed * * documentation. * * * * If you do any changes in this file, you are not allowed to * * redistribute it any more. If there is a bug or a missing * * feature, send me an email and/or your patch. If I accept * * your changes, they will go to the next release. * * * * DISCLAIMER: If this software breaks something or harms * * someone, it's your problem. * * * ***************************************************************/ #include "devStream.h" #include <mbbi2Record.h> #include <epicsExport.h> static long readData (dbCommon *record, format_t *format) { mbbi2Record *mbbiD = (mbbi2Record *) record; long val; if (format->type == DBF_LONG) { if (streamScanf (record, format, &val)) return ERROR; if (mbbiD->mask) { val &= mbbiD->mask; mbbiD->rval = val; return OK; } else { /* No MASK, (NOBT = 0): use VAL field */ mbbiD->val = (short)val; return DO_NOT_CONVERT; } } return ERROR; } static long writeData (dbCommon *record, format_t *format) { mbbi2Record *mbbiD = (mbbi2Record *) record; long val; if (format->type == DBF_LONG) { if (mbbiD->mask) val = mbbiD->rval & mbbiD->mask; else val = mbbiD->val; return streamPrintf (record, format, val); } return ERROR; } static long initRecord (dbCommon *record) { mbbi2Record *mbbiD = (mbbi2Record *) record; mbbiD->mask <<= mbbiD->shft; return streamInitRecord (record, &mbbiD->inp, readData, writeData) == ERROR ? ERROR : OK; } struct { long number; DEVSUPFUN report; DEVSUPFUN init; DEVSUPFUN init_record; DEVSUPFUN get_ioint_info; DEVSUPFUN read; } devmbbi2Stream = { 5, streamReport, streamInit, initRecord, streamGetIointInfo, streamRead }; epicsExportAddress(dset,devmbbi2Stream); #ifndef INCmbbi2H #define INCmbbi2H #include "epicsTypes.h" #include "link.h" #include "epicsMutex.h" #include "ellLib.h" #include "epicsTime.h" typedef struct mbbi2Record { char name[61]; /* Record Name */ char desc[41]; /* Descriptor */ char asg[29]; /* Access Security Group */ epicsEnum16 scan; /* Scan Mechanism */ epicsEnum16 pini; /* Process at iocInit */ epicsInt16 phas; /* Scan Phase */ epicsInt16 evnt; /* Event Number */ epicsInt16 tse; /* Time Stamp Event */ DBLINK tsel; /* Time Stamp Link */ epicsEnum16 dtyp; /* Device Type */ epicsInt16 disv; /* Disable Value */ epicsInt16 disa; /* Disable */ DBLINK sdis; /* Scanning Disable */ epicsMutexId mlok; /* Monitor lock */ ELLLIST mlis; /* Monitor List */ epicsUInt8 disp; /* Disable putField */ epicsUInt8 proc; /* Force Processing */ epicsEnum16 stat; /* Alarm Status */ epicsEnum16 sevr; /* Alarm Severity */ epicsEnum16 nsta; /* New Alarm Status */ epicsEnum16 nsev; /* New Alarm Severity */ epicsEnum16 acks; /* Alarm Ack Severity */ epicsEnum16 ackt; /* Alarm Ack Transient */ epicsEnum16 diss; /* Disable Alarm Sevrty */ epicsUInt8 lcnt; /* Lock Count */ epicsUInt8 pact; /* Record active */ epicsUInt8 putf; /* dbPutField process */ epicsUInt8 rpro; /* Reprocess */ struct asgMember *asp; /* Access Security Pvt */ struct putNotify *ppn; /* addr of PUTNOTIFY */ struct putNotifyRecord *ppnr; /* pputNotifyRecord */ struct scan_element *spvt; /* Scan Private */ struct rset *rset; /* Address of RSET */ struct dset *dset; /* DSET address */ void *dpvt; /* Device Private */ struct dbRecordType *rdes; /* Address of dbRecordType */ struct lockRecord *lset; /* Lock Set */ epicsEnum16 prio; /* Scheduling Priority */ epicsUInt8 tpro; /* Trace Processing */ char bkpt; /* Break Point */ epicsUInt8 