1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Error compiling EPICS base-7.0.x on OpenSUSE 10.3
From: "Woods, Russell via Tech-talk" <[email protected]>
Date: Thu, 20 Dec 2018 18:18:00 +0000
Has anyone compiled base-7 on the OpenSUSE pilatus computers? I'm getting the error shown below. These computers have perl5.8.8
I didn't have any problem compiling on the newer CentOS 6.5 machines (perl5.10.1).
Thanks
Russ Woods
root:base-7.0.2# make
make -C ./configure install
make[1]: Entering directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/configure'
perl -CSD ../src/tools/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
        T_A=linux-x86_64 install
make[2]: Entering directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/configure/O.linux-x86_64'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/configure/O.linux-x86_64'
make[1]: Leaving directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/configure'
make -C ./src install
make[1]: Entering directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src'
make -C ./tools install
make[2]: Entering directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src/tools/O.linux-x86_64'
Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm
Installing PERL_MODULES file ../../../lib/perl/EpicsHostArch.pl
Installing script ../../../bin/linux-x86_64/assembleSnippets.pl
mkdir ../../../bin/linux-x86_64
Installing script ../../../bin/linux-x86_64/convertRelease.pl
Installing script ../../../bin/linux-x86_64/cvsclean.pl
Installing script ../../../bin/linux-x86_64/depclean.pl
Installing script ../../../bin/linux-x86_64/dos2unix.pl
Installing script ../../../bin/linux-x86_64/expandVars.pl
Installing script ../../../bin/linux-x86_64/fullPathName.pl
Installing script ../../../bin/linux-x86_64/installEpics.pl
Installing script ../../../bin/linux-x86_64/makeMakefile.pl
Installing script ../../../bin/linux-x86_64/makeTestfile.pl
Installing script ../../../bin/linux-x86_64/mkmf.pl
Installing script ../../../bin/linux-x86_64/munch.pl
Installing script ../../../bin/linux-x86_64/podToHtml.pl
Installing script ../../../bin/linux-x86_64/podRemove.pl
Installing script ../../../bin/linux-x86_64/replaceVAR.pl
Installing script ../../../bin/linux-x86_64/tap-to-junit-xml.pl
Installing script ../../../bin/linux-x86_64/useManifestTool.pl
Installing script ../../../bin/linux-x86_64/genVersionHeader.pl
Installing html ../../../html/./style.css
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
Can't locate object method "new" via package "Pod::Simple::HTML" (perhaps you forgot to load "Pod::Simple::HTML"?) at ../../../src/tools/podToHtml.pl line 89.
make[3]: *** [../O.Common/EPICS/Getopts.html] Error 25
make[3]: Leaving directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src/tools/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src/tools'
make[1]: *** [tools.install] Error 2
make[1]: Leaving directory `/disk2/local/DPbin/epics/epics_2018-12-06/base-7.0.2/src'
make: *** [src.install] Error 2
RE: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
Prev: RE: EPICS support for HR2000+ question Bommannavar, Arun S. via Tech-talk
Next: RE: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problems with channel access across subnets on debian 9 linux systems Goetz Pfeiffer via Tech-talk
ANJ, 20 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
