1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Segmentation Fault when exiting certain Area Detector IOCs
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
Date: Fri, 18 Jan 2019 16:35:27 +0000
Hello EPICS Tech-Talk!
I have a question regarding a segmentation fault I am getting when exiting certain area detector IOCs. Thus far, I have noticed it on several detectors, including a prosilica IOC and a new driver I have developed for USB Video Class cameras. In the IOC shell, the only information given is:
Segmentation Fault: line of st.cmd file that calls ioc binary.
Using the Visual Studio Code debugger I was able to trace the segmentation fault to the following function in the asynPortDriver.cpp file:
extern "C" {static asynStatus connect(void *drvPvt, asynUser *pasynUser)
    asynPortDriver *pPvt = (asynPortDriver *)drvPvt;
    asynStatus status;
    pPvt->lock();
    status = pPvt->connect(pasynUser);
    pPvt->unlock();
    return(status);
and it occurs in the line pPvt->lock(), meaning that most likely pPvt is NULL. Is there anything I should check for that could be causing this?
Thank you all in advance,
Jakub Wlodek
Re: Segmentation Fault when exiting certain Area Detector IOCs Mark Rivers via Tech-talk
Prev: NI PXI 7334 motion controller Koennecke Mark (PSI) via Tech-talk
Next: Re: Segmentation Fault when exiting certain Area Detector IOCs Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
ANJ, 18 Jan 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
