Thanks for the update on the repository status Alan.
Chanaka, I've been able to run an IOC for a PowerPMAC using the DLS
code. I found one compile problem (CentOS7, gcc 4.8.5) and have proposed
a fix in https://github.com/waynelewis/pmac/tree/ppmac-ramfix
I'm not able to test that the fix works, but it does compile, and the
rest of the code works fine with the PowerPMAC across the asyn port
interface to gpascii.
Wayne
On Fri, Jan 04, 2019 at 04:27:14PM -0500, Chanaka wrote:
> Thank you, Guys. I will work on migrating to DLS version.
> Last night I ran test scans with 1 second period. The scans did not hang
> up. Will continue with a couple more test runs.
> Regards,
> Chanaka
> On Fri, Jan 4, 2019 at 7:45 AM [email protected] <
> [email protected]> wrote:
> > Hi all,
> > I agree with Giles completely. The OS module is now out of date and lacks
> > many features available from the new pmac module. The old OS module is for
> > powerPMAC only. The new module works with powerPMAC and geobrick, the
> > communications layer has been re-written, dynamic parameters are supported,
> > trajectory scanning is supported etc.
> > I have added a message to the README of the original OSL powerPMAC module
> > to forward people to the Diamond version.
> > The direct answer to your question Giles is no, the dynamic parameter
> > feature is not implemented in the OS driver.
> > Thanks, Alan
> > ________________________________
> > From: Knap, Giles (DLSLtd,RAL,LSCI)
> > Sent: 03 January 2019 09:46:54
> > To: Wayne Lewis
> > Cc: Chanaka; [email protected]; Greer, Alan (OBS,RAL,DIA)
> > Subject: Re: asynError in write on Power PMAC IOC
> > Hi Wayne,
> > The DLS support module can be used without any DLS specific dependencies
> > and is the currently maintained module. The power pmac support in
> > https://github.com/dls-controls/pmac is based on
> > https://github.com/Observatory-Sciences/powerPMAC and the latter is being
> > deprecated.
> > I'm not sure if the dynamic parameter feature I discussed is implemented
> > in the OS driver. (Alan?)
> > Regards,
> > giles.
> > From: Wayne Lewis <[email protected]>
> > Sent: 02 January 2019 16:41:15
> > To: Knap, Giles (DLSLtd,RAL,LSCI)
> > Hi Giles, Chanaka,
> > I've also seen a similar error on the IOC console when using a
> > StreamDevice connection to the PowerPMAC.
> > I notice that there are (at least) two versions of PowerPMAC EPICS
> > support available:
> > A couple of questions:
> > - is the DLS version dependent on anything other than standard EPICS
> > base and modules?
> > - is the Observatory Sciences version still maintained and used?
> > Thanks,
> > Wayne
> > On Wed, Jan 02, 2019 at 10:08:14AM +0000, giles.knap--- via Tech-talk
> > wrote:
> > > Hi Chanaka,
> > > It appears that you are sharing the connection port with a stream device
> > (in order to determine if PLC 15 is running)? I would not recommend this.
> > Instead you can add a dynamic parameter to one of the poll loops so that
> > the driver will monitor it for you and efficiently manage communications
> > with the power pmac.
> > > In this case you could use
> > > record(longin, "$(P){$(DEV)}TrajInitPlc-Read")
> > > field(DTYP, "asynInt32")
> > > field(INP, "@asyn(PMAC_CONTROLLER,0)PMAC_VIM_Plc[15].Running")
> > > field(SCAN, "I/O Intr")
> > > This will update on the medium scan loop every 2 seconds. The slow loop
> > is 5 seconds and the fast loop has two rates, idle and moving, which are
> > specified as parameters to pmacController constructor.
> > > You should replace all of you protocol functions with a similar pattern.
