On 12/7/18 1:00 AM, Florian Feldbauer via Tech-talk wrote:
> Hey Andrew,
> I'm not using MEDM but libXt-dev is not listed for Ubuntu on the webpage. Maybe it is a dependency of one of the other packages?
Both Debian and Ubuntu there is an excellent resources to answer these kinds of questions.
http://packages.debian.org/file:libXt.so
https://packages.ubuntu.com/search?searchon=contents&keywords=libXt.so&mode=exactfilename&suite=cosmic&arch=any
> I just checked which package contains libXt.so and found libXt-dev.
> Usually the lib packages contain libXXX.so.VERSION and the corresponding development packages contain the libXXX.so and libXXX.a files.
Compare the contents of 'libxt-dev' with those of it's dependency, 'libxt6'.
> If the linker doesn't find the shared object it tries the static one. I guess that's why the error message quotes
>> *** No rule to make target `/usr/lib64/libXt.a', needed by `medm'.
> Cheers,
> Florian
> Am 06.12.2018 um 18:26 schrieb Johnson, Andrew N.:
>> Hi Florian,
>> Is this in addition to the list of packages given on the MEDM web-page <https://epics.anl.gov/extensions/medm/index.php> ? That does mention Ubuntu 14.04 which is what I was testing against when I added that list.
>> Strictly speaking the build says it's looking for libXt.a but it should be happy with a copy of libXt.so instead, unless you have configured the build for static linking.
>> - Andrew
>> On 12/6/18 4:55 AM, Florian Feldbauer via Tech-talk wrote:
>>> Hey,
>>> at least under debian, you need to install the package libxt-dev.
>>> Guess it's the same under Ubuntu.
>>> Hope this helps!
>>> Cheers,
>>> Florian
>>> On 12/6/18 11:33 AM, nieyg--- via Tech-talk wrote:
>>>> I just tried to build medm using epics base-3.14.12.5 on Ubuntu 14.04. It gives an error:
>>>> I suspect a configuration error. Any suggestions?
>>>> Thanks
>>>> [email protected]
>>> Dr. Florian Feldbauer
>>> Ruhr-Universität Bochum
>>> Experimentalphysik I AG
>>> Fach-Nr. 125
>>> Universitätsstr. 150
>>> D-44801 Bochum
>>> Office: NB 2/134
>>> Phone: (+49)234 / 32-23563
>>> Fax: (+49)234 / 32-14170
>> Arguing for surveillance because you have nothing to hide is no
>> different than making the claim, "I don't care about freedom of
>> speech because I have nothing to say." -- Edward Snowdon
> Experimentalphsyik I AG
> Universitätsstr 150
> Fach-Nr. 125
> D-44801 Bochum
> Office: NB2/134
> https://paluma.ruhr-uni-bochum.de
- medm build nieyg--- via Tech-talk
- Re: medm build Florian Feldbauer via Tech-talk
- Re: medm build Johnson, Andrew N. via Tech-talk
RE: medm build Heesterman, Peter J via Tech-talk
AD R3-2 libzlib.so Madden, Timothy J. via Tech-talk
<2018>
build caQtDM 聂勇敢 via Tech-talk
<2018>
