Hi Michael,
the #132 solved the pvlist issue. Thanks for that.
The pvget segmentation fault is still existing (It might be that the reason is on the server side, its my famous tinkered rtems-epics stuff)
And as usual, I need your help again to get deeper into this.
I have:
epics@kannsein:~$ gdb pvget core
GNU gdb (Ubuntu 7.11.1-0ubuntu1~16.5) 7.11.1
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from pvget...done.
warning: exec file is newer than core file.
[New LWP 53453]
[New LWP 53452]
[New LWP 53444]
[New LWP 53450]
[New LWP 53446]
[New LWP 53451]
[New LWP 53447]
[New LWP 53454]
[New LWP 53448]
[New LWP 53449]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `pvget CRYAFM:struckNTNDArray'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007f57be8fcad7 in std::tr1::__shared_ptr<unsigned short, (__gnu_cxx::_Lock_policy)2>::__shared_ptr (this=<optimized out>)
at /usr/include/c++/5/tr1/shared_ptr.h:547
547 : _M_ptr(0), _M_refcount() // never throws
[Current thread is 1 (Thread 0x7f57bb9fe700 (LWP 53453))]
(gdb) thread apply all backtrace
Thread 10 (Thread 0x7f57bbc02700 (LWP 53449)):
#0 0x00007f57bdd58333 in recvfrom () at ../sysdeps/unix/syscall-template.S:84
#1 0x00007f57bec730c7 in recvfrom (__addr_len=0x7f57bbc01d48, __addr=0x7f57bbc01d60, __flags=0, __n=65487, __buf=0x145a098,
__fd=<optimized out>) at /usr/include/x86_64-linux-gnu/bits/socket2.h:76
#2 epics::pvAccess::BlockingUDPTransport::run (this=0x1419bd0) at ../../src/remote/blockingUDPTransport.cpp:223
#3 0x00007f57be5edc99 in epicsMutexOsiInit () at ../../src/osi/epicsMutex.cpp:81
#4 0xffffffffffffffff in ?? ()
#5 0xffffffffffffffff in ?? ()
#6 0xffffffffffffffff in ?? ()
#7 0xffffffffffffffff in ?? ()
#8 0xffffffffffffffff in ?? ()
#9 0xffffffffffffffff in ?? ()
#10 0xffffffffffffffff in ?? ()
#11 0xffffffffffffffff in ?? ()
#12 0xffffffffffffffff in ?? ()
#13 0xffffffffffffffff in ?? ()
#14 0xffffffffffffffff in ?? ()
#15 0x0000000000000000 in ?? ()
Thread 9 (Thread 0x7f57bf2a0700 (LWP 53448)):
#1 0x00007f57bec730c7 in recvfrom (__addr_len=0x7f57bf29fd48, __addr=0x7f57bf29fd60, __flags=0, __n=65487, __buf=0x143a0c8,
#2 epics::pvAccess::BlockingUDPTransport::run (this=0x14198c0) at ../../src/remote/blockingUDPTransport.cpp:223
Thread 8 (Thread 0x7f57bb7fd700 (LWP 53454)):
#0 pthread_cond_wait@@GLIBC_2.3.2 () at ../sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S:185
#1 0x00007f57be5f6eeb in osiSockDiscoverBroadcastAddresses (pList=0x7f57ac01a60c, socket=128, pMatchAddr=0x9)
at ../../src/osi/os/default/osdNetIntf.c:81
#2 0x7f276cf0b2fc3d00 in ?? ()
---Type <return> to continue, or q <return> to quit---
#3 0x0000000000000001 in ?? ()
#4 0x00007f57ac0009d0 in ?? ()
#5 0x00007f57bec82c50 in epics::pvData::ByteBuffer::put (count=140014784597424, src_offset=0,
src=0x7f57bed1e138 <epics::pvAccess::detail::PADDING_BYTES> "\377\377\377\377\377\377\377\377", this=<optimized out>)
at /home/epics/BASE/base-7.0/include/pv/byteBuffer.h:451
#6 epics::pvAccess::detail::AbstractCodec::alignBuffer (this=0x7f57ac000a88, alignment=<optimized out>) at ../../src/remote/codec.cpp:582
