1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Weird stream device behavior when using the IOC shell's exit function
To: Abdalla Ahmad <[email protected]>
Date: Mon, 4 Feb 2019 14:33:32 +0000
Hi Abdalla,
> asynError in write. Asyn driver says: device:port disconnected.
During IOC shutdown asyn does close all TCP ports.  However, record processing should have already been shut down, so I don't understand why you are getting that message from Stream.
Another problem we are facing with this new setup is that I can't find some asyn IOC shell function like asynTraceMask for example. The IOC is configured properly in RELEASE and src/Makefile. Is there anything we miss in the new setup?
> But eventually the IOC exits. For the gamma controllers we get something really strange.
> There a point in the database where the IOC never exits, the exit command just freezes and Ctrl-C is the only way to shut down the IOC.
I don't think I have seen that with Stream on any version of Stream/asyn/base that I have used.  That includes base 3.14.12, 3.15.5, 7.0.2.
If you run the IOC with gdb then when you type exit and it hangs do the following:
- Type Ctrl-C
- Enter the gdb command
thread apply all bt
That will show you the current stack trace for all threads.  You can then see what is blocking the threads.
The command is not "asynTraceMask" it is "asynSetTraceMask" or "asynSetTraceIOMask".
What asyn commands do you see if you type "help" at the iocsh prompt?
From: [email protected] <[email protected]> on behalf of Abdalla Ahmad via Tech-talk <[email protected]>
Sent: Monday, February 4, 2019 1:41 AM
To: [email protected]
Subject: Weird stream device behavior when using the IOC shell's exit function
Hi
We are using the following setup to test control of the agilent XGS gauge controllers and Gamma ion pump controllers:
1.       EPICS Base 3.15.6
2.       Asyn R4-33
3.       Stream R2-7-7c
For agilent controllers we get the following error:
But eventually the IOC exits. For the gamma controllers we get something really strange. There a point in the database where the IOC never exits, the exit command just freezes and Ctrl-C is the only way to shut down the IOC. For now I can see that this behavior occurs because more DB substitutions are configured which means more PVs and more controllers. But that was not the case when we had:
1.       EPICS Base 3.14.12.3
2.       Asyn R4-18
3.       Stream R2-5-1
Where the IOC exits with no errors or freezing. Should we upgrade our support modules or change the EPICS base?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
http://www.sesame.org.jo/
Re: Weird stream device behavior when using the IOC shell's exit function Abdalla Ahmad via Tech-talk
Prev: Weird stream device behavior when using the IOC shell's exit function Abdalla Ahmad via Tech-talk
Next: Re: Weird stream device behavior when using the IOC shell's exit function Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 04 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
