1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AreaDetector R3-4 module build error
Cc: [email protected]
Date: Thu, 10 Jan 2019 11:54:12 -0800
Yes, that was it. I replaced those files and it fixed the problem.
On Thu, Jan 10, 2019, 11:46 AM Mark Rivers <[email protected] wrote:
Hi David,
Ø  EPICS/Release.pm: Undefined macro $(SUPPORT) used
I just realized there could be another cause for this error.  Between R3-1 and R3-4 the ADXXX/configure/RELEASE and ADXXX/iocs/XXXIOC/configure/RELEASE files need to change.  Look at those 2 files in ADSimDetector for examples.
Sent: Thursday, January 10, 2019 6:11 AM
To: David Vine <[email protected]>
Hi David,
In the RELEASE.md for R3-3 it describes changes to the areaDetector/configure/RELEASE*.local files.
https://github.com/areaDetector/areaDetector/blob/master/RELEASE.md
The EXAMPLE_RELEASE*.local files were updated to reflect the required changes.
The INSTALL_GUIDE.md explains what is required in these files.
https://github.com/areaDetector/areaDetector/blob/master/INSTALL_GUIDE.md
From: [email protected] <[email protected]> on behalf of David Vine via Tech-talk <[email protected]>
Sent: Wednesday, January 9, 2019 10:35 PM
To: [email protected]
Subject: AreaDetector R3-4 module build error
HI all,
I have an area detector module (github.com/djvine/ADTucsen) that builds without any problem on AD3-1 but on AD3-4 I get the message below about an undefined macro $(SUPPORT).
Any suggestion on how to fix would be greatly appreciated.
David
[david@dusk ADTucsen]$ make clean && make
at /opt/epics/base-3.15.5/bin/linux-x86_64/../../lib/perl/EPICS/Release.pm line 104.
       main::expandRelease(HASH(0x558e9a7f3100)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./configure clean
make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/configure'
       main::expandRelease(HASH(0x55b054e11588)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
rm -rf O.linux-x86_64 O.Common
make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/configure'
make -C ./tucsenSupport clean
make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenSupport'
       main::expandRelease(HASH(0x555f2675e588)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenSupport'
make -C ./tucsenApp clean
make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp'
       main::expandRelease(HASH(0x555c9188d5b8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./src clean
make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/src'
       main::expandRelease(HASH(0x55c6cb9455e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/src'
make -C ./Db clean
make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/Db'
       main::expandRelease(HASH(0x55d4be52b5b8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/Db'
make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp'
make -C ./iocs clean
make[1]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs'
       main::expandRelease(HASH(0x562d950535b8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./tucsenIOC clean
make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC'
       main::expandRelease(HASH(0x55fd353095e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/configure'
       main::expandRelease(HASH(0x557b115ea5e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/configure'
make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/tucsenApp'
       main::expandRelease(HASH(0x55eb8ef845d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./src clean
make[4]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/tucsenApp/src'
       main::expandRelease(HASH(0x55ef355215e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[4]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/tucsenApp/src'
make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/tucsenApp'
make -C ./iocBoot clean
make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/iocBoot'
       main::expandRelease(HASH(0x55c6f0b525e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./iocTucsen clean
make[4]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/iocBoot/iocTucsen'
       main::expandRelease(HASH(0x563c802b25e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
rm -f cdCommands envPaths dllPath.bat relPaths.sh
make[4]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/iocBoot/iocTucsen'
make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/iocBoot'
make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC'
make[1]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs'
       main::expandRelease(HASH(0x562e3bf75030)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./configure install
       main::expandRelease(HASH(0x561594de95e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
