1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: modules/ca/src/perl cc1: error: ‘-fcf-protection=full’ on first build of base
From: Matt Newville via Tech-talk <[email protected]>
To: Peter Milne <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Thu, 3 Jan 2019 10:34:42 -0600
On Thu, Jan 3, 2019 at 3:35 AM Peter Milne via Tech-talk <[email protected]> wrote:
Hello Tech-talk
Clean build fails first try on Fedora 28
Same result on 3.16
It's easily fixed, but is no one else using Fedora? :-(
Base 3.16.2 builds without incident or any on Fedora 28.  I have
~>cat  /etc/redhat-release
Fedora release 28 (Twenty Eight)
~>gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/8/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-redhat-linux
Configured with: ../configure --enable-bootstrap --enable-languages=c,c++,fortran,objc,obj-c++,ada,go,lto --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-gcc-major-version-only --with-linker-hash-style=gnu --enable-plugin --enable-initfini-array --with-isl --enable-libmpx --enable-offload-targets=nvptx-none --without-cuda-driver --enable-gnu-indirect-function --enable-cet --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux
Thread model: posix
gcc version 8.2.1 20181105 (Red Hat 8.2.1-5) (GCC)
~> cat /proc/version
Linux version 4.19.5-200.fc28.x86_64 ([email protected]) (gcc version 8.2.1 20181105 (Red Hat 8.2.1-5) (GCC)) #1 SMP Tue Nov 27 20:19:26 UTC 2018
--Matt
Re: modules/ca/src/perl cc1: error: ‘-fcf-protection=full’ on first build of base Peter Milne via Tech-talk
Prev: Re: asynError in write on Power PMAC IOC giles.knap--- via Tech-talk
Next: Re: modules/ca/src/perl cc1: error: ‘-fcf-protection=full’ on first build of base Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: modules/ca/src/perl cc1: error: ‘-fcf-protection=full’ on first build of base Peter Milne via Tech-talk
Next: Re: modules/ca/src/perl cc1: error: ‘-fcf-protection=full’ on first build of base Peter Milne via Tech-talk
ANJ, 03 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
