1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: epics-Keithley_648x, drvAsynKeithley648x
From: Heinz Junkes via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Wed, 6 Mar 2019 10:03:53 +0100
I want to use the ip-driver for the Keithley 6485:
 Description
    This module provides support for a multiple device port driver. To
    initialize the driver, the method drvAsynKeithley6485() is called from the
    startup script with the following calling sequence.
        drvAsynKeithley6485(myport,ioport,ioaddr)
        Where:
            myport - Keithley6485 Asyn interface port driver name (i.e. "EP0" )
            ioport - Communication port driver name (i.e. "S0" )
            ioaddr - Communication port device addr
    The method dbior can be called from the IOC shell to display the current
    status of the driver.
Unfortunately I don't know how to configure the “ioport”.
Right now, here's what I'm gonna try in the st.cmd:
drvAsynIPPortConfigure("MOXA_4", "172.24.192.29:4004", 0, 0, 0)
asynOctetConnect("KeithleyIO", "MOXA_4", "-1",2000)
drvAsynKeithley648x("6485", "MOXA_4","KeithleyIO",0)
asynSetTraceIOMask("MOXA_4", 0, 0x2)
asynSetTraceMask("MOXA_4", 0, 0x9)
dbLoadRecords("db/Keithley6485.db", "P=trARPES:, CA=Sample:, PORT=MOXA_4”)
Unfortunately there is no communication with the device.
How do I configure this correctly?
Danke,
Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Prev: RE: Questions about channel access C API programming Abdalla Ahmad via Tech-talk
Next: Fw: epics-Keithley_648x, drvAsynKeithley648x Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: Re: CA and CS-studio configuration Kacper Kłys via Tech-talk
ANJ, 15 Mar 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
