1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: pvget is timing out
To: "Ivashkevych, Oksana" <[email protected]>
Date: Sat, 23 Mar 2019 15:55:35 +0000
Just change CONFIG_SITE.local to add WITH_QSRV=YES. That was added in ADCore R-3-2.
Sent from my iPhone
> On Mar 23, 2019, at 10:38 AM, Ivashkevych, Oksana <[email protected]> wrote:
> Pete and Mark,
> Thank you both,
> I just checked my Debian7 system has
> WITH_PVA=YES, and nothing for WITH_QSRV.
> It all makes sense.
> I can't check  xf11id-m1 now, it is on campus network, and I forgot its IP address.  I'm pretty sure WITH_QSRV is defined there.
> What if I would like to add qsrv to my IOC, do we have DIY instructions?
> Oksana
>> -----Original Message-----
>> From: Mark Rivers <[email protected]>
>> Sent: Saturday, March 23, 2019 11:30 AM
>> To: Ivashkevych, Oksana <[email protected]>
>> Cc: [email protected]
>> Pete's post reminded me that you also need to set WITH_QSRV=YES in
>> areaDetector to use it. For 3.14 compatibility we allow WITH_PVA=YES and
>> WITH_QSRV=NO.
>> Mark
>> Sent from my iPhone
>>> On Mar 23, 2019, at 9:55 AM, Mark Rivers <[email protected]> wrote:
>>> areaDetector IOCs are now built with qsrv by default if WITH_PVA=YES.
>>> corvette:~>caget 13SIM1:cam1:Acquire
>>> 13SIM1:cam1:Acquire            Done
>>> corvette:~>pvget 13SIM1:cam1:Acquire
>>> 13SIM1:cam1:Acquire 2019-03-21 07:59:36.269  (0) Done
>>> Mark
>>> Sent from my iPhone
>>>> On Mar 23, 2019, at 9:42 AM, Ivashkevych, Oksana <[email protected]>
>> wrote:
>>>> Thanks!
>>>> That's worked.
>>>> I actually wanted to use PV Access. So I need to run "qsrv or
>>>> equivalent"(?) I'll educate myself.
>>>> Oksana
>>>>> Sent: Saturday, March 23, 2019 10:30 AM
>>>>> Do
>>>>> pvget -h
>>>>> to get help.
>>>>> pvget defaults to using pvAccess protocol. That can only read normal
>>>>> IOC pvs if your IOC is running qsrv or equivalent.
>>>>> To use pvget to use Channel Access do
>>>>> pvget -p ca pvname
>>>>> Example:
>>>>> corvette:~>pvget -p ca 13IDA:m1
>>>>> 13IDA:m1 -0.25
>>>>> Mark
>>>>> Sent from my iPhone
>>>>> On Mar 23, 2019, at 8:31 AM, Ivashkevych, Oksana via Tech-talk
>>>>> <tech- [email protected]<mailto:[email protected]>> wrote:
>>>>> Hello,
>>>>> I have built latest epics-base branch 7.0 and R.7.0.2.1 on Windows 7
>>>>> and CentOS 4.4.7.(tested both).  I cloned with - - recursive option.
>>>>> When I am using caget(), it works, pvget() doesn't. It doesn't even
>>>>> print me an error message when I don't specify a PV. Behaves
>>>>> identical on both systems. When I specify a PV, request times out.
>>>>> On this CentOS system I have only base built and nothing running
>>>>> det@xf11bm- pilatus800k:~/epics/epics-base/bin/linux-x86_64> ./caget No
>> pv name specified.
>>>>> ('caget -h' for help.)
>>>>> det@xf11bm-pilatus800k:~/epics/epics-base/bin/linux-
>>>>> x86_64> ./pvget
>>>>> det@xf11bm-pilatus800k:~/epics/epics-base/bin/linux-x86_64>
>>>>> On this Windows 7 I have bunch of modules built and my new driver
>>>>> and IOC, which theoretically could be a contributing factor, but I don't think
>> so.
>>>>> C:\epics\epics-base>bin\windows-x64-static\pvget.exe
>>>>> //prints empty line
>>>>> C:\epics\epics-base>bin\windows-x64-static\caget.exe
>>>>> No pv name specified. ('caget -h' for help.)
>>>>> C:\epics\epics-base>git branch
>>>>> * (HEAD detached at R7.0.2.1)
>>>>> 7.0
>>>>> C:\epics\epics-base\bin\windows-x64-static>caget XF11ID-
>>>>> ES{elveFlowOB1}:elveFlow:Pres1
>>>>> XF11ID-ES{elveFlowOB1}:elveFlow:Pres1 22.3389
>>>>> C:\epics\epics-base\bin\windows-x64-static>pvget XF11ID-
>>>>> Timeout
>>>>> I have another system with Debian 7.
>>>>> On this Debian 7 I have bunch of ADProsilica  and ADPilatus iocs
>>>>> running, built with base 7.0.1. At least pvget() responds with the
>>>>> correct complaint, though times out with a PV.
>>>>> oksana@xf11bm-ioc1:/epics/distrib/epicsBundle-R-7-0-1+deb7u1-x86_64/
>>>>> epics- base/bin/linux-x86_64$ ./pvget No pv name(s) specified.
>>>>> ('pvget -h' for help.)
>>>>> XF:11BMA-BI{FS:1-Cam:1}cam1:AcquireTime
>>>>> Timeout
>>>>> epics- base/bin/linux-x86_64$ ./caget
>>>>> XF:11BMA-BI{FS:1-Cam:1}cam1:AcquireTime 1 oksana@xf11bm-
>>>>> ioc1:/epics/distrib/epicsBundle-R-7-0-1+deb7u1-x86_64/epics-base/bin
>>>>> /linux-
>>>>> x86_64$
>>>>> There is one system where pvget() does work. One year ago I built
>>>>> from core/master on Debian 8. This branch is closed now.  On this
>>>>> machine I have one ADprosilica and one ADPointGrey IOC running with
>>>>> this base. There are other IOCs, but they use Debian distribution.
>>>>> oksana@xf11id-m1:/opt/epics/ADepics7/epics-base/bin/linux-x86_64$
>>>>> ./pvget XF:MOBILE-BI{Mir:1}cam1:AcquireTime
>>>>> XF:MOBILE-BI{Mir:1}cam1:AcquireTime 0.3
>>>>> ./caget XF:MOBILE-BI{Mir:1}cam1:AcquireTime
>>>>> git branch
>>>>> * core/master
>>>>> What I could be missing? Why pvget() does not work for me?
>>>>> Thanks,
>>>>> Oksana
Re: pvget is timing out Shen, Guobao via Tech-talk
pvget is timing out Ivashkevych, Oksana via Tech-talk
Re: pvget is timing out Mark Rivers via Tech-talk
RE: pvget is timing out Ivashkevych, Oksana via Tech-talk
Prev: RE: pvget is timing out Ivashkevych, Oksana via Tech-talk
Next: Cannot access to pilatusDoc Zhibang Shen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Next: Re: pvget is timing out Shen, Guobao via Tech-talk
ANJ, 26 Mar 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