> > > I do not think the documentation covers dynamic parameters as yet, but
> > the comments under pmacController::drvUserCreate give the following details:
> > > // Accepted parameter formats
> > > // For reading variables
> > > // PMAC_VxF_... => PMAC Variable Fast Loop
> > > // PMAC_VxM_... => PMAC Variable Medium Loop
> > > // PMAC_VxS_... => PMAC Variable Slow Loop
> > > // x is I for int, H for hex, D for double or S for string
> > > // There must be no j or = in a variable, these items will simply be
> > polled for their current status
> > > // For Writing only
> > > // PMAC_WI_... => Write Integer Value
> > > // PMAC_WD_... => Write Double Value
> > > // PMAC_WS_... => Write String Value
> > > // Writing to these parameters will result in immediate writes to the
> > PMAC
> > > ( One of the main goals of the pmac driver is to efficiently manage
> > communications with the hardware. We have a message broker that batches up
> > all requests to poll for values into the 3 poll loops, the responses are
> > distributed to any objects that have registered interest. There is only one
> > instance of the message broker and it is the only object that communicates
> > with the hardware. Thus requests through drvAsynPowerPMACPort are on a
> > single thread. If you share the drvAsynPowerPMACPort with a stream device
> > then it will be being called on more than one thread. It should be using
> > locking and should work but has not been tested in this fashion. )
> > > Regards,
> > > giles.
> > > From: [email protected] <[email protected]> on
> > behalf of Chanaka via Tech-talk <[email protected]>
> > > Sent: 31 December 2018 16:03:40
> > > To: [email protected]
> > > Subject: asynError in write on Power PMAC IOC
> > > Dear All,
> > > I am running into a hanging issue while performing scans using higher
> > level software due to a WRITE INVALID caused by lower-level EPICS PVs. The
> > occurrence is intermittent. From what I can find on line this *could* be
> > due to how SCAN filed is setup in this database for the relevant PVs. I am
> > not entirely sure if that could be the case. Any help would be appreciated.
> > > --The specific error I see in the IOC shell is the following. This is
> > for one of the PVs.
> > > 2018/12/28 17:46:07.974527 SSH1 XF:07BMA-OP{MC:03}TrajInitPlc-Read:
> > asynError in write: 10.7.130.93 write error
> > > --And camonitor returned the following.
> > > XF:07BMA-OP{MC:03}TrajInitPlc-Read 2018-12-28 17:46:07.974595 0 WRITE
> > INVALID
> > > --The PV is defined as follows.
> > > record(ai, "$(P){$(DEV)}TrajInitPlc-Read")
> > > field(DTYP, "stream")
> > > field(INP, "@ppmac_stream.proto getVarInt(Plc[15].Running)
> > $(SSH)")
> > > field(SCAN, "0.5 second")
> > > -- getVarInt is defined as follows
> > > getVarInt{
> > > out "\$1";
> > > in "\n\$1=%d";
> > > -- Port configuration is as follows
> > > drvAsynPowerPMACPortConfigure("SSH1", "10.7.130.93", "root", "deltatau",
> > "0", "0", "0")
> > > Thank you,
> > > Chanaka De Silva
> > > NSLSII
> > > This e-mail and any attachments may contain confidential, copyright and
> > or privileged material, and are for the use of the intended addressee only.
> > If you are not the intended addressee or an authorised recipient of the
> > addressee please notify us of receipt by returning the e-mail and do not
> > use, copy, retain, distribute or disclose the information in or attached to
> > the e-mail.
> > > Any opinions expressed within this e-mail are those of the individual
> > and not necessarily of Diamond Light Source Ltd.
> > > Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> > attachments are free from viruses and we cannot accept liability for any
> > damage which you may sustain as a result of software viruses which may be
> > transmitted in or with the message.
> > > Diamond Light Source Limited (company no. 4375679). Registered in
> > England and Wales with its registered office at Diamond House, Harwell
> > Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
> > Wayne Lewis
> > e: [email protected]
> > w: http://ospreydcs.com
> > p: +1 631 905 1964
Wayne Lewis
p: +1 631 905 1964
- Re: asynError in write on Power PMAC IOC Chanaka via Tech-talk
- Re: asynError in write on Power PMAC IOC giles.knap--- via Tech-talk
- Re: asynError in write on Power PMAC IOC Wayne Lewis via Tech-talk
- Re: asynError in write on Power PMAC IOC alan.greer--- via Tech-talk
<2019>
2025
<2019>
2025
