Hi Russ,
As long as the machine has cpan installed you should be able to use another machine to download the tar-file from
https://cpan.metacpan.org/authors/id/K/KH/KHW/Pod-Simple-3.35.tar.gz
untar it somewhere temporary on the machine and cd into the top directory, then (as root) run
cpan .
which will do the installation for you.
It’s possible that you may need additional dependencies installing first, which cpan should tell you about. You can find the Download Link for the module distribution on metacpan.org and repeat as above.
Give me a shout in January if you need help.
- Andrew
> On Dec 22, 2018, at 4:20 PM, Woods, Russell <[email protected]> wrote:
> Thanks everyone! I should have tried Matt's suggestion but our OpenSUSE machines are blocked from the external network, so I wasn't sure how to update perl. I'll ask IT for help with that after the break.
> Cheers
> Russ
> APS Detector Pool
> On Dec 22, 2018 9:28 AM, Mark Rivers <[email protected]> wrote:
> I tried installing with cpan:
> root:epics# cpan install Pod::Simple::HTML
> CPAN: Storable loaded ok
> CPAN: LWP::UserAgent loaded ok
> Fetching with LWP:
> ftp://ftp.perl.org/pub/CPAN/authors/01mailrc.txt.gz
> It hangs up on the ftp command. I think it's probably possible to configure span to work around this problem, but I don't know how to do it.
> Mark
> -----Original Message-----
> From: Johnson, Andrew N. <[email protected]>
> Sent: Saturday, December 22, 2018 8:21 AM
> To: Mark Rivers <[email protected]>
> Cc: Peterson, Kevin M. <[email protected]>; Woods, Russell <[email protected]>; [email protected]
> Subject: Re: Error compiling EPICS base-7.0.x on OpenSUSE 10.3
> Sorry for the delay, I’ve been traveling (and my wife says I’m on holiday and shouldn’t be working anyway)...
> > On Dec 21, 2018, at 9:29 AM, Mark Rivers via Tech-talk <[email protected]> wrote:
> > I verified my suspicion. I deleted the base-7.0.2/html directory and did "make clean" on the Pilatus architecture.
> > I then got the perl errors:
> > gse-pilatus1 epics-devel/base-7.0.2> make -sj4 Can't locate
> > Pod/Simple/HTML.pm in @INC (@INC contains: /usr/lib/perl5/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/5.8.8 /usr/lib/perl5/site_perl/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl .) at ../../../src/tools/podToHtml.pl line 15.
> > BEGIN failed--compilation aborted at ../../../src/tools/podToHtml.pl line 15.
> Apparently Perl 5.8.8 didn’t come with the Pod::Simple::HTML module which I use to convert POD (Plain Old Documentation) into HTML files in the EPICS INSTALL_HTML directory, it first appeared in Perl 5.10 (which was released in December 2007). In an earlier response Matt Newville gave explicit instructions on how to install the module, which should work. Mark’s solution of first building for a different host architecture which has that Perl module is your best workaround if you can’t install it using cpan or some equivalent such as the OpenSUSE package management system.
> - Andrew
- RE: Error compiling EPICS base-7.0.x on OpenSUSE 10.3 Woods, Russell via Tech-talk
Re: New EPICS Releases Ralph Lange via Tech-talk
Weird IOC behavior with NTP time shift Abdalla Ahmad via Tech-talk
<2018>
Stream fails on windows-x64 against base-7.0.2 Gofron, Kazimierz via Tech-talk
<2018>
