1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Packaging EPICS and support modules as RPM
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Thu, 22 Nov 2018 09:07:37 +0000
Hi
I managed to package epics base 3.15.6 and some other support modules as RPM package to be included in our local CentOS repo. Recently we thought of creating a global repo to be shared with the community, but the big problem we faced is the choice epics base version.
Anything that depends on EPICS base must have its EPICS_BASE defined in the configure/RELEASE file, and since there are more than one major version of EPICS, some might try base 3.14, 3.15 or 3.16 or even 7. In order for the RPM spec file to work properly, EPICS_BASE must be hardcoded in configure/RELEASE. So the question is, does it make since to create separate repo for each base version and each repo contains all support modules built against the corresponding base version? What we think of right now is 4 repos: base 3.14, base 3.15, base 3.16 and base 7. What do you think of this approach?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Re: Packaging EPICS and support modules as RPM Michael Davidsaver via Tech-talk
Prev: Re: EPICS Application Package Michael Davidsaver via Tech-talk
Next: EPICS Collaboration Meeting June 2019 at ITER Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Gardasoft RTCC-420F LED Lighting Controller support Walsh, Thomas R. via Tech-talk
Next: Re: Packaging EPICS and support modules as RPM Michael Davidsaver via Tech-talk
ANJ, 25 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
