1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Questions about install
To: [email protected]
Date: Wed, 10 Oct 2018 16:19:21 +0200
Hi Richard,
If $(TOP) is not equal to $(INSTALL_LOCATION), you cannot see startup directory in 3.15.5 and 7.0.1.1. From our environment, we create that directory, and copy EpicsHostArch.pl file into it.
From 3.15.6-rc1, EpicsHostArch will be in startup directory if $(TOP) is equal to $(INSTALL_LOCATION). However, if $(TOP) is not equal to $(INSTALL_LOCATION), we cannot see "startup" path in $(INSTALL_LOCATION). However, EpicsHostArch.pl file will be copied into
$(EPICS_BASE)/lib/perl path.
  HTH,
  Han
On 10/10/18 4:12 PM, Lucock, Richard M wrote:
I have just built base-3.15.5, with INSTALL_LOCATION in
config/CONFIG_SITE set to a different directory than my source
directory (call it /path/base). That is the only change that I made to
the epics files before running make.
I then tried to build a test application (that is known to work),
having set EPICS_BASE in configure/RELEASE to /path/base. The build
failed, because it couldn't find the startup directory. There is a
startup directory in source directory, but nothing got created in my
install location.  Copying the startup directory from source to
install by hand fixed the problem, and the test app ran.
I am unsure what I might have done wrong when building the epics
installation. Any suggestions ? (I am working on a linux platform).
     Richard
Re: Questions about install Lucock, Richard M
Prev: Questions about install Lucock, Richard M
Next: Re: Questions about install Lucock, Richard M
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 10 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
