1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Pro-Dex Oregon Micro Systems EPICS hardware support
From: Heinz Junkes via Tech-talk <[email protected]>
To: Earl Green <[email protected]>
Date: Fri, 22 Feb 2019 09:33:01 +0100
Hi Earl,
we are using MAXv-Cards with MVME6100 and RTEMS. I can provide a bootable image for it.
This should work with the MVME5500 too.
I'm also willing to buy another Maxv card for testing.
We are planning to upgrade our FEL and need new motor controller hardware.
Heinz
> On 22. Feb 2019, at 01:04, Earl Green via Tech-talk <[email protected]> wrote:
> Hi Kevin,
> Thanks for getting back to me. I will keep a look out for changes related to the motor repository splitting.
> In order to test the drivers for the MAXv, I am planning to use a VME rack with Emerson MVME 5500 card. I believe the card was tested in the past by booting RTEM with EPICS from a server using FTP. For testing a MAXv or MAXnet, what are your suggestions for an operating system and boot method? I have found on the EPICS website how to boot a soft IOC Linux box. It appears that Linux is now more of the movement to run EPICS on than RTEMS.
> Earl
> Earl Green | Software Engineer
> 800.707.8111 (Main)
> 503.629.8081 (Office)
> 503.629.0688 (Fax)
> [email protected]
> Visit our website: www.OMSmotion.com
> <Outlook-1499788583.png>
> From: Peterson, Kevin M. <[email protected]>
> Sent: Wednesday, February 20, 2019 2:56 PM
> To: Rivers, Mark L.; Earl Green
> Cc: [email protected]
> Earl,
> Everything Mark said is correct.  I hope to begin the split of the motor
> repository very soon.
> I subscribe to tech-talk, but the number of unread tech-talk messages in
> my inbox is usually much higher than I care to admit.
> Kevin
> On 2/19/19 6:32 PM, Mark Rivers via Tech-talk wrote:
> > Hi Earl,
> > The EPICS motor software is in this repository on Github:
> > https://github.com/epics-modules/motor
> > The software for your company’s products is in these 2 directories:
> > https://github.com/epics-modules/motor/tree/master/motorApp/OmsSrc
> > https://github.com/epics-modules/motor/tree/master/motorApp/OmsAsynSrc
> > There is a plan to split up the motor repository into a base module with
> > the core code, and then separate repositories for each vendor.  I think
> > this is planned for the near future.
> > The best person to talk to is Kevin Peterson at the Advanced Photon
> > Source at Argonne ([email protected] <mailto:[email protected]>).
> > Mark
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Pro-Dex Oregon Micro Systems EPICS hardware support Earl Green via Tech-talk
RE: Pro-Dex Oregon Micro Systems EPICS hardware support Mark Rivers via Tech-talk
Re: Pro-Dex Oregon Micro Systems EPICS hardware support Peterson, Kevin M. via Tech-talk
Re: Pro-Dex Oregon Micro Systems EPICS hardware support Earl Green via Tech-talk
Prev: Re: GNU Screen or procServ on ARM? Florian Feldbauer via Tech-talk
Next: Re: Point Grey GigE Blackfly conflict Nilson Pereira via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Pro-Dex Oregon Micro Systems EPICS hardware support Earl Green via Tech-talk
Next: print all information about a PV including units rachid ayad via Tech-talk
ANJ, 22 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
