1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Issue of PV callback of PyEpics
From: Matthew Newville via Tech-talk <[email protected]>
To: "Zhang, Tong" <[email protected]>
Date: Mon, 18 Feb 2019 16:49:42 -0600
On Mon, Feb 18, 2019, 4:30 PM Zhang, Tong via Tech-talk <[email protected] wrote:
Hello,
When I work with PyEpics.PV object, I've found sometimes the value of 'char_value' in the added callback just return what 'value' meant to be. I tried with a MBBI type record, it should be expected as a string in the callback, but an integer was got. Could somebody let me know what is the possible reason?
An mbbi record definitely should return the appropriate string in 'char_value' in a callback.  That does need to be able to lookup the CTRL values, especially including the enumeration strings.
Can you do
    mypv = epics.PV(pvname)
    print(mypv.get(as_string=True))
    print(mypv.get_info())
and see the enumeration strings?
Matt
Re: Issue of PV callback of PyEpics Tong Zhang via Tech-talk
Issue of PV callback of PyEpics Zhang, Tong via Tech-talk
Prev: Issue of PV callback of PyEpics Zhang, Tong via Tech-talk
Next: EPICS support with Turbo UMAC fengwentian--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: Issue of PV callback of PyEpics Tong Zhang via Tech-talk
ANJ, 19 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
