1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How fast can EPICS communicate with a device?
Date: Fri, 15 Feb 2019 14:24:52 +0000
Sorry I missed that you added .01 second in the dbd file, so ignore that question.
I suspect you are getting a timeout if you only get 1 Hz. Turn on asynTrace to see what is happening on the communication link.
What device support are you using? StreamDevice, asyn device support, etc.?
Sent from my iPhone
> On Feb 15, 2019, at 8:20 AM, Mark Rivers via Tech-talk <[email protected]> wrote:
> There is no limit in the speed of communicating with EPICS, only the speed of the link and the device latency.
> How did you get SCAN=.01 second? Did you redefine the EPICS scan rates?
> If you want to go as fast as possible you cannot use periodic scanning. You can use a set of FNLKs that for a loop or other mechanism to scan faster.
> Are you using an asyn serial or IP port driver? If so you can turn in asynTrace to get time stamped messages to measure performance.
> Mark
> Sent from my iPhone
> On Feb 15, 2019, at 8:05 AM, Sobhani, Bayan via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
> What exactly are the limitations on how fast EPICS can communicate with a device?
> I have a device I can communicate with around 200Hz if I send it commands with a python program that uses the telnetlib module. I was wondering if it would be possible for the device to communicate with EPICS close to this rate.
> I tried modify EPICS database definition files to make records process faster. To test this, I made a PV that does no device communication, but counts up when it was processed. When I added a line in the dbd file to add a scan option of .01 second, and set the SCAN field to .01, this record increases by 100 every second when I run the IOC, which is expected behavior.
> However, when I tried having this record send commands to the device, it was much slower, around once per second. In general, when I process PVs that communicate with a device, it seems to take a while to get a response, whereas when I send commands directly through telnet I get the result back almost instantaneously.  Is there a limit to how fast EPICS can communicate with a device, apart from the SCAN field options?
> Alex
Re: How fast can EPICS communicate with a device? Dirk Zimoch via Tech-talk
RE: How fast can EPICS communicate with a device? Sobhani, Bayan via Tech-talk
Re: How fast can EPICS communicate with a device? Mark Rivers via Tech-talk
Prev: Re: How fast can EPICS communicate with a device? Mark Rivers via Tech-talk
Next: Re: How fast can EPICS communicate with a device? Dirk Zimoch via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
