1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Purpose of INSTALL_LOCATION Variable
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Sun, 25 Nov 2018 08:05:46 +0000
Hi
As you know this variable is defined in configure/CONFIG_SITE (or CONFIG_APP in some exceptions) and quoting from that file, this variable is used "To install files into a location other than $(TOP)".
1.       What files are being installed?
2.       Defining this variable in EPICS base does not include the startup folder scripts, therefore anything using the "installed" EPICS_BASE will not find the script EpicsHostArch for example. Is this an issue or this is how it works?
3.       Base on #1, when you define INSTALL_LOCATION in some modules that have UI files or some databases in App/Db/, why these files are not included in the installation?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Re: Purpose of INSTALL_LOCATION Variable Michael Davidsaver via Tech-talk
Prev: EPICS Collaboration Meeting June 2019 at ITER Ralph Lange via Tech-talk
Next: Re: Purpose of INSTALL_LOCATION Variable Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 25 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