perl -CSD /opt/epics/base-3.15.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
   T_A=linux-x86_64 install
make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/configure/O.linux-x86_64'
       main::expandRelease(HASH(0x55c621a125d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
perl -CSD /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl checkRelease
       main::expandRelease(HASH(0x5582794649d0)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/configure/O.linux-x86_64'
make -C ./tucsenSupport install
       main::expandRelease(HASH(0x5631918655b8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
mkdir O.Common
make[2]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenSupport/O.linux-x86_64'
       main::expandRelease(HASH(0x560dc1eb95e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenSupport/O.linux-x86_64'
make -C ./tucsenApp install
       main::expandRelease(HASH(0x55b0968485d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./src install
       main::expandRelease(HASH(0x55d6e58315d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
perl -CSD /opt/epics/base-3.15.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/src/O.linux-x86_64'
       main::expandRelease(HASH(0x55609453e5e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../
../include/os/Linux -I../../../include   -I/opt/epics/synApps/support/asyn-R4-33/include     -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApps/support/areaDetector
-master/ADSupport/include   -I/opt/epics/synApps/support/areaDetector-master/ADCore/include -I/opt/epics/base-3.15.5/include/compiler/gcc -I/opt/epics/base-3.15.5/include/os/Linux -I/opt/epics/base-3.15.5/inclu
de        -MM -MF tucsen.d  ../tucsen.cpp
       main::expandRelease(HASH(0x55baae33e630)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
de        -c ../tucsen.cpp
../tucsen.cpp: In member function ‘asynStatus tucsen::grabImage()’:
../tucsen.cpp:410:9:
warning: variable ‘header’ set but not used [-Wunused-but-set-variable]
    int
header, offset;
../tucsen.cpp:411:23:
warning: variable ‘stride’ set but not used [-Wunused-but-set-variable]
    int nCols, nRows,
stride;
../tucsen.cpp:412:42:
warning: variable ‘pixelBytes’ set but not used [-Wunused-but-set-variable]
    int bitDepth, pixelFormat, channels,
pixelBytes;
../tucsen.cpp:413:9:
warning: variable ‘index’ set but not used [-Wunused-but-set-variable]
    int
index, dataSize;
../tucsen.cpp: In member function ‘virtual asynStatus tucsen::writeInt32(asynUser*, epicsInt32)’:
../tucsen.cpp:551:9:
warning: variable ‘tucStatus’ set but not used [-Wunused-but-set-variable]
    int
tucStatus;
../tucsen.cpp: In member function ‘virtual asynStatus tucsen::writeFloat64(asynUser*, epicsFloat64)’:
../tucsen.cpp:632:24:
warning: unused variable ‘functionName’ [-Wunused-variable]
    static const char*
functionName = "writeFloat64";
../tucsen.cpp:633:17:
warning: unused variable ‘paramName’ [-Wunused-variable]
    const char*
paramName;
../tucsen.cpp: In member function ‘asynStatus tucsen::setCamInfo(int, int, int)’:
../tucsen.cpp:677:24:
    static const char*
functionName = "setCamInfo";
../tucsen.cpp: In member function ‘asynStatus tucsen::setSerialNumber()’:
../tucsen.cpp:711:24:
    static const char*
functionName = "setSerialNumber";
../tucsen.cpp: In member function ‘asynStatus tucsen::startCapture()’:
../tucsen.cpp:792:24:
    static const char*
functionName = "startCapture";
../tucsen.cpp: In member function ‘asynStatus tucsen::stopCapture()’:
../tucsen.cpp:802:24:
    static const char*
functionName = "stopCapture";
../tucsen.cpp:803:9:
    int
tucStatus;
../tucsen.cpp: At global scope:
warning: ‘functionName’ defined but not used [-Wunused-variable]
    static const char*
    static const char*
    static const char*
    static const char*
    static const char*
../tucsen.cpp:418:9:
warning: ‘pixelSize’ may be used uninitialized in this function [-Wmaybe-uninitialized]
    int
pixelSize;
../tucsen.cpp:493:5:
warning: ‘numColors’ may be used uninitialized in this function [-Wmaybe-uninitialized]
if (numColors==1){
../tucsen.cpp:520:32:
warning: ‘dataType’ may be used uninitialized in this function [-Wmaybe-uninitialized]
    pRaw_ =
pNDArrayPool->alloc(nDims, dims, dataType, 0, NULL);
/usr/bin/ar -rc    libtucsen.a         tucsen.o
/usr/bin/ranlib libtucsen.a
Installing library ../../../lib/linux-x86_64/libtucsen.a
make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/src/O.linux-x86_64'
make -C ./Db install
       main::expandRelease(HASH(0x556cac1205e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
mkdir O.Common
