And that is exactly the solution.
Wonder how/why it worked all the way up to 7.0.1 and only now choked on
print as a file name?
Thanks!
-----Original Message-----
Sent: Friday, January 4, 2019 2:11 PM
To: 'Engbretson, Mark S.' <[email protected]>; 'Michael Davidsaver'
<[email protected]>; [email protected]
Subject: RE: Epics base 7.0.2 Windows MSVC odd case change
The problem is not happening for me.
I am using make 4.2.1 from the EPICS page link here:
https://epics.anl.gov/base/win32.php
This is the print.d I just created when building with Visual Studio 2017.
corvette:pvData/src/O.windows-x64-static-vs2017>more print.d # DO NOT EDIT:
This file created by mkmf.pl
print.obj : ../pv/pvdVersion.h
print.obj : ../pv/pvData.h
print.obj : ../pv/valueBuilder.h
print.obj : ../../src/misc/pv/bitSet.h
print.obj : ../../src/json/pv/json.h
print.obj : H:/epics-devel/base-7.0.2/include/epicsVersion.h
print.obj : H:/epics-devel/base-7.0.2/include/shareLib.h
print.obj : ../O.Common/pv/pvdVersionNum.h print.obj : ../pv/pvIntrospect.h
print.obj : ../../src/misc/pv/typeCast.h print.obj :
../../src/misc/pv/anyscalar.h print.obj : ../../src/misc/pv/sharedVector.h
print.obj : H:/epics-devel/base-7.0.2/include/compilerDependencies.h
print.obj : ../../src/misc/pv/templateMeta.h print.obj : ../pv/pvType.h
print.obj : ../../src/misc/pv/serialize.h print.obj :
../../src/misc/pv/sharedPtr.h print.obj :
H:/epics-devel/base-7.0.2/include/yajl_parse.h
print.obj : ../../src/misc/pv/lock.h
print.obj : ../../src/misc/pv/noDefaultMethods.h
print.obj : ../../src/misc/pv/byteBuffer.h print.obj :
H:/epics-devel/base-7.0.2/include/epicsConvert.h
print.obj : H:/epics-devel/base-7.0.2/include/epicsAssert.h
print.obj :
H:/epics-devel/base-7.0.2/include/compiler/msvc/compilerSpecific.h
print.obj : H:/epics-devel/base-7.0.2/include/epicsTypes.h
print.obj : H:/epics-devel/base-7.0.2/include/yajl_common.h
print.obj : H:/epics-devel/base-7.0.2/include/epicsMutex.h
print.obj : H:/epics-devel/base-7.0.2/include/epicsEndian.h
print.obj : ../../src/misc/pv/epicsException.h
print.obj : H:/epics-devel/base-7.0.2/include/epicsGuard.h
print.obj : H:/epics-devel/base-7.0.2/include/os/WIN32/osdMutex.h
print.obj : H:/epics-devel/base-7.0.2/include/os/WIN32/osdWireConfig.h
Behalf Of Engbretson, Mark S. via Tech-talk
Sent: Friday, January 4, 2019 2:05 PM
To: 'Michael Davidsaver' <[email protected]>; [email protected]
Gnu make 4.1
Sent: Friday, January 4, 2019 2:01 PM
To: Engbretson, Mark S. <[email protected]>; [email protected]
Subject: Re: Epics base 7.0.2 Windows MSVC odd case change
Which version of Make are you using?
In fact a makefile troubleshooting target was added PRINT.% which prints the
value of a make variable. eg. PRINT.CPPFLAGS
This shouldn't cause problems as to my knowledge GNU make target names are
always case sensitive.
On 1/4/19 11:26 AM, Engbretson, Mark S. via Tech-talk wrote:
> I was just attempting a build on epics base 7.0.2 on windows with
Microsoft Visual Studio 2012 (windows 7) and 2017 (windows 10) and it
stalled on building the pvData json module print.cpp.
> The odd part is that when it is being parsed by mkmf.pl, the print.d
> is
created with all references to print being upper case, i.e. PRINT, so
print.cpp never actually gets compiled, so the library does not have all the
elements that it needs to build.
> If I were to change the file name to print1.cpp and modify the make
> file
to use that file name - everything works. As it does if I edit the print.d
file and flip the upper case PRINT back to lower case print.
> This did not do this with epics base 7.0.1. Not a big deal since I am
aware of a solution, but I was wondering if any of the build system expects
might know why "print" on at least 2 of my build systems is now being
treated differently. Works as expected on linux.
- Epics base 7.0.2 Windows MSVC odd case change Engbretson, Mark S. via Tech-talk
- Re: Epics base 7.0.2 Windows MSVC odd case change Michael Davidsaver via Tech-talk
- RE: Epics base 7.0.2 Windows MSVC odd case change Engbretson, Mark S. via Tech-talk
- RE: Epics base 7.0.2 Windows MSVC odd case change Mark Rivers via Tech-talk
Re: asynError in write on Power PMAC IOC Chanaka via Tech-talk
<2019>
webopi with different authentication Vikram Bhagat via Tech-talk
<2019>
