So of course I left out the piece of info that actually caused my problem. At Gemini we're using TDCT to design and build our databases. Turns out this is generating a SUBL field with zeros as shown below. Replacing this field with an empty string solves my problem. I'll follow up with Rolf to get the rule changed and see if we can (formally?) support aSub in tdct. My symbols are just clones of the genSubRecords used here at Gemini. --Matt #= database generated by tdct V2.17.5 #= on 2019-05-06 14:35 #= configuration file: ../tdct.cfg #= (mode: Capfast compatibility) record(aSub,"simpleTest") { field(DESC,"Array Subroutine Record") field(SCAN,"Passive") field(PINI,"NO") field(PHAS,"0") field(EVNT,"0") field(DISV,"1") field(PREC,"0") field(LFLG,"IGNORE") field(EFLG,"ALWAYS") field(SDIS,"0.0000000000000000e+00") field(DISS,"NO_ALARM") field(PRIO,"LOW") field(FLNK,"0.000000000000000e+00") field(SUBL,"0.0000000000000000e+00") On Mon, May 6, 2019 at 10:11 AM Matt Rippa <[email protected]> wrote:
ANJ, 08 May 2019 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
