1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: Re: Base 7.0.2 compile error on Raspberry Pi 3
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Wed, 24 Apr 2019 19:48:07 +0000
Hi Kaz,
On 4/24/19 1:37 PM, Gofron, Kazimierz via Tech-talk wrote:
Base: R7.0.2
Linux raspberrypi 4.9.80-v7+ #1098 SMP Fri Mar 9 19:11:42 GMT 2018 armv7l GNU/Linux
gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1+deb9u1)
GNU Make 4.1
make -C O.linux-arm -f ../Makefile TOP=../.. \
    T_A=linux-arm install
make[4]: Entering directory '/epics/base/modules/libcom/test/O.linux-arm'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/epics/base/modules/libcom/test/O.linux-arm'
make[3]: Leaving directory '/epics/base/modules/libcom/test'
make[2]: Leaving directory '/epics/base/modules/libcom'
make -C ./ca install
make[2]: Entering directory '/epics/base/modules/ca'
make -C ./configure install
make[3]: Entering directory '/epics/base/modules/ca/configure'
make[4]: Entering directory '/epics/base/modules/ca/configure/O.linux-arm'
perl -CSD /epics/base/bin/linux-arm/convertRelease.pl checkRelease
make[4]: Leaving directory '/epics/base/modules/ca/configure/O.linux-arm'
make[3]: Leaving directory '/epics/base/modules/ca/configure'
make -C ./src install
make[3]: Entering directory '/epics/base/modules/ca/src'
make -C ./client install
make[4]: Entering directory '/epics/base/modules/ca/src/client'
make -C O.linux-arm -f ../Makefile TOP=../../.. \
make[5]: Entering directory '/epics/base/modules/ca/src/client/O.linux-arm'
/usr/bin/g++ -o libca.so.4.13.3 -shared -fPIC -L/epics/base/lib/linux-arm -Wl,-rpath,/epics/base/lib/linux-arm           -rdynamic          cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o   -lCom   -lpthread    -lm -lrt -ldl -lgcc
disconnectGovernorTimer.o: file not recognized: File truncated
collect2: error: ld returned 1 exit status
/epics/base/configure/RULES_BUILD:291: recipe for target 'libca.so.4.13.3' failed
Please try the following:
cd /epics/base/modules/ca/src/client
make rebuild
The error is complaining about a file
disconnectGovernorTimer.o but your log above doesn't show us what happened when you built that file (you only showed us a subsequent build when an incomplete .o file already existed). Starting again from a clean directory might fix the build problem, and if it doesn't we should see more about what's going wrong.
- Andrew
Base 7.0.2 compile error on Raspberry Pi 3 Gofron, Kazimierz via Tech-talk
Prev: Base 7.0.2 compile error on Raspberry Pi 3 Gofron, Kazimierz via Tech-talk
Next: RE: Base 7.0.2 compile error on Raspberry Pi 3 Gofron, Kazimierz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
ANJ, 24 Apr 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
