1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: Nested PVStructureArray With pvput
From: Michael Davidsaver via Tech-talk <[email protected]>
To: William Cork <[email protected]>
Cc: [email protected]
Date: Tue, 2 Apr 2019 21:38:36 -0700
On 4/2/19 8:23 PM, William Cork via Tech-talk wrote:
> Hi All,
> I’m working on a softIOC that will make calls to a Monit daemon to restart and monitor services under Monit.
> Right now, I have the following pv structure (a wip):
> |test:Monit:localhost structure string host http://localhost:2812 int poll 120 structure[] services structure string name testService boolean monitored true int state 0 string type SERVICE epics:nt/NTEnum:1.0 action enum_t value int index 0 string[] choices ["none", "enable", "disable", "start", "stop", "restart"] |
> Is it possible to change an element in the nested services list with pvput, or are the immutable?
> |pvput test:Monit:localhost services='...'| may be the wrong syntax?
> More precisely, can I change services[index of service I care about].action = one of the action enums.
> Architecturally speaking, is it more ideal to have a bookkeeping PVArray that lists the provided services and individual PVs for each service?
Are you thinking to control this with a existing client application?
eg. an OPI client like cs-studio?  I find that questions like this
are best approached by think from the prospective of a client.
What will a client want to do?  What steps are involved?
Are there any issues of atomicity (eg. racing with other
clients).  What configuration will a client need?
Now for the part for which I have a clear answer.
For the present the 'field=' syntax is limited to scalars and arrays of scalars.
It is possible to send an array of structures w/ pvput provided you're
building against Base >=3.15 (which includes a JSON parser).  The syntax
is awkward though:
> $ pvput -h 2>&1|grep JSON
>  JSON support is present
> Field values may be given with JSON syntax.
An empty array:
> pvput test:Monit:localhost '{"services":[]}'
One element with all default values.
> pvput test:Monit:localhost '{"services":[{}]}'
One element with one field having a non-default value.
> pvput test:Monit:localhost '{"services":[{"state":42}]}'
Re: Nested PVStructureArray With pvput William Cork via Tech-talk
Prev: Nested PVStructureArray With pvput William Cork via Tech-talk
Next: Re: Nested PVStructureArray With pvput William Cork via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
ANJ, 03 Apr 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