#7 0x00007f57ac000b48 in ?? ()
#8 0x00007f57bec8759a in epics::pvAccess::detail::BlockingTCPTransportCodec::sendThread (this=0x7f57bf31fd6f)
at ../../src/remote/codec.cpp:1166
#9 0x00007f57be5edc99 in epicsMutexOsiInit () at ../../src/osi/epicsMutex.cpp:81
#15 0xffffffffffffffff in ?? ()
#16 0xffffffffffffffff in ?? ()
#17 0xffffffffffffffff in ?? ()
#18 0xffffffffffffffff in ?? ()
#19 0xffffffffffffffff in ?? ()
#20 0xffffffffffffffff in ?? ()
#21 0x0000000000000000 in ?? ()
Thread 7 (Thread 0x7f57bf321700 (LWP 53447)):
#1 0x00007f57bec730c7 in recvfrom (__addr_len=0x7f57bf320d48, __addr=0x7f57bf320d60, __flags=0, __n=65487, __buf=0x141a0f8,
#2 epics::pvAccess::BlockingUDPTransport::run (this=0x1419050) at ../../src/remote/blockingUDPTransport.cpp:223
Thread 6 (Thread 0x7f57bbb00700 (LWP 53451)):
#1 0x00007f57bec730c7 in recvfrom (__addr_len=0x7f57bbaffd48, __addr=0x7f57bbaffd60, __flags=0, __n=65487, __buf=0x149ad78,
#2 epics::pvAccess::BlockingUDPTransport::run (this=0x149ab70) at ../../src/remote/blockingUDPTransport.cpp:223
Thread 5 (Thread 0x7f57bf3a2700 (LWP 53446)):
#0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:225
#1 0x00007f57be5f7099 in epicsMessageQueueCreate (capacity=21068572, maxMessageSize=393) at ../../src/osi/os/default/osdMessageQueue.cpp:74
#2 0x0000000000406470 in __gxx_personality_v0@plt ()
#3 0x3fcbc332ab5f2510 in ?? ()
#4 0x000000005bd037ab in ?? ()
#5 0x00000000042f7132 in ?? ()
#6 0x00007f57b4000930 in ?? ()
#7 0x7f276cf0b2fc3d00 in ?? ()
#8 0x0000000001417930 in ?? ()
#9 0x0000000001417938 in ?? ()
#10 0x0000000001418fc0 in ?? ()
#11 0x00007f57be899aa5 in epics::pvData::Timer::run (this=0x1417b1c) at ../../src/misc/timer.cpp:84
#12 0x0000000001417930 in ?? ()
#13 0x0000000001417938 in ?? ()
#14 0x0000000001418fc0 in ?? ()
#15 0x00007f57be89a86c in std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_dispose (this=0x30)
at /usr/include/c++/5/bits/basic_string.h:179
#16 std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string (this=0x30, __in_chrg=<optimized out>)
at /usr/include/c++/5/bits/basic_string.h:543
#17 epics::pvData::Status::~Status (this=0x0, __in_chrg=<optimized out>) at ../../src/misc/pv/status.h:68
#18 epics::pvData::Status::~Status (this=0x0, __in_chrg=<optimized out>) at ../../src/misc/pv/status.h:68
#19 0x00007f57bf3a1dc0 in ?? ()
#20 0x00007f57bf3a1de0 in ?? ()
#21 0x00007f57bf3a1dd0 in ?? ()
#22 0x0000000036319a2a in ?? ()
#23 0x0000000032dc970a in ?? ()
#24 0x0000000036319a29 in ?? ()
#25 0x000000003ab9772f in ?? ()
#26 0x0000000001418760 in ?? ()
#27 0x0000000001418fc0 in ?? ()
#28 0x0000000036319a2b in ?? ()
#29 0x00000000042f590e in ?? ()
#30 0x0000000036319a2b in ?? ()
#31 0x00000000042f590e in ?? ()
#32 0x0000000001417968 in ?? ()
#33 0x7f276cf0b2fc3d00 in ?? ()
#34 0x0000000001417968 in ?? ()
#35 0x0000000001417968 in ?? ()
#36 0x0000000000000000 in ?? ()
Thread 4 (Thread 0x7f57bbb81700 (LWP 53450)):
#1 0x00007f57bec730c7 in recvfrom (__addr_len=0x7f57bbb80d48, __addr=0x7f57bbb80d60, __flags=0, __n=65487, __buf=0x147aa58,
#2 epics::pvAccess::BlockingUDPTransport::run (this=0x147a850) at ../../src/remote/blockingUDPTransport.cpp:223
