1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Subject: Re: DM recommedation.
To: "Kline, David" <[email protected]>
Date: Fri, 26 Oct 2018 10:52:52 -0500
On 10/25, Kline, David wrote:
> Currently I'm using MEDM for monitoring register and market
> data, but was looking for something currently supported and
> modern, preferably based on GTK+ for internal reasons.
CSS uses SWT which uses GTK+ on Linux.  However, Display Builder on CSS
uses JavaFX as its graphics library (the documentation suggests there's
some support for SWT, but the focus is on JavaFX), so if you're wanting
pure GTK+ all the way down, then Display Builder would not satisfy that.
I believe BOY on CSS is based on Draw2d
  https://www.eclipse.org/gef/draw2d/
which uses SWT which uses GTK+ on Linux.  So, it's a little closer to
being pure GTK+ all the way down, but even Draw2d renders graphical
components to an SWT canvas, so it's not like you're actually using GTK+
widgets at that point.
Depending on the application, though, that could be considered
reasonable.  For example, an application that presents data entry
forms using standard toolkit controls might end up using GTK+ widgets
exclusively, but an application like Microsoft PowerPoint might render
everything in a slide as a custom graphical object that does not map
directly to any GTK+ widget.
Lewis
Re: DM recommedation. Kasemir, Kay via Tech-talk
DM recommedation. Kline, David
Re: DM recommedation. Gabriel de Souza Fedel
RE: DM recommedation. Kline, David
Re: DM recommedation. J. Lewis Muir
Prev: Re: segmentation error pvdata -> libc Michael Davidsaver
Next: Re: DM recommedation. Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Prev: Re: DM recommedation. Siddons, David via Tech-talk
ANJ, 26 Oct 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
