Although a minor release, it has packed in a lot of changes. Two of them are backwards incompatible:
1. The “dynamicAttribute” and “limits” properties, if used in qml designer, created alias properties
like “dynamicAttribute_channel”, “limits_preSrc”. This was used as a workaround to use complicate properties
in qml designer. In the version the qml designer support has been implemented properly so that this workaround
is removed. This means that these properties have to replaced, e.g.
dynamicAttribute_channel -> dynamicAttribute.channel
limits_preSrc -> limits.preSrc
2. ADLViewer is renamed to Viewer, because it gets support of extra display formats like EDL and UI.
See the full list of changes here, http://epics.web.psi.ch/software/CSDataQuick/docs/releases.html
The binary packages can still be found here http://epics.web.psi.ch/software/CSDataQuick. The conda packages are
also in the paulscherrerinstiute channel, but the linux-64 platform is still missing because the conda qt-5.9
now only works on rhel/cento 7.
Best
Xiaoqiang
Re: Stream device does not recognize a custom record type Dirk Zimoch
RE: Stream device does not recognize a custom record type Abdalla Ahmad
<2018>
ADPicam problem Jörn Dreyer
<2018>
