1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Possible duplicate writeInt32 call when using Asyn
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 25 Oct 2018 15:06:33 +0000
Ah OK thanks.  I'm using a DLS specific 1-6-1 so the problem could be originating from there.  I'll take a look at that newer version.
Thanks again, Alan
Sent: 25 October 2018 16:00:18
To: Greer, Alan (OBS,RAL,DIA); [email protected]
Hi Alan,
What version of the bust module are you using?  There were a number of fixes to the busy record logic in R1-7.
From: [email protected] <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Thursday, October 25, 2018 9:45 AM
To: [email protected]
Subject: Possible duplicate writeInt32 call when using Asyn
Hello,
I have an IOC with a busy record connected to an asyn parameter within an area detector application.  If I perform multiple caputs to the record occasionally I appear to get two writeInt32 calls in quick succession.  I'm performing the caput calls from a script to ensure I've eliminated any involvement from a GUI.
Below shows the output from asynTrace when this occurs:
2018/10/25 15:12:52.238 ODN.OD addr 0 queueRequest priority 0 not lockHolder
2018/10/25 15:12:52.238 asynManager::portThread port=ODN.OD callback
2018/10/25 15:12:52.238 Param[ODIN_HDF5_WRITE]::put<bool>: 1
2018/10/25 15:12:52.238 Param[ODIN_HDF5_WRITE]::fetch<int>: 0
2018/10/25 15:12:52.238 Param[ODIN_HDF5_WRITE]::basePut: 'true'
2018/10/25 15:12:52.241 OdinDataDriver:writeInt32: function=100, value=1
2018/10/25 15:12:52.241 EXCALIBUR:OD:Capture devBusyAsyn::interruptCallback pr->val=1, new value=1
2018/10/25 15:12:52.241 EXCALIBUR:OD:Capture devBusyAsyn::processCallback value 1
2018/10/25 15:12:52.241 ODN.OD addr 0 queueRequest priority 0 not lockHolder
2018/10/25 15:12:52.241 asynManager::portThread port=ODN.OD callback
2018/10/25 15:12:52.241 Param[ODIN_HDF5_WRITE]::put<bool>: 1
2018/10/25 15:12:52.241 Param[ODIN_HDF5_WRITE]::fetch<int>: 0
2018/10/25 15:12:52.241 Param[ODIN_HDF5_WRITE]::basePut: 'true'
2018/10/25 15:12:52.245 OdinDataDriver:writeInt32: function=100, value=1
2018/10/25 15:12:52.245 EXCALIBUR:OD:Capture devBusyAsyn::processCallback value 1
This is intermittent and the rate of occurrence is altered by turning on the asynTrace debug.
I'm using
asyn 4-31
ADCore 2-6
EPICS R3.14.12.3
RHEL 6
Is this an issue that anyone has noticed before?  I can see that many of our detector application implementations would silently ignore this but in this application we are queueing acquisitions and so we observe in the queue a duplicate request.
Thanks, Alan
Possible duplicate writeInt32 call when using Asyn [email protected]
Re: Possible duplicate writeInt32 call when using Asyn Mark Rivers
Prev: Re: Possible duplicate writeInt32 call when using Asyn Mark Rivers
Next: Re: DM recommedation. J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Next: calling EIPCS' Raspberry Pi users Chew Eh Piew
ANJ, 25 Oct 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
