We have some Travis builds that are using the NSLS2 Debian repository. They used to work before the repo moved, and now they are failing.
The snippet from .travis.yaml:
addons:
apt:
sources:
- sourceline: 'deb https://epics.nsls2.bnl.gov/debian/ wheezy main contrib'
key_url: 'https://epics.nsls2.bnl.gov/debian/repo-key.pub'
packages:
- epics-dev
- build-essential
Tries to run:
curl -sSL "https://epics.nsls2.bnl.gov/debian/repo-key.pub"
Which fails with:
curl: (60) Peer's Certificate issuer is not recognized.
More details here: http://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
Any ideas?
Tom
> -----Original Message-----
> From: [email protected] <[email protected]> On
> Behalf Of Flaks, Leonid via Tech-talk
> Sent: 01 May 2019 20:33
> To: Mark Rivers <[email protected]>; '[email protected]' <tech-
> [email protected]>
> Subject: Re: Problem with NSLS2 Debian repository?
> The directory structure has been reverted back to original state. Now the link
> https://epics.nsls2.bnl.gov/debian/repo-key.pub works again.
> Leon
> From: Mark Rivers <[email protected]>
> Date: Monday, April 1, 2019 at 7:35 PM
> To: Leonid Flaks <[email protected]>, "'[email protected]'" <tech-
> [email protected]>
> Subject: RE: Problem with NSLS2 Debian repository?
> Thanks, that fixed it. Is that likely to be the path in the future, or are you
> going to ask them to change it back?
> Mark
> From: Flaks, Leonid <[email protected]>
> Sent: Monday, April 1, 2019 6:23 PM
> [email protected]>
> Our ITD is playing games with us. Long story short - they changed root
> directory (we asked them not to!). Now we need to drop the word “debian”
> from the path and all instructions that mention the path.
> Correct path for now would look like this:
> https://epics.nsls2.bnl.gov/repo-key.pub
> Thanks for noticing!
> Leon
> Get Outlook for iOS <https://aka.ms/o0ukef>
> ________________________________
> From: [email protected] <mailto:tech-talk-
> [email protected]> <[email protected] <mailto:tech-talk-
> [email protected]> > on behalf of Mark Rivers via Tech-talk <tech-
> [email protected] <mailto:[email protected]> >
> Sent: Monday, April 1, 2019 6:37:52 PM
> To: '[email protected]'
> Subject: Problem with NSLS2 Debian repository?
> The asyn Travis build failed with the following error:
> 0.23s$ curl https://epics.nsls2.bnl.gov/debian/repo-key.pub
> <https://epics.nsls2.bnl.gov/debian/repo-key.pub> | sudo apt-key add -
> gpg: no valid OpenPGP data found.
> The command "curl https://epics.nsls2.bnl.gov/debian/repo-key.pub
> <https://epics.nsls2.bnl.gov/debian/repo-key.pub> | sudo apt-key add -"
> failed and exited with 2 during .
> Anyone know what is wrong?
> Thanks,
> Mark
- Re: Problem with NSLS2 Debian repository? Flaks, Leonid via Tech-talk
- Problem with NSLS2 Debian repository? Mark Rivers via Tech-talk
- RE: Problem with NSLS2 Debian repository? Mark Rivers via Tech-talk
Re: IOClog Jeong Han Lee via Tech-talk
<2019>
2025
<2019>
2025
