1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS Qt 3.6.4 [SEC=UNOFFICIAL]
From: "STARRITT, Andrew via Tech-talk" <[email protected]>
Date: Wed, 6 Feb 2019 07:57:37 +0000
Hi all,
EPICS Qt 3.6.4 has been released and available at GitHub.
This is available at https://github.com/qtepics with guidance and release notes
Note: there was an unannounced release just before Christmas, so be sure to read
the r3.6.3 release notes as well.
All the repositories (apart from the binaries) have been tagged r3.6.4
All the https://qtepics.github.io guidance files are now markdown (as opposed
to being converted from .docx files to .html files) so look a lot “cleaner”.
After sending this e-mail, I’ll be starting to integrate release 3.7.1 changes from
our local source repository to the GitHub’s repos. The 3.7 series incorporates
PV Access. Until 3.7.1 is formally release I would stick to the r3.6.4 tag files.
However, if you are feeling adventurous and want to build from the HEAD files,
as a minimum you will need to pull in the acai library (new dependency) available
from https://github.com/andrewstarritt/acai and modify the qeframework’s
configure RELASE file to update ACAI definition.
More details when 3.7.1 is actually released.
Cheers
Andrew C Starritt
Manager - Accelerator Controls and Support Systems
Australian Synchrotron
Tel
Email
Web
+61 3 8540 4164
[email protected]
www.ansto.gov.au
Important: This transmission is intended only for the use of the intended addressee. It is confidential to the intended addressee and may contain privileged information and or copyright material. If this email is not intended for your attention, any use, printing, storage, reproduction or further disclosure of this communication (including all attachments) is strictly forbidden. If you have received this transmission in error, please notify me by telephone or email and immediately delete all copies of this transmission as well as any attachments.
Prev: RE: Weird stream device behavior when using the IOC shell's exit function Abdalla Ahmad via Tech-talk
Next: Re: EPICS7.0.2 "make distclean" in a model deletes top level configure dir Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS7.0.2 "make distclean" in a model deletes top level configure dir Ralph Lange via Tech-talk
Next: EPICS June 2019: Sessions and Workshops Ralph Lange via Tech-talk
ANJ, 06 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