Thread 3 (Thread 0x7f57bf3a4740 (LWP 53444)):
#1 0x00007f57be5f7099 in epicsMessageQueueCreate (capacity=21056140, maxMessageSize=393) at ../../src/osi/os/default/osdMessageQueue.cpp:74
#2 0x00000000014152e0 in ?? ()
#3 0x4008000000000000 in ?? ()
#4 0x000000005bd037ac in ?? ()
#5 0x000000003abb2474 in ?? ()
#6 0x0000000000000000 in ?? ()
Thread 2 (Thread 0x7f57bba7f700 (LWP 53452)):
#1 0x00007f57bec730c7 in recvfrom (__addr_len=0x7f57bba7ed48, __addr=0x7f57bba7ed60, __flags=0, __n=65487, __buf=0x14bb928,
#2 epics::pvAccess::BlockingUDPTransport::run (this=0x14bb720) at ../../src/remote/blockingUDPTransport.cpp:223
Thread 1 (Thread 0x7f57bb9fe700 (LWP 53453)):
#1 std::tr1::shared_ptr<unsigned short>::shared_ptr (this=<optimized out>) at /usr/include/c++/5/tr1/shared_ptr.h:990
#2 epics::pvData::detail::shared_vector_base<unsigned short>::shared_vector_base (O=..., this=<optimized out>)
at ../../src/misc/pv/sharedVector.h:160
#3 epics::pvData::shared_vector<unsigned short, void>::shared_vector (t=..., O=..., this=<optimized out>)
at ../../src/misc/pv/sharedVector.h:396
#4 epics::pvData::thaw<epics::pvData::shared_vector<unsigned short const, void> > (src=...) at ../../src/misc/pv/sharedVector.h:903
#5 epics::pvData::PVValueArray<unsigned short>::deserialize (this=0x7f57a4002c00, pbuffer=0x2d5, pcontrol=0x7f57ac0009d8)
at ../../src/factory/PVDataCreateFactory.cpp:225
#6 0x00007f57be8dbace in __gnu_cxx::__atomic_add_single (__val=<optimized out>, __mem=<optimized out>)
at /usr/include/c++/5/ext/atomicity.h:74
#7 __gnu_cxx::__atomic_add_dispatch (__val=<optimized out>, __mem=<optimized out>) at /usr/include/c++/5/ext/atomicity.h:98
#8 std::tr1::_Sp_counted_base<(__gnu_cxx::_Lock_policy)2>::_M_add_ref_copy (this=<optimized out>) at /usr/include/c++/5/tr1/shared_ptr.h:128
#9 std::tr1::__shared_count<(__gnu_cxx::_Lock_policy)2>::__shared_count (__r=..., this=<optimized out>)
at /usr/include/c++/5/tr1/shared_ptr.h:348
#10 std::tr1::__shared_ptr<epics::pvData::PVField const, (__gnu_cxx::_Lock_policy)2>::__shared_ptr<epics::pvData::PVField> (__r=...,
this=<optimized out>) at /usr/include/c++/5/tr1/shared_ptr.h:573
#11 std::tr1::shared_ptr<epics::pvData::PVField const>::shared_ptr<epics::pvData::PVField> (__r=..., this=<optimized out>)
at /usr/include/c++/5/tr1/shared_ptr.h:1003
#12 epics::pvData::PVUnion::get (this=<optimized out>) at ../pv/pvData.h:939
#13 epics::pvData::PVUnion::dumpValue (this=<optimized out>, o=...) at ../../src/factory/PVUnion.cpp:184
#14 0x00007f57ac0009d8 in ?? ()
#15 0x00000000014dc810 in ?? ()
#16 0x00000000014dc550 in ?? ()
#17 0x00007f57bb9fdaf0 in ?? ()
#18 0x00007f57ac000a18 in ?? ()
#19 0x00007f57bb9fdd20 in ?? ()
#20 0x00000000014dc648 in ?? ()
#21 0x0000000000000050 in ?? ()
#22 0x00007f57bec9d73c in (anonymous namespace)::ChannelGetImpl::normalResponse (this=0x7f57a4002ba0,
transport=std::tr1::shared_ptr (count 1314147887, weak 1920090435) 0x7f57beb9e868 <vtable for epics::pvData::BitSet+16>,
payloadBuffer=0x7f57be8d0cfd <epics::pvData::PVStructure::dumpValue(std::ostream&) const+189>, status=...)