udf; /* Undefined */ epicsTimeStamp time; /* Time */ DBLINK flnk; /* Forward Process Link */ epicsUInt16 val; /* Current Value */ epicsInt16 nobt; /* Number of Bits */ DBLINK inp; /* Input Specification */ epicsUInt32 rval; /* Raw Value */ epicsUInt32 oraw; /* Prev Raw Value */ epicsUInt32 mask; /* Hardware Mask */ epicsUInt16 mlst; /* Last Value Monitored */ epicsUInt16 lalm; /* Last Value Alarmed */ epicsInt16 sdef; /* States Defined */ epicsUInt16 shft; /* Shift */ DBLINK siol; /* Sim Input Specifctn */ epicsUInt32 sval; /* Simulation Value */ DBLINK siml; /* Sim Mode Location */ epicsEnum16 simm; /* Simulation Mode */ epicsEnum16 sims; /* Sim mode Alarm Svrty */ epicsUInt8 b0; /* Bit 0 */ epicsUInt8 b1; /* Bit 1 */ epicsUInt8 b2; /* Bit 2 */ epicsUInt8 b3; /* Bit 3 */ epicsUInt8 b4; /* Bit 4 */ epicsUInt8 b5; /* Bit 5 */ epicsUInt8 b6; /* Bit 6 */ epicsUInt8 b7; /* Bit 7 */ epicsUInt8 b8; /* Bit 8 */ epicsUInt8 b9; /* Bit 9 */ epicsUInt8 ba; /* Bit A */ epicsUInt8 bb; /* Bit B */ epicsUInt8 bc; /* Bit C */ epicsUInt8 bd; /* Bit D */ epicsUInt8 be; /* Bit E */ epicsUInt8 bf; /* Bit F */ char b0st[26]; /* Bit 0 description */ char b1st[26]; /* Bit 1 description */ char b2st[26]; /* Bit 2 description */ char b3st[26]; /* Bit 3 description */ char b4st[26]; /* Bit 4 description */ char b5st[26]; /* Bit 5 description */ char b6st[26]; /* Bit 6 description */ char b7st[26]; /* Bit 7 description */ char b8st[26]; /* Bit 8 description */ char b9st[26]; /* Bit 9 description */ char bast[26]; /* Bit A description */ char bbst[26]; /* Bit B description */ char bcst[26]; /* Bit C description */ char bdst[26]; /* Bit D description */ char best[26]; /* Bit E description */ char bfst[26]; /* Bit F description */ epicsEnum16 b0zsv; /* Bit 0 zero severity */ epicsEnum16 b1zsv; /* Bit 1 zero severity */ epicsEnum16 b2zsv; /* Bit 2 zero severity */ epicsEnum16 b3zsv; /* Bit 3 zero severity */ epicsEnum16 b4zsv; /* Bit 4 zero severity */ epicsEnum16 b5zsv; /* Bit 5 zero severity */ epicsEnum16 b6zsv; /* Bit 6 zero severity */ epicsEnum16 b7zsv; /* Bit 7 zero severity */ epicsEnum16 b8zsv; /* Bit 8 zero severity */ epicsEnum16 b9zsv; /* Bit 9 zero severity */ epicsEnum16 bazsv; /* Bit A zero severity */ epicsEnum16 bbzsv; /* Bit B zero severity */ epicsEnum16 bczsv; /* Bit C zero severity */ epicsEnum16 bdzsv; /* Bit D zero severity */ epicsEnum16 bezsv; /* Bit E zero severity */ epicsEnum16 bfzsv; /* Bit F zero severity */ epicsEnum16 b0osv; /* Bit 0 one severity */ epicsEnum16 b1osv; /* Bit 1 one severity */ epicsEnum16 b2osv; /* Bit 2 one severity */ epicsEnum16 b3osv; /* Bit 3 one severity */ epicsEnum16 b4osv; /* Bit 4 one severity */ epicsEnum16 b5osv; /* Bit 5 one severity */ epicsEnum16 b6osv; /* Bit 6 one severity */ epicsEnum16 b7osv; /* Bit 7 one severity */ epicsEnum16 b8osv; /* Bit 8 one severity */ epicsEnum16 b9osv; /* Bit 9 one severity */ epicsEnum16 baosv; /* Bit A one severity */ epicsEnum16 bbosv; /* Bit B one severity */ epicsEnum16 bcosv; /* Bit C one severity */ epicsEnum16 bdosv; /* Bit D one severity */ epicsEnum16 beosv; /* Bit E one severity */ epicsEnum16 bfosv; /* Bit F one severity */ epicsUInt16 bas; /* Bits alarm source */ } mbbi2Record; #define mbbi2RecordNAME 0 #define mbbi2RecordDESC 1 #define mbbi2RecordASG 2 #define mbbi2RecordSCAN 3 #define mbbi2RecordPINI 4 #define mbbi2RecordPHAS 5 #define mbbi2RecordEVNT 6 #define