1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: Questions about channel access C API programming
From: Wang Xiaoqiang via Tech-talk <[email protected]>
To: Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 5 Mar 2019 17:01:53 +0100
Call ca_flush_io after ca_put.
1. ca_task_initialize is the old API, and creates a non-preemptive context.
2. DBR is for request and DBF is for field type. But plain DBR_XXX has the same value as DBF_XXX.
Best
Xiaoqiang
On 3/5/19 3:08 PM, Abdalla Ahmad via Tech-talk wrote:
Hi
The attached C file is a snippet from a Qt project. In the project there was a function that writes values to many PVs in a loop. What was happening is that some PVs do not get their new value updated immediately but after 3 or 4 seconds. The code shows a similar behavior, two consecutive "ca_put" calls, and the same behavior occurs. I double-checked the database (included in the comments) but there is nothing wrong. I tried to use ca_context_ or ca_task_ but the project crashes maybe because the QE framework is already handling low-level CA. What am I missing here?
Another two questions came up:
1.What is the difference between ca_task_initialize and ca_context_create?
2.What is the difference between request types (DBR_) and field types (DBF_)?
P.S.: We are using Base 3.15.6
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo <http://www.sesame.org.jo/>
Questions about channel access C API programming Abdalla Ahmad via Tech-talk
Prev: Re: Basic PVAccess question Marty Kraimer via Tech-talk
Next: Re: Questions about channel access C API programming Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: Questions about channel access C API programming Abdalla Ahmad via Tech-talk
ANJ, 05 Mar 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