at ../../src/remoteClient/clientContextImpl.cpp:653
#23 0x00007f57bec96978 in (anonymous namespace)::BaseRequestImpl::response (this=0x14dc550,
transport=std::tr1::shared_ptr (count 6, weak 1) 0x7f57ac0009d8, version=<optimized out>, payloadBuffer=0x7f57ac000a18)
at ../../src/remoteClient/clientContextImpl.cpp:294
#24 0x00007f57bec98aa2 in (anonymous namespace)::ResponseRequestHandler::handleResponse (this=<optimized out>, responseFrom=<optimized out>,
transport=std::tr1::shared_ptr (count 6, weak 1) 0x7f57ac0009d8, version=1 '\001', command=<optimized out>, payloadSize=<optimized out>,
payloadBuffer=0x7f57ac000a18) at ../../src/remoteClient/clientContextImpl.cpp:2502
#25 0x00007f57bec9574f in (anonymous namespace)::ClientResponseHandler::handleResponse (this=<optimized out>, responseFrom=<optimized out>,
transport=..., version=<optimized out>, command=<optimized out>, payloadSize=<optimized out>, payloadBuffer=0x7f57ac000a18)
at ../../src/remoteClient/clientContextImpl.cpp:3008
#26 0x00007f57bec879b5 in epics::pvAccess::detail::BlockingTCPTransportCodec::processApplicationMessage (this=0x7f57ac0009d0)
at ../../src/remote/pv/codec.h:352
#27 epics::pvAccess::detail::AbstractCodec::processReadNormal (this=0x7f57ac0009d0) at ../../src/remote/codec.cpp:224
#28 0x00007f57bec87e95 in epics::pvAccess::detail::AbstractCodec::processRead (this=this@entry=0x7f57ac0009d0)
at ../../src/remote/codec.cpp:128
#29 0x00007f57bec87faa in epics::pvAccess::detail::BlockingTCPTransportCodec::receiveThread (this=0x7f57ac0009d0)
at ../../src/remote/codec.cpp:1138
#30 0x00007f57be5edc99 in epicsMutexOsiInit () at ../../src/osi/epicsMutex.cpp:81
#31 0xffffffffffffffff in ?? ()
#32 0xffffffffffffffff in ?? ()
#33 0xffffffffffffffff in ?? ()
#34 0xffffffffffffffff in ?? ()
#35 0xffffffffffffffff in ?? ()
#36 0xffffffffffffffff in ?? ()
#37 0xffffffffffffffff in ?? ()
#38 0xffffffffffffffff in ?? ()
#39 0xffffffffffffffff in ?? ()
#40 0xffffffffffffffff in ?? ()
#41 0xffffffffffffffff in ?? ()
#42 0x0000000000000000 in ?? ()
(gdb)
Danke, Heinz
> On 25. Oct 2018, at 18:09, Michael Davidsaver <[email protected]> wrote:
> On 10/25/18 7:45 AM, Patrik Marschalik wrote:
>> Hi Michael,
>> the issue is even stranger.
