1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Device using undefined record type 'scalcout', place-holder created -> dbdExpand.pl: A different record type named 'scalcout' already exists
To: tech Talk EPICS <[email protected]>
Date: Thu, 1 Nov 2018 17:39:35 +0100
I have an error message due to scalcout with which I can't start anything.
I also don't know where to look.
calc is the master from https://github.com/epics-modules/calc
I get the following error
epics@kannsein:~/FHI/IOCVACUUM/IOCVACUUMApp/src$ make
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory '/home/epics/FHI/IOCVACUUM/IOCVACUUMApp/src/O.linux-x86_64'
Creating dbd file IOCVACUUM.dbd
perl -CSD /home/epics/BASE/epics-base/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I/srv/iocs/sys/vacuum/dbd -I/home/epics/SUPPORT/seq-2.2.6/dbd -I/home/epics/SUPPORT/asyn/dbd -I/home/epics/SUPPORT/calc/dbd -I/home/epics/SUPPORT/busy/dbd -I/home/epics/SUPPORT/autosave/dbd -I/home/epics/SUPPORT/iocStats/dbd -I/home/epics/SUPPORT/stream/dbd -I/home/epics/BASE/epics-base/dbd -o IOCVACUUM.dbd base.dbd drvAsynIPPort.dbd asyn.dbd stream.dbd calc.dbd busySupport.dbd devIocStats.dbd  asSupport.dbd
Context: recordtype(scalcout) in file '/home/epics/SUPPORT/calc/dbd/sCalcoutRecord.dbd' in file '/home/epics/SUPPORT/calc/dbd/calc.dbd'
  while reading 'calc.dbd' to create ‘IOCVACUUM.dbd'
dbdExpand.pl: Exiting due to errors
make[1]: *** No rule to make target '../O.Common/IOCVACUUM.dbd', needed by 'build'.  Stop.
make[1]: Leaving directory '/home/epics/FHI/IOCVACUUM/IOCVACUUMApp/src/O.linux-x86_64'
/home/epics/BASE/epics-base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make: *** [install.linux-x86_64] Error 2
make test in calc gives :
.../usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics/SUPPORT/sscan/include   -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include        -c ../sCalcPostfix.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics/SUPPORT/sscan/include   -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include        -c ../sCalcPerform.c
../sCalcPerform.c: In function ‘sCalcPerform’:
../sCalcPerform.c:1544:7: warning: format not a string literal and no format arguments [-Wformat-security]
       sprintf(tmpstr, ps->s);
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics/SUPPORT/sscan/include   -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include        -c ../aCalcPostfix.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics/SUPPORT/sscan/include   -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include        -c ../aCalcPerform.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics/SUPPORT/sscan/include   -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include        -c ../myFreeListLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics/SUPPORT/sscan/include   -I/home/epics/SUPPORT/seq-2.2.6/include -I/home/epics/BASE/epics-base/include/compiler/gcc -I/home/epics/BASE/epics-base/include/os/Linux -I/home/epics/BASE/epics-base/include        -c ../sCalcoutRecord.c
In file included from /home/epics/BASE/epics-base/include/dbAccess.h:19:0,
                 from ../sCalcoutRecord.c:66:
/home/epics/BASE/epics-base/include/dbBase.h:162:5: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
     rset        *prset;
Heinz
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
Attachment: smime.p7s
Description: S/MIME cryptographic signature
RE: Device using undefined record type 'scalcout', place-holder created -> dbdExpand.pl: A different record type named 'scalcout' already exists Mark Rivers
Prev: EPICS Collaboration Meeting Registrations Closing Soon [SEC=UNCLASSIFIED] POZAR, Andraz
Next: RE: Device using undefined record type 'scalcout', place-holder created -> dbdExpand.pl: A different record type named 'scalcout' already exists Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 01 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
