1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: archiverAppliance access to
From: Gabriel de Souza Fedel via Tech-talk <[email protected]>
Date: Fri, 15 Feb 2019 13:06:12 +0000
Hi Heinz,
A colleague from LNLS developed a archiver version that uses LDAP to
authenticate users and control access:
https://github.com/lnls-sirius/epicsarchiverap-ldap
There is a docker to configure and run it:
https://github.com/lnls-sol/docker-epics-archiver-appliances
Best Regards
On 15/02/2019 10:26, Heinz Junkes via Tech-talk wrote:
> Does anyone have a solution how to regulate the access (especially writing and modifying)
> to the archiverAppliance?
> For example, I would like everyone to be able to view all archived PVs (via the built-in viewer)
> but only certain users can  add/delete/change PVs.
> Heinz
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1073
www.lnls.cnpem.br
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
archiverAppliance access to Heinz Junkes via Tech-talk
Prev: archiverAppliance access to Heinz Junkes via Tech-talk
Next: Re: archiverAppliance access to Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
