1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: generalTime/epicsTimeGetCurrent and casr questions
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "Brands Helge (PSI)" <[email protected]>, Mark Rivers <[email protected]>, techtalk <[email protected]>
Date: Wed, 13 Mar 2019 13:06:22 +0000
Can anyone answer how edm, CSS, and PyDM handle this?
edm and CS-Studio connect once and then keep that connection.
This is useful for two reasons.
One is the performance gain respectively reduced load on network and IOCs as you already mentioned.
The other is that we're in a distributed environment.
Your display that has a text entry field or a slider might not be the only tools that's writing to those PVs.
In fact the IOC might just change the PV on its own.
Or you write "105", but the IOC clamps the value at "100".
This means that you always need to monitor a PV that you write.
You move the slider or enter a new value into a text entry field
-> Your tool writes to the PV.
Meanwhile, the PV can be changed by somebody else
-> Your tool needs to show that value in the text entry field, or move the slider to the received value.
Kay
Re: generalTime/epicsTimeGetCurrent and casr questions Jemian, Pete R. via Tech-talk
generalTime/epicsTimeGetCurrent and casr questions Layne (US), William C via Tech-talk
Re: generalTime/epicsTimeGetCurrent and casr questions Mark Rivers via Tech-talk
Re: generalTime/epicsTimeGetCurrent and casr questions Johnson, Andrew N. via Tech-talk
RE: generalTime/epicsTimeGetCurrent and casr questions Mark Rivers via Tech-talk
AW: generalTime/epicsTimeGetCurrent and casr questions Brands Helge (PSI) via Tech-talk
Prev: Re: generalTime/epicsTimeGetCurrent and casr questions Mark Rivers via Tech-talk
Next: Re: generalTime/epicsTimeGetCurrent and casr questions Jemian, Pete R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
ANJ, 13 Mar 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
