1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: Fw: asynDriver - update record (timestamp), on no change
From: Rod Nussbaumer via Tech-talk <[email protected]>
Date: Fri, 1 Mar 2019 14:17:58 +0000
Does this mean that the records with unchanged data but new timestamps
will post monitors to subscribed clients on each 'update'? That would
potentially introduce a lot of unnecessary/unwanted CA traffic.
    --- rod.
On 2/28/19 11:15 AM, Mark Rivers via Tech-talk wrote:
> ________________________________
> From: Mark Rivers
> Sent: Thursday, February 28, 2019 12:35 PM
> To: Joao Afonso
> Subject: Re: asynDriver - update record (timestamp), on no change
> Your proposed hack is indeed the workaround for now.  It would be nice to add another way to do this, perhaps forceParamCallback(addr, param).
> Mark
> From: [email protected] <[email protected]> on behalf of Joao Afonso via Tech-talk <[email protected]>
> Sent: Thursday, February 28, 2019 11:16 AM
> To: [email protected]
> Subject: asynDriver - update record (timestamp), on no change
> Hello,
> I have an asyn driver IOC that periodically receives new data, updates the parameters (and timestamps), and runs the callbacks for the "I/O Intr" records.
> It has an extra thread that runs something like this:
> while(1)
>      int value = wait_for_data();
>      setIntegerParam(dev_addr, param_id, value)
>      updateTimeStamp();
>      callParamCallbacks(dev_addr);
> However, 'callParamCallbacks' will not update the record timestamp if the value received keeps being the same.
>  From what I understand, this is the intended behaviour of asynDriver - no updates if data is the same -, but I would like to know if there a way to enforce it (to update the record timestamp)?
> One possible solution I think will work is to update the parameter with a random value first, to trigger the 'new data' flag, but it feels like an hack...
> Example:
> setIntegerParam(dev_addr, param_id, 0)
> Thank you,
> Joao Afonso
Re: Fw: asynDriver - update record (timestamp), on no change Ralph Lange via Tech-talk
asynDriver - update record (timestamp), on no change Joao Afonso via Tech-talk
Fw: asynDriver - update record (timestamp), on no change Mark Rivers via Tech-talk
Prev: Re: Basic PVAccess question Marty Kraimer via Tech-talk
Next: Re: Fw: asynDriver - update record (timestamp), on no change Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: Fw: asynDriver - update record (timestamp), on no change Mark Rivers via Tech-talk
ANJ, 01 Mar 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
