Is there a reason that the xLS/RxLS limit switch fields in the motor
record only work when the TDIR field's value indicates that the motor is
or was last moving in the direction that would normally trigger the
corresponding limit switch?
This means that that only way to know if a limit switch has REALLY been
triggered is to monitor the bits in the MSTA field.
I am using version 6-9 of the motor record if that makes any difference.
Mark Davis, NSCL/FRIB
Control Systems Software Engineer
[email protected]
- RE: limit switch fields in the motor record Mark Rivers via Tech-talk
- Re: limit switch fields in the motor record Peterson, Kevin M. via Tech-talk
Re: firewalld configuration for EPICS? Benjamin Franksen via Tech-talk
<2019>
Re: asynMotor device support and the motor specific driver (asynMotorContorller) Allan Serra Braga Bugyi via Tech-talk
<2019>