mbbi2RecordTSE 7 #define mbbi2RecordTSEL 8 #define mbbi2RecordDTYP 9 #define mbbi2RecordDISV 10 #define mbbi2RecordDISA 11 #define mbbi2RecordSDIS 12 #define mbbi2RecordMLOK 13 #define mbbi2RecordMLIS 14 #define mbbi2RecordDISP 15 #define mbbi2RecordPROC 16 #define mbbi2RecordSTAT 17 #define mbbi2RecordSEVR 18 #define mbbi2RecordNSTA 19 #define mbbi2RecordNSEV 20 #define mbbi2RecordACKS 21 #define mbbi2RecordACKT 22 #define mbbi2RecordDISS 23 #define mbbi2RecordLCNT 24 #define mbbi2RecordPACT 25 #define mbbi2RecordPUTF 26 #define mbbi2RecordRPRO 27 #define mbbi2RecordASP 28 #define mbbi2RecordPPN 29 #define mbbi2RecordPPNR 30 #define mbbi2RecordSPVT 31 #define mbbi2RecordRSET 32 #define mbbi2RecordDSET 33 #define mbbi2RecordDPVT 34 #define mbbi2RecordRDES 35 #define mbbi2RecordLSET 36 #define mbbi2RecordPRIO 37 #define mbbi2RecordTPRO 38 #define mbbi2RecordBKPT 39 #define mbbi2RecordUDF 40 #define mbbi2RecordTIME 41 #define mbbi2RecordFLNK 42 #define mbbi2RecordVAL 43 #define mbbi2RecordNOBT 44 #define mbbi2RecordINP 45 #define mbbi2RecordRVAL 46 #define mbbi2RecordORAW 47 #define mbbi2RecordMASK 48 #define mbbi2RecordMLST 49 #define mbbi2RecordLALM 50 #define mbbi2RecordSDEF 51 #define mbbi2RecordSHFT 52 #define mbbi2RecordSIOL 53 #define mbbi2RecordSVAL 54 #define mbbi2RecordSIML 55 #define mbbi2RecordSIMM 56 #define mbbi2RecordSIMS 57 #define mbbi2RecordB0 58 #define mbbi2RecordB1 59 #define mbbi2RecordB2 60 #define mbbi2RecordB3 61 #define mbbi2RecordB4 62 #define mbbi2RecordB5 63 #define mbbi2RecordB6 64 #define mbbi2RecordB7 65 #define mbbi2RecordB8 66 #define mbbi2RecordB9 67 #define mbbi2RecordBA 68 #define mbbi2RecordBB 69 #define mbbi2RecordBC 70 #define mbbi2RecordBD 71 #define mbbi2RecordBE 72 #define mbbi2RecordBF 73 #define mbbi2RecordB0ST 74 #define mbbi2RecordB1ST 75 #define mbbi2RecordB2ST 76 #define mbbi2RecordB3ST 77 #define mbbi2RecordB4ST 78 #define mbbi2RecordB5ST 79 #define mbbi2RecordB6ST 80 #define mbbi2RecordB7ST 81 #define mbbi2RecordB8ST 82 #define mbbi2RecordB9ST 83 #define mbbi2RecordBAST 84 #define mbbi2RecordBBST 85 #define mbbi2RecordBCST 86 #define mbbi2RecordBDST 87 #define mbbi2RecordBEST 88 #define mbbi2RecordBFST 89 #define mbbi2RecordB0ZSV 90 #define mbbi2RecordB1ZSV 91 #define mbbi2RecordB2ZSV 92 #define mbbi2RecordB3ZSV 93 #define mbbi2RecordB4ZSV 94 #define mbbi2RecordB5ZSV 95 #define mbbi2RecordB6ZSV 96 #define mbbi2RecordB7ZSV 97 #define mbbi2RecordB8ZSV 98 #define mbbi2RecordB9ZSV 99 #define mbbi2RecordBAZSV 100 #define mbbi2RecordBBZSV 101 #define mbbi2RecordBCZSV 102 #define mbbi2RecordBDZSV 103 #define mbbi2RecordBEZSV 104 #define mbbi2RecordBFZSV 105 #define mbbi2RecordB0OSV 106 #define mbbi2RecordB1OSV 107 #define mbbi2RecordB2OSV 108 #define mbbi2RecordB3OSV 109 #define mbbi2RecordB4OSV 110 #define mbbi2RecordB5OSV 111 #define mbbi2RecordB6OSV 112 #define mbbi2RecordB7OSV 113 #define mbbi2RecordB8OSV 114 #define mbbi2RecordB9OSV 115 #define mbbi2RecordBAOSV 116 #define mbbi2RecordBBOSV 117 #define mbbi2RecordBCOSV 118 #define mbbi2RecordBDOSV 119 #define mbbi2RecordBEOSV 120 #define mbbi2RecordBFOSV 121 #define mbbi2RecordBAS 122 #endif /*INCmbbi2H*/ #ifdef GEN_SIZE_OFFSET #ifdef __cplusplus extern "C" { #endif #include <epicsExport.h> static int mbbi2RecordSizeOffset(dbRecordType *pdbRecordType) { mbbi2Record *prec = 0; pdbRecordType->papFldDes[0]->size=sizeof(prec->name); pdbRecordType->papFldDes[0]->offset=(short)((char *)&prec->name - (char *)prec); pdbRecordType->papFldDes[1]->size=sizeof(prec->desc); pdbRecordType->papFldDes[1]->offset=(short)((char *)&prec->desc - (char *)prec); pdbRecordType->papFldDes[2]->size=sizeof(prec->asg); pdbRecordType->papFldDes[2]->offset=(short)((char *)&prec->asg - (char *)prec); pdbRecordType->papFldDes[3]->size=sizeof(prec->scan); pdbRecordType->papFldDes[3]->offset=(short)((char *)&prec->scan - (char *)prec); pdbRecordType->papFldDes[4]->size=sizeof(prec->pini); pdbRecordType->papFldDes[4]->offset=(short)((char *)&prec->pini - (char *)prec); pdbRecordType->papFldDes[5]->size=sizeof(prec->phas); pdbRecordType->papFldDes[5]->offset=(short)((char *)&prec->phas - (char *)prec); pdbRecordType->papFldDes[6]->size=sizeof(prec->evnt); pdbRecordType->papFldDes[6]->offset=(short)((char *)&prec->evnt - (char *)prec); pdbRecordType->papFldDes[7]->size=sizeof(prec->tse); pdbRecordType->papFldDes[7]->offset=(short)((char *)&prec->tse - (char *)prec); pdbRecordType->papFldDes[8]->size=sizeof(prec->tsel); pdbRecordType->papFldDes[8]->offset=(short)((char *)&prec->tsel - (char *)prec); pdbRecordType->papFldDes[9]->size=sizeof(prec->dtyp); pdbRecordType->papFldDes[9]->offset=(short)((char *)&prec->dtyp - (char *)prec); pdbRecordType->papFldDes[10]->size=sizeof(prec->disv); pdbRecordType->papFldDes[10]->offset=(short)((char *)&prec->disv - (char *)prec); pdbRecordType->papFldDes[11]->size=sizeof(prec->disa); pdbRecordType->papFldDes[11]->offset=(short)((char *)&prec->disa - (char *)prec); pdbRecordType->papFldDes[12]->size=sizeof(prec->sdis); pdbRecordType->papFldDes[12]->offset=(short)((char *)&prec->sdis - (char *)prec); pdbRecordType->papFldDes[13]->size=sizeof(prec->mlok); pdbRecordType->papFldDes[13]->offset=(short)((char *)&prec->mlok - (char *)prec); pdbRecordType->papFldDes[14]->size=sizeof(prec->mlis); pdbRecordType->papFldDes[14]->offset=(short)((char *)&prec->mlis - (char *)prec); pdbRecordType->papFldDes[15]->size=sizeof(prec->disp); pdbRecordType->papFldDes[15]->offset=(short)((char *)&prec->disp - (char *)prec); pdbRecordType->papFldDes[16]->size=sizeof(prec->proc); pdbRecordType->papFldDes[16]->offset=(short)((char *)&prec->proc - (char *)prec); pdbRecordType->papFldDes[17]->size=sizeof(prec->stat); pdbRecordType->papFldDes[17]->offset=(short)((char *)&prec->stat - (char *)prec); pdbRecordType->papFldDes[18]->size=sizeof(prec->sevr); pdbRecordType->papFldDes[18]->offset=(short)((char *)&prec->sevr - (char *)prec); pdbRecordType->papFldDes[19]->size=sizeof(prec->nsta); pdbRecordType->papFldDes[19]->offset=(short)((char *)&prec->nsta - (char *)prec); pdbRecordType->papFldDes[20]->size=sizeof(prec->nsev); pdbRecordType->papFldDes[20]->offset=(short)((char *)&prec->nsev - (char *)prec); pdbRecordType->papFldDes[21]->size=sizeof(prec->acks); pdbRecordType->papFldDes[21]->offset=(short)((char *)&prec->acks - (char *)prec); pdbRecordType->papFldDes[22]->size=sizeof(prec->ackt); pdbRecordType->papFldDes[22]->offset=(short)((char *)&prec->ackt - (char *)prec); pdbRecordType->papFldDes[23]->size=sizeof(prec->diss); pdbRecordType->papFldDes[23]->offset=(short)((char *)&prec->diss - (char *)prec); pdbRecordType->papFldDes[24]->size=sizeof(prec->lcnt); pdbRecordType->papFldDes[24]->offset=(short)((char *)&prec->lcnt - (char *)prec); pdbRecordType->papFldDes[25]->size=sizeof(prec->pact); pdbRecordType->papFldDes[25]->offset=(short)((char *)&prec->pact - (char *)prec); pdbRecordType->papFldDes[26]->size=sizeof(prec->putf); pdbRecordType->papFldDes[26]->offset=(short)((char *)&prec->putf - (char *)prec); pdbRecordType->papFldDes[27]->size=sizeof(prec->rpro); pdbRecordType->papFldDes[27]->offset=(short)((char *)&prec->rpro - (char *)prec); pdbRecordType->papFldDes[28]->size=sizeof(prec->asp); pdbRecordType->papFldDes[28]->offset=(short)((char *)&prec->asp - (char *)prec); pdbRecordType->papFldDes[29]->size=sizeof(prec->ppn); pdbRecordType->papFldDes[29]->offset=(short)((char *)&prec->ppn - (char *)prec); pdbRecordType->papFldDes[30]->size=sizeof(prec->ppnr); pdbRecordType->papFldDes[30]->offset=(short)((char *)&prec->ppnr - (char *)prec); pdbRecordType->papFldDes[31]->size=sizeof(prec->spvt); pdbRecordType->papFldDes[31]->offset=(short)((char *)&prec->spvt - (char *)prec); pdbRecordType->papFldDes[32]->size=sizeof(prec->rset); pdbRecordType->papFldDes[32]->offset=(short)((char *)&prec->rset - (char *)prec); pdbRecordType->papFldDes[33]->size=sizeof(prec->dset); pdbRecordType->papFldDes[33]->offset=(short)((char *)&prec->dset - (char *)prec); pdbRecordType->papFldDes[34]->size=sizeof(prec->dpvt); pdbRecordType->papFldDes[34]->offset=(short)((char *)&prec->dpvt - (char *)prec); pdbRecordType->papFldDes[35]->size=sizeof(prec->rdes); pdbRecordType->papFldDes[35]->offset=(short)((char *)&prec->rdes - (char *)prec); pdbRecordType->papFldDes[36]->size=sizeof(prec->lset); pdbRecordType->papFldDes[36]->offset=(short)((char *)&prec->lset - (char *)prec); pdbRecordType->papFldDes[37]->size=sizeof(prec->prio); pdbRecordType->papFldDes[37]->offset=(short)((char *)&prec->prio - (char *)prec); pdbRecordType->papFldDes[38]->size=sizeof(prec->tpro); pdbRecordType->papFldDes[38]->offset=(short)((char *)&prec->tpro - (char *)prec); pdbRecordType->papFldDes[39]->size=sizeof(prec->bkpt); pdbRecordType->papFldDes[39]->offset=(short)((char *)&prec->bkpt - (char *)prec); pdbRecordType->papFldDes[40]->size=sizeof(prec->udf); pdbRecordType->papFldDes[40]->offset=(short)((char *)&prec->udf - (char *)prec); pdbRecordType->papFldDes[41]->size=sizeof(prec->time); pdbRecordType->papFldDes[41]->offset=(short)((char *)&prec->time - (char *)prec); pdbRecordType->papFldDes[42]->size=sizeof(prec->flnk); pdbRecordType->papFldDes[42]->offset=(short)((char *)&prec->flnk - (char *)prec); pdbRecordType->papFldDes[43]->size=sizeof(prec->val); pdbRecordType->papFldDes[43]->offset=(short)((char *)&prec->val - (char *)prec); pdbRecordType->papFldDes[44]->size=sizeof(prec->nobt); pdbRecordType->papFldDes[44]->offset=(short)((char *)&prec->nobt - (char *)prec); pdbRecordType->papFldDes[45]->size=sizeof(prec->inp); pdbRecordType->papFldDes[45]->offset=(short)((char *)&prec->inp - (char *)prec); pdbRecordType->papFldDes[46]->size=sizeof(prec->rval); pdbRecordType->papFldDes[46]->offset=(short)((char *)&prec->rval - (char *)prec); pdbRecordType->papFldDes[47]->size=sizeof(prec->oraw); pdbRecordType->papFldDes[47]->offset=(short)((char *)&prec->oraw - (char *)prec); pdbRecordType->papFldDes[48]->size=sizeof(prec->mask); pdbRecordType->papFldDes[48]->offset=(short)((char *)&prec->mask - (char *)prec); pdbRecordType->papFldDes[49]->size=sizeof(prec->mlst); pdbRecordType->papFldDes[49]->offset=(short)((char *)&prec->mlst - (char *)prec); pdbRecordType->papFldDes[50]->size=sizeof(prec->lalm); pdbRecordType->papFldDes[50]->offset=(short)((char *)&prec->lalm - (char *)prec); pdbRecordType->papFldDes[51]->size=sizeof(prec->sdef); pdbRecordType->papFldDes[51]->offset=(short)((char *)&prec->sdef - (char *)prec); pdbRecordType->papFldDes[52]->size=sizeof(prec->shft); pdbRecordType->papFldDes[52]->offset=(short)((char *)&prec->shft - (char *)prec); pdbRecordType->papFldDes[53]->size=sizeof(prec->siol); pdbRecordType->papFldDes[53]->offset=(short)((char *)&prec->siol - (char *)prec); pdbRecordType->papFldDes[54]->size=sizeof(prec->sval); pdbRecordType->papFldDes[54]->offset=(short)((char *)&prec->sval - (char *)prec); pdbRecordType->papFldDes[55]->size=sizeof(prec->siml); pdbRecordType->papFldDes[55]->offset=(short)((char *)&prec->siml - (char *)prec); pdbRecordType->papFldDes[56]->size=sizeof(prec->simm); pdbRecordType->papFldDes[56]->offset=(short)((char *)&prec->simm - (char *)prec); pdbRecordType->papFldDes[57]->size=sizeof(prec->sims); pdbRecordType->papFldDes[57]->offset=(short)((char *)&prec->sims - (char *)prec); pdbRecordType->papFldDes[58]->size=sizeof(prec->b0); pdbRecordType->papFldDes[58]->offset=(short)((char *)&prec->b0 - (char *)prec); pdbRecordType->papFldDes[59]->size=sizeof(prec->b1); pdbRecordType->papFldDes[59]->offset=(short)((char *)&prec->b1 - (char *)prec); pdbRecordType->papFldDes[60]->size=sizeof(prec->b2); pdbRecordType->papFldDes[60]->offset=(short)((char *)&prec->b2 - (char *)prec); pdbRecordType->papFldDes[61]->size=sizeof(prec->b3); pdbRecordType->papFldDes[61]->offset=(short)((char *)&prec->b3 - (char *)prec); pdbRecordType->papFldDes[62]->size=sizeof(prec->b4); pdbRecordType->papFldDes[62]->offset=(short)((char *)&prec->b4 - (char *)prec); pdbRecordType->papFldDes[63]->size=sizeof(prec->b5); pdbRecordType->papFldDes[63]->offset=(short)((char *)&prec->b5 - (char *)prec); pdbRecordType->papFldDes[64]->size=sizeof(prec->b6); pdbRecordType->papFldDes[64]->offset=(short)((char *)&prec->b6 - (char *)prec); pdbRecordType->papFldDes[65]->size=sizeof(prec->b7); pdbRecordType->papFldDes[65]->offset=(short)((char *)&prec->b7 - (char *)prec); pdbRecordType->papFldDes[66]->size=sizeof(prec->b8); pdbRecordType->papFldDes[66]->offset=(short)((char *)&prec->b8 - (char *)prec); pdbRecordType->papFldDes[67]->size=sizeof(prec->b9); pdbRecordType->papFldDes[67]->offset=(short)((char *)&prec->b9 - (char *)prec); pdbRecordType->papFldDes[68]->size=sizeof(prec->ba); pdbRecordType->papFldDes[68]->offset=(short)((char *)&prec->ba - (char *)prec); pdbRecordType->papFldDes[69]->size=sizeof(prec->bb); pdbRecordType->papFldDes[69]->offset=(short)((char *)&prec->bb - (char *)prec); pdbRecordType->papFldDes[70]->size=sizeof(prec->bc); pdbRecordType->papFldDes[70]->offset=(short)((char *)&prec->bc - (char *)prec); pdbRecordType->papFldDes[71]->size=sizeof(prec->bd); pdbRecordType->papFldDes[71]->offset=(short)((char *)&prec->bd - (char *)prec); pdbRecordType->papFldDes[72]->size=sizeof(prec->be); pdbRecordType->papFldDes[72]->offset=(short)((char *)&prec->be - (char *)prec); pdbRecordType->papFldDes[73]->size=sizeof(prec->bf); pdbRecordType->papFldDes[73]->offset=(short)((char *)&prec->bf - (char *)prec); pdbRecordType->papFldDes[74]->size=sizeof(prec->b0st); pdbRecordType->papFldDes[74]->offset=(short)((char *)&prec->b0st - (char *)prec); pdbRecordType->papFldDes[75]->size=sizeof(prec->b1st); pdbRecordType->papFldDes[75]->offset=(short)((char *)&prec->b1st - (char *)prec); pdbRecordType->papFldDes[76]->size=sizeof(prec->b2st); pdbRecordType->papFldDes[76]->offset=(short)((char *)&prec->b2st - (char *)prec); pdbRecordType->papFldDes[77]->size=sizeof(prec->b3st); pdbRecordType->papFldDes[77]->offset=(short)((char *)&prec->b3st - (char *)prec); pdbRecordType->papFldDes[78]->size=sizeof(prec->b4st); pdbRecordType->papFldDes[78]->offset=(short)((char *)&prec->b4st - (char *)prec); pdbRecordType->papFldDes[79]->size=sizeof(prec->b5st); pdbRecordType->papFldDes[79]->offset=(short)((char *)&prec->b5st - (char *)prec); pdbRecordType->papFldDes[80]->size=sizeof(prec->b6st); pdbRecordType->papFldDes[80]->offset=(short)((char *)&prec->b6st - (char *)prec); pdbRecordType->papFldDes[81]->size=sizeof(prec->b7st); pdbRecordType->papFldDes[81]->offset=(short)((char *)&prec->b7st - (char *)prec); pdbRecordType->papFldDes[82]->size=sizeof(prec->b8st); pdbRecordType->papFldDes[82]->offset=(short)((char *)&prec->b8st - (char *)prec); pdbRecordType->papFldDes[83]->size=sizeof(prec->b9st); pdbRecordType->papFldDes[83]->offset=(short)((char *)&prec->b9st - (char *)prec); pdbRecordType->papFldDes[84]->size=sizeof(prec->bast); pdbRecordType->papFldDes[84]->offset=(short)((char *)&prec->bast - (char *)prec); pdbRecordType->papFldDes[85]->size=sizeof(prec->bbst); pdbRecordType->papFldDes[85]->offset=(short)((char *)&prec->bbst - (char *)prec); pdbRecordType->papFldDes[86]->size=sizeof(prec->bcst); pdbRecordType->papFldDes[86]->offset=(short)((char *)&prec->bcst - (char *)prec); pdbRecordType->papFldDes[87]->size=sizeof(prec->bdst); pdbRecordType->papFldDes[87]->offset=(short)((char *)&prec->bdst - (char *)prec); pdbRecordType->papFldDes[88]->size=sizeof(prec->best); pdbRecordType->papFldDes[88]->offset=(short)((char *)&prec->best - (char *)prec); pdbRecordType->papFldDes[89]->size=sizeof(prec->bfst); pdbRecordType->papFldDes[89]->offset=(short)((char *)&prec->bfst - (char *)prec); pdbRecordType->papFldDes[90]->size=sizeof(prec->b0zsv); pdbRecordType->papFldDes[90]->offset=(short)((char* )&prec->b0zsv - (char *)prec); pdbRecordType->papFldDes[91]->size=sizeof(prec->b1zsv); pdbRecordType->papFldDes[91]->offset=(short)((char* )&prec->b1zsv - (char *)prec); pdbRecordType->papFldDes[92]->size=sizeof(prec->b2zsv); pdbRecordType->papFldDes[92]->offset=(short)((char* )&prec->b2zsv - (char *)prec); pdbRecordType->papFldDes[93]->size=sizeof(prec->b3zsv); pdbRecordType->papFldDes[93]->offset=(short)((char* )&prec->b3zsv - (char *)prec); pdbRecordType->papFldDes[94]->size=sizeof(prec->b4zsv); pdbRecordType->papFldDes[94]->offset=(short)((char* )&prec->b4zsv - (char *)prec); pdbRecordType->papFldDes[95]->size=sizeof(prec->b5zsv); pdbRecordType->papFldDes[95]->offset=(short)((char* )&prec->b5zsv - (char *)prec); pdbRecordType->papFldDes[96]->size=sizeof(prec->b6zsv); pdbRecordType->papFldDes[96]->offset=(short)((char* )&prec->b6zsv - (char *)prec); pdbRecordType->papFldDes[97]->size=sizeof(prec->b7zsv); pdbRecordType->papFldDes[97]->offset=(short)((char* )&prec->b7zsv - (char *)prec); pdbRecordType->papFldDes[98]->size=sizeof(prec->b8zsv); pdbRecordType->papFldDes[98]->offset=(short)((char* )&prec->b8zsv - (char *)prec); pdbRecordType->papFldDes[99]->size=sizeof(prec->b9zsv); pdbRecordType->papFldDes[99]->offset=(short)((char* )&prec->b9zsv - (char *)prec); pdbRecordType->papFldDes[100]->size=sizeof(prec->bazsv); pdbRecordType->papFldDes[100]->offset=(short)((char* )&prec->bazsv - (char *)prec); pdbRecordType->papFldDes[101]->size=sizeof(prec->bbzsv); pdbRecordType->papFldDes[101]->offset=(short)((char* )&prec->bbzsv - (char *)prec); pdbRecordType->papFldDes[102]->size=sizeof(prec->bczsv); pdbRecordType->papFldDes[102]->offset=(short)((char* )&prec->bczsv - (char *)prec); pdbRecordType->papFldDes[103]->size=sizeof(prec->bdzsv); pdbRecordType->papFldDes[103]->offset=(short)((char* )&prec->bdzsv - (char *)prec); pdbRecordType->papFldDes[104]->size=sizeof(prec->bezsv); pdbRecordType->papFldDes[104]->offset=(short)((char* )&prec->bezsv - (char *)prec); pdbRecordType->papFldDes[105]->size=sizeof(prec->bfzsv); pdbRecordType->papFldDes[105]->offset=(short)((char* )&prec->bfzsv - (char *)prec); pdbRecordType->papFldDes[106]->size=sizeof(prec->b0osv); pdbRecordType->papFldDes[106]->offset=(short)((char* )&prec->b0osv - (char *)prec); pdbRecordType->papFldDes[107]->size=sizeof(prec->b1osv); pdbRecordType->papFldDes[107]->offset=(short)((char* )&prec->b1osv - (char *)prec); pdbRecordType->papFldDes[108]->size=sizeof(prec->b2osv); pdbRecordType->papFldDes[108]->offset=(short)((char* )&prec->b2osv - (char *)prec); pdbRecordType->papFldDes[109]->size=sizeof(prec->b3osv); pdbRecordType->papFldDes[109]->offset=(short)((char* )&prec->b3osv - (char *)prec); pdbRecordType->papFldDes[110]->size=sizeof(prec->b4osv); pdbRecordType->papFldDes[110]->offset=(short)((char* )&prec->b4osv - (char *)prec); pdbRecordType->papFldDes[111]->size=sizeof(prec->b5osv); pdbRecordType->papFldDes[111]->offset=(short)((char* )&prec->b5osv - (char *)prec); pdbRecordType->papFldDes[112]->size=sizeof(prec->b6osv); pdbRecordType->papFldDes[112]->offset=(short)((char* )&prec->b6osv - (char *)prec); pdbRecordType->papFldDes[113]->size=sizeof(prec->b7osv); pdbRecordType->papFldDes[113]->offset=(short)((char* )&prec->b7osv - (char *)prec); pdbRecordType->papFldDes[114]->size=sizeof(prec->b8osv); pdbRecordType->papFldDes[114]->offset=(short)((char* )&prec->b8osv - (char *)prec); pdbRecordType->papFldDes[115]->size=sizeof(prec->b9osv); pdbRecordType->papFldDes[115]->offset=(short)((char* )&prec->b9osv - (char *)prec); pdbRecordType->papFldDes[116]->size=sizeof(prec->baosv); pdbRecordType->papFldDes[116]->offset=(short)((char* )&prec->baosv - (char *)prec); pdbRecordType->papFldDes[117]->size=sizeof(prec->bbosv); pdbRecordType->papFldDes[117]->offset=(short)((char* )&prec->bbosv - (char *)prec); pdbRecordType->papFldDes[118]->size=sizeof(prec->bcosv); pdbRecordType->papFldDes[118]->offset=(short)((char* )&prec->bcosv - (char *)prec); pdbRecordType->papFldDes[119]->size=sizeof(prec->bdosv); pdbRecordType->papFldDes[119]->offset=(short)((char* )&prec->bdosv - (char *)prec); pdbRecordType->papFldDes[120]->size=sizeof(prec->beosv); pdbRecordType->papFldDes[120]->offset=(short)((char* )&prec->beosv - (char *)prec); pdbRecordType->papFldDes[121]->size=sizeof(prec->bfosv); pdbRecordType->papFldDes[121]->offset=(short)((char* )&prec->bfosv - (char *)prec); pdbRecordType->papFldDes[122]->size=sizeof(prec->bas); pdbRecordType->papFldDes[122]->offset=(short)((char* )&prec->bas - (char *)prec); pdbRecordType->rec_size = sizeof(*prec); return(0); } epicsExportRegistrar(mbbi2RecordSizeOffset); #ifdef __cplusplus } #endif #endif /*GEN_SIZE_OFFSET*/
ANJ, 04 Oct 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
