Hi all, I have a question about Linux OS. My epics shell always shutdown itself in this computer, so the epics ioc could not run long time. I do not quite know how the OS shutdown. I just know the ioc was shut down. I means that I don't know what happened. I checked the log and found these information bellow. I am not good at the linux OS, so I am here ask for help. Could someone tell me how to fix it. Regards, Li xing My OS informaion root@localhost log]# cat /proc/version Linux version 3.10.0-957.12.1.el7.x86_64 ([email protected]) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-36) (GCC) ) #1 SMP Mon Apr 29 14:59:59 UTC 2019 [root@localhost log]# lsb_release -a LSB Version: :core-4.1-amd64:core-4.1-noarch:cxx-4.1-amd64:cxx-4.1-noarch:desktop-4.1-amd64:desktop-4.1-noarch:languages-4.1-amd64:languages-4.1-noarch:printing-4.1-amd64:printing-4.1-noarch Distributor ID: CentOS Description: CentOS Linux release 7.6.1810 (Core) Release: 7.6.1810 Part of my log(message): And I found someone report the same question in the https://bugs.centos.org/view.php?id=15900 ------------------------------------------------------------------------------ May 13 20:03:39 localhost journal: STACK_OP_ADD: window 0x3000001 already in stack May 13 20:03:40 localhost : QSGContext::initialize: depth buffer support missing, expect rendering errorsMay 13 20:03:40 localhost : QSGContext::initialize: stencil buffer support missing, expect rendering errors May 13 20:03:40 localhost journal: JS WARNING: [resource:///org/gnome/shell/ui/keyboard.js 553]: reference to undefined property "_rect" May 13 20:03:40 localhost journal: JS ERROR: Exception in callback for signal: position-changed: TypeError: this._rect is undefined#012getCurrentRect@resource:///org/gnome/shell/ui/keyboard.js:553:22#012wrapper@resource:///org/gnome/gjs/modules/_legacy.js:82:22#012_onFocusPositionChanged@resource:///org/gnome/shell/ui/keyboard.js:635:20#012wrapper@resource:///org/gnome/gjs/modules/_legacy.js:82:22#012_emit@resource:///org/gnome/gjs/modules/signals.js:128:27#012_setCurrentWindow/this._currentWindowPositionId<@resource:///org/gnome/shell/ui/keyboard.js:534:21 May 13 20:03:40 localhost journal: JS ERROR: Exception in callback for signal: position-changed: TypeError: this._rect is undefined#012getCurrentRect@resource:///org/gnome/shell/ui/keyboard.js:553:22#012wrapper@resource:///org/gnome/gjs/modules/_legacy.js:82:22#012_onFocusPositionChanged@resource:///org/gnome/shell/ui/keyboard.js:635:20#012wrapper@resource:///org/gnome/gjs/modules/_legacy.js:82:22#012_emit@resource:///org/gnome/gjs/modules/signals.js:128:27#012_setCurrentWindow/this._currentWindowPositionId<@resource:///org/gnome/shell/ui/keyboard.js:534:21 May 13 20:03:40 localhost journal: g_simple_action_set_enabled: assertion 'G_IS_SIMPLE_ACTION (simple)' failed May 13 20:03:40 localhost journal: g_simple_action_set_enabled: assertion 'G_IS_SIMPLE_ACTION (simple)' failed May 13 20:03:40 localhost gnome-shell: GNOME Shell started at Mon May 13 2019 20:03:36 GMT+0800 (CST) May 13 20:03:40 localhost dracut: *** Installing kernel module dependencies and firmware done *** May 13 20:03:40 localhost dracut: *** Resolving executable dependencies *** May 13 20:03:40 localhost : QSystemTrayIcon::setVisible: No Icon set May 13 20:03:40 localhost journal: g_simple_action_set_enabled: assertion 'G_IS_SIMPLE_ACTION (simple)' failed May 13 20:03:41 localhost journal: g_simple_action_set_enabled: assertion 'G_IS_SIMPLE_ACTION (simple)' failed May 13 20:03:41 localhost journal: g_simple_action_set_enabled: assertion 'G_IS_SIMPLE_ACTION (simple)' failed May 13 20:03:41 localhost journal: g_simple_action_set_enabled: assertion 'G_IS_SIMPLE_ACTION (simple)' failed May 13 20:03:41 localhost journal: g_simple_action_set_enabled: assertion 'G_IS_SIMPLE_ACTION (simple)' failed May 13 20:03:41 localhost journal: g_simple_action_set_enabled: assertion 'G_IS_SIMPLE_ACTION (simple)' failed May 13 20:03:41 localhost journal: g_simple_action_set_enabled: assertion 'G_IS_SIMPLE_ACTION (simple)' failed May 13 20:03:41 localhost journal: g_simple_action_set_enabled: assertion 'G_IS_SIMPLE_ACTION (simple)' failed May 13 20:03:41 localhost journal: Exiting May 13 20:03:41 localhost dracut: *** Resolving executable dependencies done***
ANJ, 16 May 2019 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