make[3]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/Db/O.linux-x86_64'
       main::expandRelease(HASH(0x555b4686a5b8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/tucsenApp/Db/O.linux-x86_64'
make -C ./iocs install
       main::expandRelease(HASH(0x557ad1e775d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
make -C ./tucsenIOC install
       main::expandRelease(HASH(0x55f0880d15d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
       main::expandRelease(HASH(0x5641de5fd5d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
mkdir O.Common
make[4]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/configure/O.linux-x86_64'
       main::expandRelease(HASH(0x555dead625e8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
       main::expandRelease(HASH(0x563577ae9c88)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
       main::expandRelease(HASH(0x563577b138f8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 222
       main::checkRelease called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 86
make[4]: Leaving directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/configure/O.linux-x86_64'
       main::expandRelease(HASH(0x562acc1675d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
       main::expandRelease(HASH(0x560f5669c5d8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
mkdir O.Common
make[5]: Entering directory '/opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC/tucsenApp/src/O.linux-x86_64'
       main::expandRelease(HASH(0x556d8dd6a5a8)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../in
clude/os/Linux -I../../../include   -I../../../../../include   -I/opt/epics/synApps/support/asyn-R4-33/include     -I/opt/epics/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/opt/epics/synApp
s/support/areaDetector-master/ADSupport/include   -I/opt/epics/synApps/support/areaDetector-master/ADCore/include  -I/opt/epics/synApps/support/autosave-R5-9/include/os/Linux -I/opt/epics/synApps/support/autosa
ve-R5-9/include   -I/opt/epics/synApps/support/busy-R1-7/include   -I/opt/epics/synApps/support/calc-R3-7-1/include   -I/opt/epics/synApps/support/seq-2-2-5/include   -I/opt/epics/synApps/support/sscan-R2-11-1/
include  -I/opt/epics/synApps/support/iocStats-3-1-15/include/os/Linux -I/opt/epics/synApps/support/iocStats-3-1-15/include -I/opt/epics/base-3.15.5/include/compiler/gcc -I/opt/epics/base-3.15.5/include/os/Linu
x -I/opt/epics/base-3.15.5/include        -MM -MF tucsenAppMain.d  ../tucsenAppMain.cpp
Creating dbd file tucsenApp.dbd
perl -CSD /opt/epics/base-3.15.5/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/opt/epics/synApps/support/asyn-R4-33/dbd -I/opt/epics/synApps/support/areaDetector-
master/ADCore/dbd -I/opt/epics/synApps/support/autosave-R5-9/dbd -I/opt/epics/synApps/support/busy-R1-7/dbd -I/opt/epics/synApps/support/calc-R3-7-1/dbd -I/opt/epics/synApps/support/seq-2-2-5/dbd -I/opt/epics/s
ynApps/support/sscan-R2-11-1/dbd -I/opt/epics/synApps/support/iocStats-3-1-15/dbd -I/opt/epics/base-3.15.5/dbd -o tucsenApp.dbd tucsenSupport.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDFile
NetCDF.dbd NDFileMagick.dbd NDFileTIFF.dbd NDFileJPEG.dbd NDFileNexus.dbd NDFileHDF5.dbd asyn.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd
perl -CSD /opt/epics/base-3.15.5/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/opt/epics/synApps/support/asyn-R4-33/dbd -I/opt/epics/synApps/supp
ort/areaDetector-master/ADCore/dbd -I/opt/epics/synApps/support/autosave-R5-9/dbd -I/opt/epics/synApps/support/busy-R1-7/dbd -I/opt/epics/synApps/support/calc-R3-7-1/dbd -I/opt/epics/synApps/support/seq-2-2-5/d
bd -I/opt/epics/synApps/support/sscan-R2-11-1/dbd -I/opt/epics/synApps/support/iocStats-3-1-15/dbd -I/opt/epics/base-3.15.5/dbd    -o tucsenApp_registerRecordDeviceDriver.cpp ../O.Common/tucsenApp.dbd tucsenApp
_registerRecordDeviceDriver /opt/epics/synApps/support/areaDetector-master/ADTucsen/iocs/tucsenIOC
x -I/opt/epics/base-3.15.5/include        -MM -MF tucsenApp_registerRecordDeviceDriver.d  tucsenApp_registerRecordDeviceDriver.cpp
       main::expandRelease(HASH(0x56454ea9a630)) called at /opt/epics/base-3.15.5/bin/linux-x86_64/convertRelease.pl line 76
AreaDetector R3-4 module build error David Vine via Tech-talk
Re: AreaDetector R3-4 module build error Mark Rivers via Tech-talk
RE: AreaDetector R3-4 module build error Mark Rivers via Tech-talk
Prev: RE: AreaDetector R3-4 module build error Mark Rivers via Tech-talk
Next: Cannot execute application on ARM target 刘佳 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: proxy authentication for standard cs-studio Jignesh Patel via Tech-talk
ANJ, 11 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
