1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: Problems with StreamDevice
From: "Zimoch Dirk \(PSI\) via Tech-talk" <[email protected]>
Date: Fri, 15 Feb 2019 19:19:39 +0000
People here at PSI had complained about error message flooding when devices go crazy or are offline. Softiocs had filled their disks with logs and such.
Thus I have heavily reduced the amount of error output.
StreamDevice sets asynTraceMask to 0. This has already been reported as a bug arguing it is not StreamsDevice‘s responsibility to silence other code. And it does so in iocInit, so that user settings in the startup script are ignored. I am somewhat convinced that this is a valid argument and will change it soon.
StreamDevice suppresses its own error messages by default now. You can re-enable error messages with var streamError 1.
In the first 2.8 versions this also suppressed parsing errors which was very inconvenient. This should not happen any more. Errors are enabled while reading the protocol file. I will check in which version this is the case on Monday. But I thought this was already fixed in 2.8.8.
I always wanted to rework the error and debug message system, in particular to allow filtering per record, but I never found the time.
Dirk
Am 15.02.2019 um 19:17 schrieb Mark Rivers <[email protected]>:
I am running StreamDevice 2.8.8.  I am having 3 issues.  I don’t know if these are bugs or features, because I cannot find the release notes for StreamDevice.  Where are they located?
1)      StreamDevice seems to set asynTraceMask to 0 for the port.
This is my startup script.
< envPaths
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in this build from CARS
dbLoadDatabase("../../dbd/CARSLinux.dbd")
CARSLinux_registerRecordDeviceDriver(pdbbase)
drvAsynIPPortConfigure("PORT","gse-tetramm2:10001",0,0,0)
asynOctetSetInputEos(PORT, 0, "\r\n")
asynOctetSetOutputEos(PORT, 0, "\r")
asynSetTraceIOMask(PORT, 0, 2)
asynSetTraceMask(PORT, 0, 9)
asynSetOption(PORT, 0, "disconnectOnReadTimeout", "Y")
dbLoadRecords("stream2.db", "P=13TEST:, R=R:, PORT=PORT")
dbLoadRecords("$(ASYN)/db/asynRecord.db", "P=13TEST:, R=asyn1, PORT=PORT, ADDR=0, IMAX=80, OMAX=80")
iocInit
Note that it sets the trace mask to 9 with asynSetTraceMask.  However, when I boot and look at the trace mask with asynReport it is 0.  The TraceIOMask is 2 like I set it, but the traceMask is 0.
epics> asynReport 10
PORT multiDevice:No canBlock:Yes autoConnect:Yes
    enabled:Yes connected:Yes numberConnects 1
    nDevices 0 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 5 exceptionNotifys 0
    traceMask:0x0 traceIOMask:0x2 traceInfoMask:0x1
    interposeInterfaceList
        asynOctet pinterface 0x1da89e0 drvPvt 0x3624870
    interfaceList
        asynCommon pinterface 0x1ce6770 drvPvt 0x3620c10
        asynOption pinterface 0x1ce6790 drvPvt 0x3620c10
        asynOctet pinterface 0x3620d30 drvPvt 0x3620c10
    Port gse-tetramm2:10001: Connected
                    fd: 5
    Characters written: 152
       Characters read: 208
If I uncomment the line that loads the StreamDevice records then asynTrace is set correctly when I boot.
#dbLoadRecords("stream2.db", "P=13TEST:, R=R:, PORT=PORT")
    exceptionActive:No exceptionUsers 2 exceptionNotifys 0
    traceMask:0x9 traceIOMask:0x2 traceInfoMask:0x1
        asynOctet pinterface 0x1da89e0 drvPvt 0x2c6b830
    interfaceList
        asynCommon pinterface 0x1ce6770 drvPvt 0x2c67bd0
        asynOption pinterface 0x1ce6790 drvPvt 0x2c67bd0
        asynOctet pinterface 0x2c67cf0 drvPvt 0x2c67bd0
                    fd: 6
    Characters written: 0
       Characters read: 0
If I put the asynSetTraceMask after iocInit it works.  Is this indeed something StreamDevice is doing?
2)      If I have an error in my protocol file I am not seeing any error messages.  I used to see them in previous versions.
This is what the protocol should be, command is CHN.
readChans {
   out "CHN:?";
   in "CHN:%d";
If I break the protocol by changing CHN to CHAN
readChans {
   out "CHAN:?";
   in "CHAN:%d";
then this is what I see with asynTrace on.  Note that the CHAN:? command returned NAK:00 which the protocol won’t parse.
2019/02/15 12:07:15.074 gse-tetramm2:10001 write 7
CHAN:?\r
2019/02/15 12:07:15.075 gse-tetramm2:10001 read 8
NAK:00\r\n
2019/02/15 12:07:15.077 gse-tetramm2:10001 write 6
HVV:?\r
2019/02/15 12:07:15.078 gse-tetramm2:10001 read 10
HVV:0.00\r\n
The record is indeed in invalid alarm but I don’t see any error messages from StreamDevice (STAT=CALC, SEVR=INVALID).  Is this new behavior to see no errors?
epics> dbpr 13TEST:R:Chans 3
ACKS: INVALID       ACKT: YES           ADEL: 0             AFTC: 0
AFVL: 0             ALST: 0             AOFF: 0             ASG :
ASLO: 1             BKPT: 00            DESC:               DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DTYP: stream
EGU :               EGUF: 0             EGUL: 0             EOFF: 0
ESLO: 1             EVNT:               FLNK: CONSTANT      HHSV: NO_ALARM
HIGH: 0             HIHI: 0             HOPR: 0             HSV : NO_ALARM
HYST: 0             INIT: 0
INP : INST_IO @stream2.proto readChans PORT 0 0             LALM: 0
LBRK: 0             LCNT: 0             LINR: NO CONVERSION LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW : 0             LSV : NO_ALARM
MDEL: 0             MLST: 0             NAME: 13TEST:R:Chans
NSEV: NO_ALARM      NSTA: NO_ALARM      ORAW: 0             PACT: 0
PHAS: 0             PINI: NO            PREC: 0             PRIO: LOW
PROC: 0             PUTF: 0             ROFF: 0             RPRO: 0
RVAL: 0             SCAN: 1 second      SDIS: CONSTANT      SDLY: -1
SEVR: INVALID       SIML: CONSTANT      SIMM: NO            SIMS: NO_ALARM
SIOL: CONSTANT      SMOO: 0             SSCN: <nil>         STAT: CALC
SVAL: 0             TIME: 2019-02-15 12:10:16.524791659     TPRO: 0
TSE : 0             TSEL: CONSTANT      UDF : 1             UDFS: INVALID
VAL : 0
3)      If I have a communications error I don’t see any error messages.  I used to see them in previous versions.  This is what I see when I disconnect the cable to my device.
2019/02/15 12:12:18.494 gse-tetramm2:10001 read 10
HVV:0.00\r\n
2019/02/15 12:12:19.488 gse-tetramm2:10001 write 7  CABLE DISCONNECTED
TEMP:?\r
2019/02/15 12:12:36.488 gse-tetramm2:10001 write 7
TEMP:?\r
2019/02/15 12:12:36.489 gse-tetramm2:10001 read 9
There are no error messages from StreamDevice.  This is with disconnectOnReadTimeout=Y, but there are no messages with that not set either.
RE: Problems with StreamDevice Mark Rivers via Tech-talk
Prev: Problems with StreamDevice Mark Rivers via Tech-talk
Next: RE: Problems with StreamDevice Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
ANJ, 15 Feb 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
