1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error in installing EtherCAT coupler module
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Cc: Harshal Sheth <[email protected]>
Date: Wed, 13 Feb 2019 09:10:50 +0100
Dear Harshal,
Your error messages look like you are trying to compile Linux software on a Windows machine.
Can you be more specific on which version of which software you have downloaded from which site? The EPICS website at https://epics-controls.org has a link to a download page at Diamond light source that says the current version of their EtherCAT software is on GitHub.
Cheers,
~Ralph
On Wed, 13 Feb 2019 at 08:58, Harshal Sheth via Tech-talk <[email protected]> wrote:
I am having an error while building etherCAT coupler module which I downloaded from the EPICS website.
The error occurring is shown below.
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(113) : warning C4013: 'pthread_mutexattr_setprotocol' undefined; assuming extern returning int
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(113) : error C2065: 'PTHREAD_PRIO_INHERIT' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(130) : error C2143: syntax error : missing ';' before 'type'
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(131) : error C2065: 'slot' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(131) : error C2100: illegal indirection
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(131) : warning C4018: '<' : signed/unsigned mismatch
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(133) : error C2065: 'slot' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(133) : error C2100: illegal indirection
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(135) : error C2065: 'slot' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(135) : warning C4022: 'memcpy' : pointer mismatch for actual parameter 2
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(154) : error C2143: syntax error : missing ';' before 'type'
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(155) : error C2065: 'slot' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(155) : error C2100: illegal indirection
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(155) : warning C4018: '<' : signed/unsigned mismatch
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(157) : error C2065: 'slot' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(157) : error C2100: illegal indirection
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(159) : error C2065: 'slot' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(159) : warning C4022: 'memcpy' : pointer mismatch for actual parameter 2
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(184) : error C2143: syntax error : missing ';' before 'type'
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(185) : error C2065: 'slot' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(185) : error C2100: illegal indirection
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(186) : error C2065: 'slot' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(186) : warning C4022: 'memcpy' : pointer mismatch for actual parameter 1
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(211) : warning C4018: '>' : signed/unsigned mismatch
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(226) : error C2143: syntax error : missing ';' before 'type'
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(227) : error C2065: 'slot' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(227) : error C2100: illegal indirection
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(228) : error C2065: 'slot' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(228) : warning C4022: 'memcpy' : pointer mismatch for actual parameter 1
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(274) : error C2275: 'TIMER_MESSAGE' : illegal use of this type as an _expression_
        c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(22) : see declaration of 'TIMER_MESSAGE'
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(274) : error C2146: syntax error : missing ';' before identifier 'msg'
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(274) : error C2065: 'msg' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(275) : error C2065: 'msg' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(275) : error C2224: left of '.tag' must have struct/union type
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(276) : warning C4013: 'clock_gettime' undefined; assuming extern returning int
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(276) : error C2065: 'CLOCK_MONOTONIC' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(280) : warning C4013: 'clock_nanosleep' undefined; assuming extern returning int
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(280) : error C2065: 'CLOCK_MONOTONIC' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(280) : error C2065: 'TIMER_ABSTIME' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(281) : error C2065: 'msg' : undeclared identifier
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(281) : error C2224: left of '.ts' must have struct/union type
c:\epics\modules\ethercat-master\ethercatapp\rtutilssrc\rtutils.c(282) : error C2065: 'msg' : undeclared identifier
make[3]: *** [C:/EPICS/base-3.15.6/configure/RULES_BUILD:232: rtutils.obj] Error 2
make[3]: Leaving directory 'C:/EPICS/modules/ethercat-master/ethercatApp/rtutilsSrc/O.windows-x64'
make[2]: *** [C:/EPICS/base-3.15.6/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[2]: Leaving directory 'C:/EPICS/modules/ethercat-master/ethercatApp/rtutilsSrc'
make[1]: *** [C:/EPICS/base-3.15.6/configure/RULES_DIRS:84: rtutilsSrc.install] Error 2
make[1]: Leaving directory 'C:/EPICS/modules/ethercat-master/ethercatApp'
make: *** [C:/EPICS/base-3.15.6/configure/RULES_DIRS:84: ethercatApp.install] Error 2
Please help me as I have to work on etherCAT in my project.
Thank you,
Harshal Sheth
RE: Error in installing EtherCAT coupler module ronaldo.mercado--- via Tech-talk
Error in installing EtherCAT coupler module Harshal Sheth via Tech-talk
Prev: Error in installing EtherCAT coupler module Harshal Sheth via Tech-talk
Next: RE: Error in installing EtherCAT coupler module ronaldo.mercado--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 13 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
