1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: R3.15.6 calc string doesn't accept LA, LB, LC, etc...?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Neil Hamilton Jr <[email protected]>, [email protected]
Date: Tue, 19 Mar 2019 19:56:11 -0700
On 3/19/19 7:50 PM, Michael Davidsaver wrote:
> Uses a Channel Access list
Of course I should have typed 'Channel Access link'.
> to process '$(P)INC' each time '$(P)WATCH' changes.
> This can be extended with additional inputs INPB ...
> On 3/19/19 5:42 PM, Neil Hamilton Jr via Tech-talk wrote:
>> Hey all,
>> I'm trying to create a calc record that looks at previous values to increment a count.  See below
>> record(calc, "RESULT_A")
>>    field(SCAN, ".05 second")
>>    field(INPH, "RESULT_A.LG")
>>    field(INPA, "RESULTINPA")
>>    field(INPC, "RESULTINPC")
>>    field(INPB, "RESULT.LA <http://RESULT.LA>")
>>    field(INPE, "RESULTINPE")
>>    field(INPD, "RESULT.LC <http://RESULT.LC>")
>>    field(INPG, "RESULTINPG")
>>    field(INPF, "RESULT_A.LE")
>>    field(CALC, "A#B?1:0+C#D?1:0+E#F?1:0+G#H?1:0")
>> If I change B to LA in the calc string above I get this error during dbLoadRecords
>> RESULT_A.CALC: Syntax error, unknown operator/operand in expression "A#LA?1:0+C#D?1:0+E#F?1:0+G#H?1:0"
>> First I'd like to ask if the 'last' fields are usable this way.  From the record reference manual it appears they are.  Second, does anyone have a better way of just incrementing a count anytime the inputs change?  Any help is very much appreciated.
>> Neil Hamilton Jr
R3.15.6 calc string doesn't accept LA, LB, LC, etc...? Neil Hamilton Jr via Tech-talk
Re: R3.15.6 calc string doesn't accept LA, LB, LC, etc...? Michael Davidsaver via Tech-talk
Prev: Re: R3.15.6 calc string doesn't accept LA, LB, LC, etc...? Michael Davidsaver via Tech-talk
Next: Re: R3.15.6 calc string doesn't accept LA, LB, LC, etc...? Mooney, Tim M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
ANJ, 19 Mar 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