>> We have a host with one network interface, starting a testServer in one
>> terminal and calling pvlist in another one shows nothing. pvlist
>> localhost works as expected. Do you have an idea what might be the
>> problem?
> At least in part #132 which is now fixed.
> https://github.com/epics-base/pvAccessCPP/issues/132
> Which revisions of the various modules are you building?
> Also, could you extract line numbers from the stack trace?
> 0x7fe7638179c5 isn't very meaningful :) Please run the following,
> replacing the addresses with those from a newer run if you have
> rebuilt the executables/libraries.
>> addr2line -e ./path/to/pvget 0x7fe7638179c5 0x7fe76234bfc6 0x7fe762345bfb
>> Thanks
>> Patrik
>> On Wed, Oct 24, 2018 at 09:37:29PM +0200, Heinz Junkes wrote:
>>> Hi Michael,
>>> this I got got today from Patrik once:
>>> *** Error in `pvget': munmap_chunk(): invalid pointer:
>>> 0x00007fe74e0a1010 ***
>>> ======= Backtrace: =========
>>> /lib/x86_64-linux-gnu/libc.so.6(+0x70bfb)[0x7fe762345bfb]
>>> /lib/x86_64-linux-gnu/libc.so.6(+0x76fc6)[0x7fe76234bfc6]
>>> /home/patrik/GITHUB/epics-base/epics-base/lib/linux-x86_64/libpvAccess.so.6.0.1(_ZN5epics8pvAccess6detail25BlockingTCPTransportCodecD2Ev+0x425)[0x7fe7638179c5]
>>> But there's a more general problem on our side.
>>> It has something to do with multiple networks? And I still haven't understood the impact of all the environments.
>>> Starting testserver:
>>> epics@kannsein:~$ testServer
>>> VERSION : pvAccess Server v6.0.1-SNAPSHOT
>>> PROVIDER_NAMES : local,
>>> BEACON_ADDR_LIST :
>>> AUTO_BEACON_ADDR_LIST : 1
>>> BEACON_PERIOD : 15
>>> BROADCAST_PORT : 5076
>>> SERVER_PORT : 5075
>>> RCV_BUFFER_SIZE : 16384
>>> IGNORE_ADDR_LIST:
>>> INTF_ADDR_LIST : 0.0.0.0
>>> On an other Terminal
>>> epics@kannsein:~/BASE/epics-base$ pvlist
>>> (no output)
>>> epics@kannsein:~/BASE/epics-base$ pvlist 141.14.133.59
>>> testADC
>>> testAggregate
>>> testBinaryCounter
>>> testCounter
>>> testHistogram
>>> testMP
>>> testNameValue
>>> testRandom
>>> testTable
>>> epics@kannsein:~/BASE/epics-base$ pvlist 10.20.30.1
>>> testADC
>>> testAggregate
>>> testBinaryCounter
>>> testCounter
>>> testHistogram
>>> testMP
>>> testNameValue
>>> testRandom
>>> testTable
>>> Seems to works on both networks. But why no output on pvlist (without arguments) ?
>>> epics@kannsein:~$ export EPICS_PVAS_AUTO_BEACON_ADDR_LIST=NO
>>> epics@kannsein:~$ export EPICS_PVAS_BEACON_ADDR_LIST=10.20.30.1
>>> epics@kannsein:~$ export EPICS_PVAS_INTF_ADDR_LIST=10.20.30.1
>>> BEACON_ADDR_LIST : 10.20.30.1
>>> AUTO_BEACON_ADDR_LIST : 0
>>> BEACON_PERIOD : 15
>>> SERVER_PORT : 5075
>>> IGNORE_ADDR_LIST:
>>> INTF_ADDR_LIST : 10.20.30.1
>>> After 15 about 15 seconds the other terminal shows
>>> GUID 0x0CC9D05B00000000422E1420 version 1: tcp@[10.20.30.1:5075]
>>> epics@kannsein:~/BASE/epics-base$ pvlist 0x0CC9D05B00000000422E1420
>>> Failed to resolve GUID '0x0CC9D05B00000000422E1420’!
