1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: print all information about a PV including units
To: rachid ayad <[email protected]>
Date: Wed, 20 Feb 2019 14:53:34 +0000
Note that EGU for BUNCH is DBF_STRING which is correct. I think POS.PXP may be an invalid record name.
Sent from my iPhone
On Feb 20, 2019, at 8:50 AM, rachid ayad <[email protected]<mailto:[email protected]>> wrote:
  I used another PV that does not have a point in it: (Also I used in the caget command "-a" option because they said it prints more info but there was an error as seen below)
cainfo FBH:BCM:NBUNCH.EGU
FBH:BCM:NBUNCH.EGU
    State:            connected
    Host:             130.87.82.88:5064<http://130.87.82.88:5064>
    Access:           read, no write
    Native data type: DBF_STRING
    Request type:     DBR_STRING
    Element count:    1
labm@labmpc:~$ caget -a BMH:MQC2LE:POS.PXP.EGU
BMH:MQC2LE:POS.PXP.EGU         <undefined> 0 UDF INVALID
On Wed, Feb 20, 2019 at 11:40 PM Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Something looks wrong. Why does the EGU field have type DBF_DOUBLE?
Is the problem the . In the record name?
Sent from my iPhone
On Feb 20, 2019, at 8:36 AM, rachid ayad via Tech-talk <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
 Dear Bastian, Is still the same:
caget BMH:MQC2LE:POS.PXP.EGU
BMH:MQC2LE:POS.PXP.EGU         0
labm@labmpc:~$ cainfo BMH:MQC2LE:POS.PXP.EGU
    State:            connected
    Host:             130.87.82.88:5064<http://130.87.82.88:5064><http://130.87.82.88:5064>
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    1
I think maybe they did not set the units when they created the PV???
Thank you, Rachid
On Wed, Feb 20, 2019 at 11:03 PM Dr. Bastian Löher <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
Dear Rachid,
one way would be to directly request the .EGU field of the PV, i.e.
All the best
Bastian
On 190220-1321, rachid ayad via Tech-talk wrote:
>  Dear All,
> I would like to ask you how print wide information about a PV using the
> epics command cainfo. For example a cainfo shell command gives:
> BMH:MQC2LE:POS.PXP
>     State:            connected
>     Host:             abcob02.kek.jp:5064<http://abcob02.kek.jp:5064><http://abcob02.kek.jp:5064>
>     Element count:    1
> without units and I tried all options given in "caninfo -h" but did not
> work. I found I can do it in a C code to print the val structure but I need
> it in shell command
> Thank you, Rachid
> Dr. Rachid Ayad
> Department of Physics, Faculty of Science
> University Of Tabuk
> P.O. Box 2072
> Tabuk 71451
> Kingdom Of Saudi Arabia
> Tel: +966560296632
> This message and its
> attachment, if any, are confidential and may contain legally privileged
> information. If you are not the intended recipient, please contact the
> sender immediately and delete this message and its attachment , if any,
> from your system. You should not copy this message or disclose its contents
> to any other person or use it for any purpose. Statements and opinions
> expressed in this e-mail are those of the sender, and do not necessarily
> reflect those of University of Tabuk. University of Tabuk Accepts no
> liability for any damage caused by any virus transmitted by this email.
Dr. Bastian Löher
Data acquisition
Experiment controls
Detector development
R3B - Relativistic reactions with radioactive beams
Gamma spectroscopy
-- TU Darmstadt ---------------------------------------------------------------
Room / Raum: S2|14 418
Phone / Telefon: +49 6151 23532
Mobile / Mobil: +49 162 5467038
E-Mail: [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>
Institut für Kernphysik
Technische Universität Darmstadt
Schlossgartenstrasse 9, 64289 Darmstadt
http://www.ikp.tu-darmstadt.de
-- GSI ------------------------------------------------------------------------
Room / Raum: SB3 3.199
Phone / Telefon: +49 6159 71 2739, 3272
Fax: +49 6159 71 3007
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1, 64291 Darmstadt, Germany, www.gsi.de<http://www.gsi.de><http://www.gsi.de>
Commercial Register / Handelsregister: Amtsgericht Darmstadt, HRB 1528
Managing Directors / Geschäftsführung:
Professor Dr. Paolo Giubellino, Ursula Weyrich, Jörg Blaurock
Chairman of the Supervisory Board / Vorsitzender des GSI-Aufsichtsrats:
State Secretary / Staatssekretär Dr. Georg Schütte
Dr. Rachid Ayad
University Of Tabuk
P.O. Box 2072
Tabuk 71451
Tel: +966560296632
This message and its attachment, if any, are confidential and may contain legally privileged information. If you are not the intended recipient, please contact the sender immediately and delete this message and its attachment , if any, from your system. You should not copy this message or disclose its contents to any other person or use it for any purpose. Statements and opinions expressed in this e-mail are those of the sender, and do not necessarily reflect those of University of Tabuk. University of Tabuk Accepts no liability for any damage caused by any virus transmitted by this email.
Dr. Rachid Ayad
University Of Tabuk
P.O. Box 2072
Tabuk 71451
Tel: +966560296632
print all information about a PV including units rachid ayad via Tech-talk
Re: print all information about a PV including units Dr. Bastian Löher via Tech-talk
Re: print all information about a PV including units rachid ayad via Tech-talk
Re: print all information about a PV including units Mark Rivers via Tech-talk
Prev: Re: print all information about a PV including units rachid ayad via Tech-talk
Next: Re: print all information about a PV including units Marty Kraimer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 20 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
