1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS CSS with OPC UA
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 30 Jan 2019 13:02:31 +0100
Hi Abhay,
What requirement is it that doesn't allow you to use Channel Access?
Cheers,
~Ralph
On Wed, 30 Jan 2019 at 12:56, Abhijit Bhopale via Tech-talk <[email protected]> wrote:
Hi Team,
I am using EPICS OPI(Operator Interface) and the PVs on GUI are updated by channel access protocol used IOCs.
Due to some security requirement currently, we won't be able to continue using channel access protocol.
Is it feasible If I replace all the IOCs with OPC UA server but want to continue with same Operator OPI?
So in general OPI will get all the PV updates from the protocol supported by OUC UA and not Channel Access. (In this approach the IOC PV name and OPC UA tag name will be same)
Anyone have ever tried this? What can I do to achieve this?
Any suggestions/solution approaches are welcome.
Best Regards,
Abhay
Re: EPICS CSS with OPC UA Abhijit Bhopale via Tech-talk
Prev: EPICS CSS with OPC UA Abhijit Bhopale via Tech-talk
Next: Re: EPICS CSS with OPC UA Abhijit Bhopale via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
