asyn/config/RELEASE does point to $(SUPPORT)/seq-2-2-5.
*Sent:* Tuesday, December 11, 2018 3:24 PM
*To:* Iain Marcuson <[email protected]>; Johnson,
Andrew N. <[email protected]>
*Subject:* RE: FW: Build failure when compiling synApps from source
Does asyn/config/RELEASE have an entry that correctly points to
$(SUPPORT)/seq-2-2-5? If so, it should find the rule to build .st files.
<mailto:[email protected]> <[email protected]
<mailto:[email protected]>> *On Behalf Of *Iain Marcuson via
Tech-talk
*Sent:* Tuesday, December 11, 2018 2:04 PM
*To:* Johnson, Andrew N. <[email protected] <mailto:[email protected]>>
*Cc:* [email protected] <mailto:[email protected]>
The synApps RELEASE files point to $(SUPPORT)/seq-2-2-5. That said, how
would I install EPICS and synApps in a distinct directory if I need to
include the source?
Iain.
*From:* Johnson, Andrew N. <[email protected] <mailto:[email protected]>>
*Sent:* Tuesday, December 11, 2018 2:57 PM
<mailto:[email protected]>>; [email protected]
*Subject:* Re: FW: Build failure when compiling synApps from source
Hi Iain,
On 12/11/18 1:20 PM, Iain Marcuson via Tech-talk wrote:
I was able to build the standalone sequencer fine. Yokogawa appears to build, but asyn fails with
make[4]: *** No rule to make target `ipSNCServer.o', needed by `libtestIPServerSupport.a'. Stop.
The sequencer provides its own set of build rules which the EPICS build
system will pull in automatically from the sncseq module when you list
it in your application's configure/RELEASE file. This isn't happening
for you, and I suspect you're trying to use a modified build system
since you also wrote this earlier:
-snc binary in /opt/epics/bin/linux-arm
That isn't how the sequencer normally comes, GNUmake needs to see the
contents of the sncseq/configure/RULES_BUILD file for any application
that needs to compiler sequence programs.
- Andrew
