1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Camera Recommendations [SEC=UNCLASSIFIED]
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 16 Oct 2018 22:01:21 +0000
Hi Mark,
Thank you for recommendation, however, we have tried using BFLY-PGE-13S2M-CS with adSpinnaker on Ubuntu 16 and FL3-GE-13S2M-CS with adPontGrey on Centos 7 but both of them "freeze" after running smoothly for some time. They become unresponsive and an IOC reboot is required in some cases even power cycle of the camera.  We're running them at toughly 1 Hz so they should get overworked.
At this stage we're looking at potential alternatives or any kind of advice if someone has had similar experience with those cameras?
Cheers,
Andraz
-----Original Message-----
Sent: Tuesday, October 16, 2018 10:45 PM
To: POZAR, Andraz <[email protected]>; [email protected]
Subject: Re: Camera Recommendations [SEC=UNCLASSIFIED]
Hi Andraz,
The Point Grey Blackfly cameras will meet your specifications:
https://www.ptgrey.com/blackfly-gige-poe-cameras
Here are 2 examples:
BFLY-PGE-13S2M-CS
1/3 inch, global shutter, 1288x964 pixels
3.75 micron pixels
66% QE, 11 e- read noise, 9339 e- full well
58 dB dynamic range
30 FPS
POE
$345
The following model has significantly better QE, read noise, and dynamic range in a somewhat larger format:
BFLY-PGE-23S6M-C
1/1.2" sensor, global shutter, 1920x1200 pixels
5.86 micron pixels
80% QE, 7 e- read noise, 33105 e- full well
73 dB dynamic range
41 FPS
POE
$495
Either camera can be used with 3 areaDetector drivers:
ADPointGrey (Windows, Linux RHEL 7 or higher) aravisGigE (Linux, most any version) ADSpinnaker (Windows, Linux Ubuntu 16 and higher)
From: [email protected] <[email protected]> on behalf of POZAR, Andraz <[email protected]>
Sent: Tuesday, October 16, 2018 12:44 AM
To: [email protected]
Subject: Camera Recommendations [SEC=UNCLASSIFIED]
Hi all,
We're looking into replacing our old Firewire cameras with Ethernet ones and we'd be interested in any suggestions and experiences you have had with different camera models.
Some requirements:
-          1/3 inch, global shutter, mono sensor at roughly 1300 x 900 resolution
-          Good quantum efficiency and low noise
-          Roughly 4 microns pixel size
-          Ethernet
-          Preferably POE
-          areaDetector support
Cheers,
Andraz Pozar
Controls Engineer
Australian Synchrotron
Tel
Email
Web
+61 3 8540 5387
[email protected]<mailto:[email protected]>
www.ansto.gov.au<http://www.ansto.gov.au/>
[fb]<http://www.facebook.com/DiscoverANSTO> [tw] <https://twitter.com/ANSTO>  [ln] <http://www.linkedin.com/company/ansto>  [yt] <http://www.youtube.com/user/ANSTOVideos>
[ansto]
Important: This transmission is intended only for the use of the intended addressee. It is confidential to the intended addressee and may contain privileged information and or copyright material. If this email is not intended for your attention, any use, printing, storage, reproduction or further disclosure of this communication (including all attachments) is strictly forbidden. If you have received this transmission in error, please notify me by telephone or email and immediately delete all copies of this transmission as well as any attachments.
RE: Camera Recommendations [SEC=UNCLASSIFIED] [email protected]
RE: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
Re: Camera Recommendations [SEC=UNCLASSIFIED] Pearson, Matthew R. via Tech-talk
Camera Recommendations [SEC=UNCLASSIFIED] POZAR, Andraz
Re: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
Prev: Control System Studio run time file NAJM US SAQIB
Next: EPICS Collaboration Meeting Registrations Closing Date [SEC=UNCLASSIFIED] POZAR, Andraz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
Next: RE: Camera Recommendations [SEC=UNCLASSIFIED] [email protected]
ANJ, 17 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