>>> After that no more output on pvlist without arguments????
>>> this still works
>>> testADC
>>> testAggregate
>>> testBinaryCounter
>>> testCounter
>>> testHistogram
>>> testMP
>>> testNameValue
>>> testRandom
>>> testTable
>>> What is the right way to define the environments in our situation?
>>> Thank you Heinz
>>> Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
>>> Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
>>> Faradayweg 4-6 |
>>> D - 14195 Berlin | E-Mail: [email protected]
>>>> On 24. Oct 2018, at 16:15, Michael Davidsaver <[email protected]> wrote:
>>>> What modules versions/revisions are involved? Can you use gdb
>>>> to extract a stack trace from the core file?
>>>> On 10/24/18 5:54 AM, Heinz Junkes wrote:
>>>>> Using epics-base master on Ubuntu 16.4 (same on debian 9)
>>>>> pvget -> segmentation fault
>>>>> epics@kannsein:/var/log$ pvget CRYAFM:struckNTTable
>>>>> epics:nt/NTTable:1.0
>>>>> time_t timeStamp 2018-10-24T15:27:48.075 0
>>>>> string[] labels [The SIS TS,The X,The Y,The Z]
>>>>> structure value
>>>>> double[] ts [0,0,0,0,0,0,0,0,100,0,0,0,0,0,0,0,200,0,0,0,0,0,0,0,300,0,0,0,0,0,0,0,400,0,0,0,0,0,0,0,500,0,0,0,0,0,0,0,600,0,0,0,0,0,0,0,700,0,0,0,0,0,0,0,800,0,0,0,0,0,0,0,900,0,0,0,0,0,0,0,1000,0,0,0,0,0,0,0,1100,0,0,0,0,0,0,0,1200,0,0,0]
>>>>> double[] X []
>>>>> double[] Y []
>>>>> double[] Z []
>>>>> Segmentation fault (core dumped)
>>>>> In kern.log we can find
>>>>> Oct 24 14:42:11 kannsein kernel: [788447.325497] traps: pvget[55565] general protection ip:7f6e9577c512 sp:7fffe1ea90d0 error:0 in libc-2.23.so[7f6e956f8000+1c0000]
>>>>> Oct 24 14:42:19 kannsein kernel: [788456.015443] traps: pvget[55587] general protection ip:7f00b8c3a512 sp:7ffdbf0c6150 error:0 in libc-2.23.so[7f00b8bb6000+1c0000]
>>>>> Oct 24 14:43:04 kannsein kernel: [788500.715803] traps: pvget[55616] general protection ip:7f88c21b8512 sp:7ffcf2fdba60 error:0 in libc-2.23.so[7f88c2134000+1c0000]
>>>>> Oct 24 14:45:14 kannsein kernel: [788630.968783] traps: pvget[55636] general protection ip:7f4d4fa00512 sp:7ffc280a7b40 error:0 in libc-2.23.so[7f4d4f97c000+1c0000]
>>>>> Oct 24 14:45:27 kannsein kernel: [788643.257952] traps: pvget[55648] general protection ip:7f088b665512 sp:7ffcc5d6ed40 error:0 in libc-2.23.so[7f088b5e1000+1c0000]
>>>>> Oct 24 14:46:09 kannsein kernel: [788685.910016] traps: pvget[55661] general protection ip:7f750da52512 sp:7ffd13bdf0b0 error:0 in libc-2.23.so[7f750d9ce000+1c0000]
>>>>> Oct 24 14:46:21 kannsein kernel: [788697.759313] traps: pvget[55673] general protection ip:7f859f104512 sp:7fff5629ff80 error:0 in libc-2.23.so[7f859f080000+1c0000]
>>>>> Oct 24 14:47:10 kannsein kernel: [788746.457913] traps: pvget[55685] general protection ip:7f9d4348f512 sp:7fffd170dba0 error:0 in libc-2.23.so[7f9d4340b000+1c0000]
