1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asynDriver - UDP server
To: 'Joao Afonso' <[email protected]>
Date: Tue, 4 Dec 2018 15:01:31 +0000
Hi Joao,
The example in asyn/testAsynPortDriver is a simple example.
This tutorial starts with a simple driver and gets more complex in subsequent versions:
https://github.com/epics-modules/measComp/blob/master/documentation/measCompTutorial.pdf
This page has links to 2015 YouTube video lectures on asyn and asynPortDriver:
https://epics.anl.gov/docs/APS2015.php
This page also has links to 2018 YouTube videos on asyn and asynPortDriver under the areaDetector section:
https://www.bnl.gov/ps/epics/
Sent: Tuesday, December 4, 2018 8:44 AM
Cc: [email protected]
Hi Mark,
Thank you for the quick answer.
I will take a look into asynPortDriver documentation, to see if writing a driver is a good approach for us.
Is there any specific documentation you would recommend to help writing it?
Joao
Sent: 03 December 2018 19:39
To: Joao Afonso
Hi Joao,
What you have tried seems reasonable, but unfortunately it won’t work. The reason is that the drvAsynIPPort driver does not have a mechanism to asynchronously call back to device support when new input arrives.  There are several other ways to do this.
-       You can use streamDevice.  It works with SCAN=I/O Intr records by polling the device.  streamDevice should even be able to parse the UDP buffer for you into the individual records you want to use.
-       You could write your own little asyn driver, derived from asynPortDriver.  It would just have a small loop like this:
    while (1) {
        pasynOctet->read(myBuffer)
        value1 = parseMyBuffer(1)
        setIntegerParam(myParam1, value1)
        value2 = parseMyBuffer(2)
        setIntegerParam(myParam2, value2)
        callParamCallbacks()
From: [email protected] <[email protected]> On Behalf Of Joao Afonso via Tech-talk
Sent: Monday, December 3, 2018 11:27 AM
To: [email protected]
Subject: asynDriver - UDP server
Hello!
First, sorry if any of these questions seems too simple. I started working recently with EPICS and I am still learning how it works.
Basically, I am trying to create an IOC that works as a UDP server. It should be listening at a certain port and, when a new packet arrives, it should update a set of records with the incoming data.
It doesn't need to respond to any of the packets.
The data is a binary array, which will be read into a waveform record, and then unpacked into other records in order to be read by the clients (I don't know if this is the best approach, for now I am just experimenting). The structure of the binary array is fixed and known beforehand.
For now, I just want to update the waveform record with the binary data when the UDP packet arrives. I am using asynDriver since it seems to provide all the tools I need:
On the 'st.cmd' file I have:
drvAsynIPServerPortConfigure ("fgc_udp", "localhost:2906 udp", 10, 0, 0, 0)
dbLoadRecords("db/fgc_udp.db","GW=${FGC_GW_NAME}:")
And on the 'db/fgc_udp.db' I have:
record(waveform, "$(GW)UDP") {
     field(SCAN, "I/O Intr")
     field(DTYP, "asynOctetRead")
     field(FTVL, "UCHAR")
     field(DESC, "UDP publication")
     field(NELM, "4096")
     field(INP,  "@asyn(fgc_udp, 0, 0) drvUser")
Since I am using 'I/O Intr', I would expect the record to be updated when a new UDP packet arrives, but it is not working.
It only updates if I use the IOC shell command "dbtr xxx:UDP", or if I change SCAN to a "N seconds" option.
Do you know how I can fix it? I guess it is something simple, but I am stuck.
I would also like to know if using a waveform record is a good starting point for unpacking binary data, or if there is a better alternative.
Thank you in advance,
Joao
asynDriver - UDP server Joao Afonso via Tech-talk
RE: asynDriver - UDP server Mark Rivers via Tech-talk
RE: asynDriver - UDP server Joao Afonso via Tech-talk
Prev: RE: asynDriver - UDP server Joao Afonso via Tech-talk
Next: Re: Asyn PortDriver readFloat64 Douglas Henrique C. de Araújo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Waiting for mbufs on RTEMS Matt Rippa via Tech-talk
ANJ, 04 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