>>>>> Oct 24 14:47:27 kannsein kernel: [788763.257920] traps: pvget[55697] general protection ip:7fc04a7b2512 sp:7ffc9e722280 error:0 in libc-2.23.so[7fc04a72e000+1c0000]
>>>>> Oct 24 14:47:40 kannsein kernel: [788776.330929] traps: pvget[55709] general protection ip:7f0774726512 sp:7ffd41eb8d90 error:0 in libc-2.23.so[7f07746a2000+1c0000]
>>>>> earlier this morning:
>>>>> Oct 24 11:13:14 kannsein kernel: [775910.021560] TCP-rx[53453]: segfault at 7f57bb5fd028 ip 00007f57be8fcad7 sp 00007f57bb9fd890 error 6 in libpvData.so.7.0.1[7f57be826000+178000]
>>>>> Oct 24 11:14:06 kannsein kernel: [775961.525926] TCP-rx[53465]: segfault at 7fcbd9a80028 ip 00007fcbdcd7fad7 sp 00007fcbd9e80890 error 6 in libpvData.so.7.0.1[7fcbdcca9000+178000]
>>>>> Oct 24 11:27:12 kannsein kernel: [776747.380789] TCP-rx[53569]: segfault at 7efe437dd020 ip 00007efe46adcad7 sp 00007efe43bdd890 error 6 in libpvData.so.7.0.1[7efe46a06000+178000]
>>>>> Oct 24 11:27:54 kannsein kernel: [776790.105153] TCP-rx[53586]: segfault at 7fdb33afc038 ip 00007fdb3ae14ad7 sp 00007fdb33efc890 error 6 in libpvData.so.7.0.1[7fdb3ad3e000+178000]
>>>>> Oct 24 13:24:55 kannsein kernel: [783811.567841] TCP-rx[53954]: segfault at 7f9e25019038 ip 00007f9e28318ad7 sp 00007f9e25419890 error 6 in libpvData.so.7.0.1[7f9e28242000+178000]
>>>>> Oct 24 13:25:18 kannsein kernel: [783834.055359] TCP-rx[53983]: segfault at 7f04138fc000 ip 00007f0416bfbad7 sp 00007f0413cfc890 error 6 in libpvData.so.7.0.1[7f0416b25000+178000]
>>>>> Oct 24 13:26:06 kannsein kernel: [783882.134154] TCP-rx[53998]: segfault at 7f9094ad6038 ip 00007f9097dd5ad7 sp 00007f9094ed6890 error 6 in libpvData.so.7.0.1[7f9097cff000+178000]
>>>>> Oct 24 13:26:31 kannsein kernel: [783907.132452] TCP-rx[54010]: segfault at 7f16139fa010 ip 00007f1616cf9ad7 sp 00007f1613dfa890 error 6 in libpvData.so.7.0.1[7f1616c23000+178000]
>>>>> Oct 24 13:26:45 kannsein kernel: [783921.247824] TCP-rx[54022]: segfault at 7f7cfebe6010 ip 00007f7d01ee5ad7 sp 00007f7cfefe6890 error 6 in libpvData.so.7.0.1[7f7d01e0f000+178000]
>>>>> Oct 24 13:31:08 kannsein kernel: [784183.770344] TCP-rx[54084]: segfault at 7fcce9f67020 ip 00007fcced266ad7 sp 00007fccea367890 error 6 in libpvData.so.7.0.1[7fcced190000+178000]
>>>>> Sometimes it works well … ;-(
>>>>> System runs with two network-domains (141.14.128.0, 10.0.30.0)
>>>>> Any ideas?
>>>>> Heinz
>>>>> Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
>>>>> Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
>>>>> [General Data Protection Regulation (GDPR)] der Europaeischen Union.
smime.p7s
Description: S/MIME cryptographic signature
- Re: segmentation error pvdata -> libc Michael Davidsaver
- segmentation error pvdata -> libc Heinz Junkes
- Re: segmentation error pvdata -> libc Patrik Marschalik
RE: calling EIPCS' Raspberry Pi users Kline, David
<2018>
<2018>
